#81
Old 12-11-2012, 11:46 PM
tom s tom s is offline
Ken,would need to be custom,too narrow.That is what I wanted but trying to do on the cheap.Dont have the final deck yet.I need to fit the shim and check the clearance for the counter weights next.It will be in the 9.2ish range.Tom
  #82
Old 12-11-2012, 11:53 PM
I think Dave matched the flanges too his 260 CNC port job,maybe that helped with all the matching?Im sure you could contact him.Whne I get a chance I will take a pic of a gasket on the head and then on the intake.Tom
  #83
Old 12-12-2012, 03:55 AM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
[QUOTE=77 TRASHCAN;4789688]Weak compared to a 400, 455, not knocking your incredible effort.
I was underwhelmed, finding out here, the the main webbing had been compromised also, to make this "transportaion" engine lighter...
... i'm afraid i disagree with that part, the 301T blocks are considerably more beefy than the std. 301 blocks, which is why they stopped making the std. blocks, too many issues ...
... as you can see, these blocks were in fact very nice castings, and my stroker 434/301T project has very thick mains, and is right with the thickest blocks Pontiac had made, at least the ones we've measured over the years, not saying its the thickest, but surely not the smallest ...
ID:	305939   Click image for larger version
ID:	305940   Click image for larger version
ID:	305941   Click image for larger version
  #84
Old 12-12-2012, 01:54 PM
here are pics of intake and head port openings with std gasket and the RAIV gasket.Tom
ID:	305965   Click image for larger version
ID:	305967   Click image for larger version
ID:	305969   Click image for larger version
  #85
Old 12-12-2012, 01:55 PM
few more
ID:	305973   Click image for larger version
ID:	305974   Click image for larger version
ID:	305975   Click image for larger version
  #86
Old 12-12-2012, 04:08 PM
Pontiac Performance Author
looks like a 6" rodwill give a street worthy pin height. whats the big end width on a 301 rod?
  #87
Old 12-12-2012, 04:52 PM
I need stock pontiac rod width.BBC will work and 6.135 is the shortest I can find without a custom rod.I wanted a 6in like we used in the RA V build but have to compremise.Tom
  #88
Old 12-12-2012, 06:26 PM
81TTA's Avatar
81TTA 81TTA is offline
Thanks for the pictures of the manifold ports. Looks like some smoothing was done after the flanges were reattached?
I'm not sure if the Torker II came in versions without the exhaust crossover. It appears from one of your pictures that it's been milled off? I think it makes life a lot easier when the flange only needs to match up to the runners instead of trying to match up to the runners *and* the exhaust crossover.
Anyway, that manifold is sweet. Very nice work!
  #89
Old 12-12-2012, 06:56 PM
anything not needed was removed to make it easyer to do.Tom
  #90
Old 12-12-2012, 09:27 PM
Tom Vaught's Avatar
Boost Engineer
Your engine should like that 950 3 BBL vacuum carb for the initial dyno runs.
Tom Vaught
  #91
Old 12-12-2012, 09:28 PM
Joe has a dyno Quickfuel he virtually always uses.Tom
  #92
Old 12-12-2012, 09:52 PM
Dave Bisschop's Avatar
Dave Bisschop Dave Bisschop is offline
Tom let me know about this thread, when it comes to the intake I set up the intake in the CNC and separated the flanges by using a 3/4" end mill. I then milled them perfectly flat. I had Tom's block and bolted on a mock up set of heads with head gaskets and bolted the flanges to the heads without the intake gaskets which would give me about .060" to mill the flanges perfectly flat once all the welding was done.
From there I milled each side of the intake (or what was left of it!!). I tried using math, but basically it came down to trial and error fitting to get it where I was happy with it. The outside runners line up pretty reasonable but the inners required extensive welding to build up the material. It was definitely more time consuming than I had anticipated but part of the problem was dealing with the impurities that had been absorbed by the intake since it was used, anyone who's welded used cast aluminum will know what I'm talking about. Getting the exhaust crossover to work would have been difficult so Tom was ok with me removing it. Beyond all the welding there was a ton of diegrinding and sanding, but I'm kind of use to that!!
I think the end product turned out well and almost looks like it was cast that way.
Hopefully this answers some of the questions people have on what it took to modify the intake. It's not as simple as cutting the flanges off, removing about and inch worth of runner and welding it back together.
  #93
Old 12-12-2012, 10:09 PM
I did get some info on welding used castiron.I was told in the aircraft industry they dip the part to be welded in liquid nitrogine to clean clean it.FWIW,Tom
  #94
Old 12-12-2012, 10:15 PM
All T2's come with ex crossover. You can eliminate it. you could also block exhaust (fill) and plumb the heat crossover for water if you really want/need heat in your manifold. If it dont clear the valley tray shrink it. Its not terribly difficult to cut the entire heated section off a t1, performer, rpm, t2, HSD etc.. Wouldnt be hard to make a new manifold heater with aluminum tubing if you really felt you had to have one.
The harder part is what Dave said ^^^^!!!
  #95
Old 12-12-2012, 10:19 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Question
Dave, did you look into brand x manifolds as a possible easier way to fab an intake?
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
  #96
Old 12-12-2012, 10:28 PM
65 tri-pwr's Avatar
65 tri-pwr 65 tri-pwr is offline
I was also looking into doing this for my 1981 TTA. I have a 1977 350 crank and the counter weights look to clear the block with no problems. I gave up after seeing the issues with the thrust bearing and needing a shorter rod (I wanted to keep the stock heads and turbo set up). But I am starting to look at this again after seeing what Tom is doing.
Ken, you mention a shorter rod. Yes it is tough finding a rod under 6" with at least a .980" width big end. So far I found aftermarket rods for the Ford 2300 4cyl. (sportsman rods?) They come in different lengths. Another is AMC 290-360 rods. They have a 1.06" width big end and a bearing diameter of 2.095". The length of the AMC rods is 5.858" and a .930" pin diameter. Not sure if a stock Pontiac crank can be ground to a 2.095 rod journal safely.
Possibly looking for a factory 4-speed 1979 GP.
Owner of TTA Performance specializing in performance and restoration parts for the 301 Turbo.
www.ttaperformance.com
  #97
Old 12-12-2012, 11:29 PM
there can be a issue with turning too small as to what happens to the oil holes.I have taken them to 2.10.Tom
  #98
Old 12-12-2012, 11:55 PM
J.C. I never really considered it since #2 cylinder is ahead of #1 to start with on a Pontiac and bore spacing and flange angles are all different as well, so I don't see any of them being an easier mod. then starting with a Pontiac "tall deck" intake.
  #99
Old 12-13-2012, 12:13 AM
81TTA's Avatar
I guess part of the "problem" with making it look like it was originally cast that way is the fact it masks all the work you put into it! From the work I'd done on those manifolds, I thought there had to be quite a bit of effort put into getting the final product together. There just don't seem to be any manifolds with runners straight enough to allow the amount of material to be removed as is needed. By the time the material is removed, the cross section of the runner has changed enough the flanges no longer line up. I know what you mean about trying to weld the cast aluminum that's seen about every engine fluid in addition to paints/waxes/etc. Just tacking the flanges in a few spots was a nightmare.....
Again, very nice work! Thanks for the additional info.
  #100
Old 12-13-2012, 03:23 AM
GregonVI GregonVI is offline
Would a rod from a 409 Chevy work? That engine has a 2.20" rod journal size and I believe the rod is 6.0" long.
http://www.show-cars.com/NewParts.htm
Greg
'79 Grand Prix LJ 301 4bbl.
Thread Tools
Display Modes
