#61
Valve cover and hubcap pics / new very old rebuild kit
Attached are pics of the original valve covers
They have some light pitting should I reuse or just keep and buy new ones? The block has been Correctly painted even though I now know it was a mistake to do so … also attached original hub caps also showing normal were and tear should I use these ?? If so I do not have the rims that work for these caps still need part number or site please .. also I have some very cool old AC delco Vintage carb rebuilt kits I will keep with the car . And a repo build sheet thanks for the advice . |
#62
Current Pontiacs - 1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1974 Formula 400 - Ram Air automatic 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
The Following User Says Thank You to 71GP76TA For This Useful Post: | ||
#63
The Optional Mirror-Inside Non-Glare #392 was either left off that reproduction window sticker or someone added that mirror.
Tedd930, When you are taking photos of various items please take a photo of the rectangle aluminum Data Plate on the firewall. Thanks.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
#64
..... and the spare wheel , and its stampings .
If it passes inspection , then you have a perfect example in hand of what you need to look for when hunting a replacement set. Also look to see if any evidence the rim has been repainted Black. As in if possibly it was originally Fontaine Blue |
#65
Ok .. that’s great I will take a good look at the spare
In the am.. I think it’s just a black rim. |
#66
I just received a ton of documents from the Pontiac historical records .. is there anything in there that would help??
#67
The two most important items to verify a GTO.
1) Data Plate on firewall. 2) Car Billing History card as shown below.
The Following User Says Thank You to 60sstuff For This Useful Post: | ||
#68
Forgot one.
The POP if it’s still with the car.
#69
I have that !!! I will post it later
Today running kids to school!! 😂 |
#70
I think the valve covers look pretty presentable. You can probably get them looking better with some Flitz or Simichrome polish - it won't remove the pitting, but should get them looking better.
#71
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
#72
Try to avoid the reproduction parts as nothing looks as good as the real GM. I agree with Stuart that your valve covers look very presentable for a 57 year old GTO.
#73
Car billing history attached .
Ok here it is …. Thank you again for the information!!
#74
000 or 0000 steel wool is pretty good to clean up those valve covers..
Greg Reid Palmetto, Georgia |
#75
It’s been confirmed. This GTO is the lowest optioned car I’ve seen.
Push button AM radio only. But it’s a P1 Convertible 3x2’s 4 spd. with a 3.55 and Red Line tires. 18 764 = Taber Pontiac Inc. Atlanta, GA.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. Last edited by 60sstuff; 02-07-2024 at 12:15 PM. |
#76
Will smooth out pitting and speckling and clean off rust stains. Then use chrome polish or paste wax - or both. The wool also works good on glass to make it smooth and slick where your knuckle will just glide across it. Removes build up and residues , and over spray. Last edited by Baron Von Zeppelin; 02-07-2024 at 01:44 PM. |
#77
Tedd , your Protect-o-Plate may or may not have a wheel color code.
But we can check it out. It WILL have your engine code (WS) More importantly it will have the serial number of the engine. The code and serial number are stamped on passenger side front face of block just below where the cylinder head mates to the block. Not doubting yours match - but it gives that extra fuzzy feel when you verify it. Very few of these cars still have their PoP to confirm the engine serial number. We will likely have to rely on examining your spare to get the nitty gritty on correct wheel color. All 5 rims would have been matching when new. Close up around valve stem will help us help you find the most exact replacements. |
#78
Lowest option tripower car I can recall - ever.
Have seen a 68 Vert with only 4spd - no radio or anything. 70 Hdtp with 0 options. Blank Invoice - completely blank. |
#79
This Barrier '66 looks very nice with the poverty caps, black wheels and redlines. Beautiful car. Considering the level of restoration, I think it was in Hemming's, and the earlier post with the color chips, I would lean towards black wheels being correct.
Sent from my moto g stylus (2021) using Tapatalk
#80
Greg..that’s awesome I am calling the shop where the cars at to have them check the original spare
Hoping it’s Black!! Based on the bare bones options I would think it would be black.. thank you |
The Following User Says Thank You to Tedd930 For This Useful Post: | ||
Thread Tools | |
Display Modes | |
