#41
A lot of hydraulic roller lifters have a disc that has a tendency to break, it's underneath the pushrod cup. The broken disc can now move around and block the oil hole. The lifters works but won't oil the pushrod.
#42
MUCH better to GROUND the spark in order to kill each cylinder in turn. Blunt the sharp points of eight small nails. Lightly lube the nails with silicone dielectric grease, then slide the nails between the plug wires and the distributor boots. You'll feel the nails touch the metal end of the plug wire. DO NOT puncture the insulation. Then touch each nail in turn with a grounded jumper-wire or 12V test light (the lamp won't light up.) No high voltage, no insulation damage. |
The Following User Says Thank You to Schurkey For This Useful Post: | ||
#43
Well this sucks
Title and pic says it all
#45
Well hey now you can build back better, That sux ya figure bearing material ?
#46
I think you know why the lifter didn't work?
Sorry to see that.
The Following User Says Thank You to johnta1 For This Useful Post: | ||
#47
What are you showing us? There's no reference for size; that could be a cup of Starbux coffee with melted whipped cream, and a goofy-looking "sprinkle" on top.
No, the title and pic DON'T "say it all". |
#48
Yeah...is that a Latte, or hot chocolate?
The Following User Says Thank You to 77 TRASHCAN For This Useful Post: | ||
#49
That is the bottom of the cut open oil filter.
#50
Looks like sand?Tom
#51
Assuming that is iron/steel and not bronze or copper? Trash from assembly? Oxide from a rusty block?
I guess either one is not good. If you do a rebuild .... get some niobium bar magnets and stick them around the circumference of the filter housing. Then when you cut filter open the ferrous material will be stuck to the housing walls and the bearing materials and other non-ferrous particles will be in the bottom. I typically leave the magnets on all the time to help keep very fine metal particles out of the oil.
I'm World's Best Hyperbolist !! |
The Following User Says Thank You to dataway For This Useful Post: | ||
#52
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
#53
Is this a follow up to your other post on Thoughts on knocking sound?? If so, Dam that too bad. Sorry that happened to your engine. Can you give us more on the cause. Oil doesn't look so good for sure.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick. Best so far 9.95@134 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. |
#54
One I find out the root cause of the copper/brass I'll let you know. But my guess is either the cam gear is chewed up or a bearing.
The Following User Says Thank You to slowbird For This Useful Post: | ||
#55
I don’t believe Brass is used in the make up of modern replaceable bearings.
Time to yank the dizzy and look down at the gear.
I do stuff for reasons. |
The Following User Says Thank You to 25stevem For This Useful Post: | ||
#56
if its bearing material could be main thrust bearing easy to check without tear down by looking at crankshaft endplay
pry crankshaft fore aft should be easy to spot excess without a dial indicator Last edited by Formulas; 11-15-2022 at 12:13 PM. |
#57
There's really no title needed for a pic like that.
#58
Before you spring into action get your bearings ... OK sorry for both the puns and your misfortune.
Triple Black 1971 GTO |
#59
Without rereading the whole thread, was this a Hydraulic Roller camshaft lifter?
Manufacturer? Tom V.
#60
It is a HR camshaft and lifter set that came from Competition Cams |
Thread Tools | |
Display Modes | |
