#41
The thread left me hanging. Is this guy still around? Does he sell these? I dont mean to knock it, looks like a lot of work but I think its overkill.
Anyone willing to do the work themselves will be able to do it the way I did for way under 100 bucks. The most expensive item so far is the belt at $30. I guess it all depends on where you get your pulleys though, mine were 6.00 each at junk yard. I wish I had an engine on a stand for better pics. I am spraying my brackets now and hope to assemble this week with pics. |
#42
yeah, that thread went on for like 4 years, and no end product. I doubt if it is going to ever be sold.
And I like that big plate about as much as I like the bling bling of the March setup. Russ |
#43
Dave Schiffers the OP last posted in Dec. 2010, according to his public profile.
Its ok to giggle and snicker, Dont laugh and point |
#44
I too don't understand the interest.
#45
Well, I had thought about making a plate to mount the Alt and P/S pump-- or better yet, a Type II pump.
Believe me, Jiimo- I'm all about cheap!! I would rather do the junkyard method than shell out for March's goofy system. I look forward to seeing your finished product. Please keep us updated!
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
#46
I'd like to know if it runs quiet, no belt whistles or squeaks:Is this Serpentine running?
#47
All parts are made and or modified and ready to install. I figured I would replace my noisy power steering pump while I had it apart. Ill have the pump tomorrow and everything should be together by Friday. My pesky 9-5 job gets in the way I did run it with the temporary spacers. Its actually overall quieter but does have a whine to it. I was pleasantly surprised and think it sounds pretty cool! I guess that part is left to opinion though. |
#48
I ask with reason: the Whine or worse yet squeal would be from the Belt mini-Vees bottoming-out on the Pulley Vees. That spells of a worm pulley in a Factory-match Vee-vee array. But This & That pulley with a belt should result in this & that Vee in the Pulley grooves.
Good news is MAYBE all the Manufactureres have standardized on their mini-Vee dimensions so Belt makers can do the same for all Big Car companies. I just don't know. |
#49
I do have to admit that I wasnt aware that the depth was different from each manufacturer until you pointed it out, so thank you. It was only coincidence that I bought the dayco. After reading your post I took a closer look at the pulleys and did some searching online and found this. http://www.daycow.com/daycow.nsf/Day...FQPe4AodFlsHNw I hope everything works well. We will see after some miles and some loads on it. I guess worst case I will have to find a replacement for the VW alternator pulley but that might be difficult. We will see, I'm keepin my fingers crossed. |
#50
Guys screw up on that deal with supercharger pulleys and ribbed belts too. The P-"Dodger" boys sold some systems where the belt rib tips bottomed out in their pulleys and the systems never did make any real boost. Belt slippage.
The only way that a ribbed belt works is if there is no contact at the points and if the belt is gripping on the sides to the pulley groove. Tom Vaught
#51
My R4 set up is off an 81 turbo TA. Bracket is real easy to shim
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
#52
Do you have a pic? I saw a couple on ebay but I didnt want to spend that much on a gamble. I got an aluminum one from a 6 cyl 1990, I think, camaro. It will work with some mods but if the 81 is easier and if I can score one at the right price it would be worth it.
#53
I'll send you one
#54
Frankie,
How about posting it so all can see? That way we can keep a public knowledge base Thanks!
#55
81 TA A/C
81 TA A/C set up R4 compressor. all brackets can be milled or shimmed
#57
Thanks a lot for taking the time to post those Frankie! Thats definitely an option for me. I really like the way those lines do a quick 90 away from the engine without the bends. It would require a bit of spacing in my application but its do-able.
#58
The accumulator is behind the pass side headlight. I upgraded the whole A/C system to 81 with accumulator instead of POA valve.
#59
This looks like a good DIY solution.
I wonder how you know if the accessories are spinning at the correct RPM? |
#60
The only one that would make a real diff would be WP
Thread Tools | |
Display Modes | |
