Belt tensioner
Was installing a new accessory drive/serpentine system today and got stuck on the last piece. The the belt tensioner (Gages 38198) will not budge. Anyone run into this before? Any advise on how to get it to swing?
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
Silly question perhaps, but does it have a temporary lock pin installed to keep it retracted for belt installation?
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
Not sure how you are trying to turn it?? Must use a belt tool or 1/2 breaker bar, big spring in there. Usually has a 1/2 square hole for breaker bar. If not
sometimes they use they pulley bolt that you have removed.
64 Lemans hardtop 4spd, buckets Last edited by Lemans64; 05-11-2024 at 02:04 AM. |
Where is the rest of it. Looks like your missing parts. The belt pulley and bolt. I believe you can put a socket on the bolt on the pulley to relieve tension. These are mounted a certain way. They also have a locking pin in the back of the tension-er when mounting. You can see in the pictures. Also, I believe the belt pulley turns in the same direction the pulley bolt tightens. So the bolt for the pulley never loosens up.
https://store.autovalueparts.ca/p/ga...sioner/3650669
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick. Best so far 9.95@134 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. Last edited by chuckies76ta; 05-11-2024 at 07:16 AM. |
Thanks for chiming in guys. I was using a 14" breaker bar on the pulley bolt yesterday. I've changed serpentine belts before and I can't ever recall running into this issue. These tensioners are pretty simple, so I was stumped. Anyways, I soaked it in penetrating oil overnight and pulled out the 24" breaker bar. Took some effort, but finally broke it loose. I swung it back and forth a few times and it loosened up to where it seems more normal. Not sure what the issue was, but all good now.
Thread Tools | |
Display Modes | |
