421 Block - Sevice Replacement?
A friend just bought a 1964 421 block, standard bore,. Faint code on the front. He was wondering if its an SR block. Either way, its a cool score. Pics below:
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears 66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project Last edited by grivera; 04-28-2024 at 06:02 PM. |
The Following User Says Thank You to grivera For This Useful Post: | ||
More
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears 66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Real nice!
Dare I ask how much he payed for it?
He’s keeping that private for now…
Service Replacement wouldn't have an eun on it
What's the engine code for it?
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." Socrates |
He says it isn’t legible
Just note the ALL service replacement blocks came with rings and fitted Pistons .
Good to know- assembled?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears 66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project Last edited by grivera; 04-29-2024 at 07:11 AM. |
IMO a freshly shot peened used block. Nice find though.
The Following User Says Thank You to Mr Twister For This Useful Post: | ||
Yes, the rings where on the pistons and the pistons where in the bore.
The front 2 four bolt caps are missing the outer bolts.
I never realized that the 64 motors did not use a full length windage tray and still had the bell housing reinforcement ribs from the 425 trophy motors.
Maybe you missed this thread on 1964 389 and 421 blocks: https://forums.maxperformanceinc.com...d.php?t=772995 And my 1964 421 HO build, both threads show the windage tray setup used on 1964 and earlier engines: https://forums.maxperformanceinc.com...d.php?t=771741
The Following User Says Thank You to b-man For This Useful Post: | ||
It’s been a loooong time, but I had a 389 425 T block for a while and just forgot about the windage tray deal.
for sure 64 block,has provision for block mounted starter.JMHO,worth the same as any std bore 3 1/4 main 4 bolt block UNLESS you need a SR or numbers matching code or vin to a car you might own.Nice clean block.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
That was my thought as well, based on pics
Yep- saw that. Hopefully they are the caps original to the block
I think the correct term was "fitted block"no crank or rods.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post: | ||
Xs 2 with the above.
Sorry I should have been more detailed.
All great info - will pass onto my friend
Thread Tools | |
Display Modes | |
