#441
I concur!
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
#442
221 or 260 in the Meteor? (Sorry if you already told me and I forgot)
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
#443
Decide to buy a Digital angle gauge to try and check my pinion angles, Already had adjustable uppers, but had never bothered to check it.
Had a 4 post hoist at work, but had to wait till retied and do it at home. LOL. Crawling around on floor I found that trans was down 2.1 * and rear was pointed down 3.5*. OOPS. adjusted to up 2.1* and found I was able to move axle housing a touch side to side with adjustable uppers. Tires were hitting exhaust, adjusted to center the diff and road tested. All good. Now onto the next thing I have been putting off for years, LOL.
64 Lemans hardtop 4spd, buckets |
The Following User Says Thank You to Lemans64 For This Useful Post: | ||
#444
Well, I had always thought it was a 221 based on the casting codes. After I pulled the engine and inspected it, I found it to be a 260! I brought this issue with the codes up over on a Ford website, and the best explanation we can come up with is that its possibly a service replacement block.
71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs. 63 LeMans- 69 400 w/ original transaxle. 2.69 gears. |
The Following User Says Thank You to 67drake For This Useful Post: | ||
#445
We recently replaced a customer's exhaust system ('69 GTO) with a Gardner system (awesome quality and fit), and I bought the 2 1/2" system we removed. As time has allowed the past couple of days, I now have it under my '72 Grand Prix.
Next week I'm picking up a built '67 428 from another customer. Hoping it ends up in my '67 GTO. My original WT can go to the next owner when the time comes. |
The Following User Says Thank You to 400 4spd. For This Useful Post: | ||
#446
Getting the 64 GP out of storage ...Saturday....Then my 67 GTO next weekend.
The Following User Says Thank You to MUSLCAH For This Useful Post: | ||
#447
Compared the pics of my block from 10 months ago to vs today.
The Following User Says Thank You to 65 Lamnas For This Useful Post: | ||
#448
Well... I didn't actually do this today, I had a shop do it. Both exhaust manifold gaskets needed replacing on the 455HO in the 'Bandit' Suburban, so I bought a pair of Remflex gaskets and had them installed. It's a nasty job even on a lift. I have to admit to feeling too old to tackle it from a creeper.
I can't complain about the gaskets- the engine was built in '93- 31 years and lord knows how many miles ago! I've put 50,000 miles on it without ever needing to get into the engine. What I did do on my Pontiac today was continue machining stuff to convert the lakester's broken four cylinder hemi Pontiac to a two-cylinder. Rather than source a smaller blower, I'll keep the huge 14-71, but underdrive it a bunch more (about 19% of crank speed) . This requires a 2-stage belt drive, so I'm almost finished machining a jackshaft arrangement. Keeping with the low-budget approach, and using spare parts, I'll only need to buy a couple of belts.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) Last edited by Jack Gifford; 04-20-2024 at 12:52 AM. |
The Following 2 Users Say Thank You to Jack Gifford For This Useful Post: | ||
#449
Relocated bottom shock mount so I can put a bigger tire on.
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
#450
Now I hopefully will be able to shoehorn these custom 8 lugs with 255-70-15s.
#451
Got up at the crack of dawn and headed over to a show in Benicia, CA. Pretty good showing of Pontiacs. Every time I go to one of these big shows where you're locked in all day, I'm reminded me why I like the smaller casual cruise ins better.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5 TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
#452
Quick test fit on one side.. still room to spare!
#453
Did the unthinkable today
Began cloning the Le Mans into a GTO.
The Horror ..
#454
Finally got around to getting the Firebird out of the corner of the garage. First thing was new tires. Before even starting it I removed the wheels and took them to the tire shop for a brand new set of BFG TA Radials. On the way to drop them off I realized that a tire on the truck was starting to separate at the plys. So I got two sets of new tires at once. Anyway, Friday I picked up the van with the Firebird tires in the back and had the 'Bird off of the jack-stands and ready for a test drive. Fired right up and all seems good. Yesterday was the day to shift everything around in the garage to summer mode. I think I'm officially ready for summer.
1969 Firebird 350 convertible, t-5, Carousel Red 2008 Solstice GXP 5speed manual, Sly 2008 Grand Prix, Ink Slate, Winter daily driver 2009 G8, Switchblade Silver, summer daily driver |
#455
Pulled the 8.2 and have been prepping the new rear end for install. Annoyed that Moser left out the axle seals, vent tube and backing plate t-bolts for as much as this thing cost. Debating whether I paint the aluminum cover black or not.
#456
got my windows tinted yesterday w/ ceramic film. Clear on the windshield and the lightest available for the remaining. it's uv blocking which should help reduce interior temps, too.
Long live the Muscle Car Instagram @tuske427 1967 Firebird #BVbird 1967 Firebird 400 4 speed project 1969 Verdoro green GTO (daily) |
The Following 2 Users Say Thank You to Tuske427 For This Useful Post: | ||
#457
Nothing on my Pontiacs, but I did break my Mercury engine and cam in today. NOW, I can focus on my Pontiacs.
Man I was nervous about that HFT break in, but seems OK. It fired instantly, and runs great. Time will tell. Hopefully my 16 year old learned a few things, he’s a gear head, just like my older boys.
71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs. 63 LeMans- 69 400 w/ original transaxle. 2.69 gears. Last edited by 67drake; 04-28-2024 at 09:39 PM. |
The Following 2 Users Say Thank You to 67drake For This Useful Post: | ||
#458
The H/L bezels on the '65 look to be original, and were badly pitted. Found a decent original pair that only has minor pits. Touched up the black paint, and put on new gaskets, which were a bitch to get on and stay, but got 'er done. After aiming the headlights, I put 'em on......they look OK.
The Following 2 Users Say Thank You to 65 Lamnas For This Useful Post: | ||
#459
1st chi-chi cruise of the year with the unprecedented weather I don't believe she has ever been on the road in April!
Only a few diehards and tons of ricers out but still nice to get out of the house.
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 Last edited by kingbuzzo; 04-29-2024 at 12:48 PM. Reason: pic |
The Following 2 Users Say Thank You to kingbuzzo For This Useful Post: | ||
#460
Current Pontiacs - 1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1974 Formula 400 - Ram Air automatic 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
The Following 2 Users Say Thank You to 71GP76TA For This Useful Post: | ||
Thread Tools | |
Display Modes | |
