Compression the same? Heads same except new?
If those are same and basically just the cam change I'll guess 940-950 |
New steel rods? Did you have Aluminum rods previously?
Hi Steve.... That 113 is the intake centerline
117 LSA on the cam. I'll say 1020 HP.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
I thought it read .630 lobe-old eyes! I’ll still say about a grand!
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
I'm not going to post any numbers but it was down 50hp with this cam. I'm going to make a few passes with it and see then put the old cam back in.
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
I ran pretty much that same cam from lsm in mine, ran great. Sucks it didn't work out for you. Good luck this season.
That's disappointing..... Sorry to hear that.
That stinks bro, get a couple of runs to make sure the Dyno wasn't having a bad day
From my standpoint it is hard to say what is happening due to lack of specs.
535 ci 1) 920 HP (what RPM), 278 intake and 292 exhaust on a 114 cl (what LSA), what heads (flow and valve size), what CR 2) 870 HP (what RPM), 284 intake and 306 exhaust on a 113 cl (117 LSA), what heads (flow and valve size), what CR Do run a power adder on this engine? Stan
The Following User Says Thank You to slowbird For This Useful Post: | ||
The new heads are supposed to be the 430 cnc port from Kauffman same as the old heads. Compression is at 14 to 1.
The new heads were bare and everything was transferred from the old heads to the new heads.
At what RPM does the engine my 920 peak HP?
Stan
7200 rpm
Your new cam is virtually the same as my Bullet nitrous cam. I'm running 1.75 rocker ratio. My LSA is 115 installed at 113.
I am going to do a leak down test today after work.
#38
I was going to say what Slowbird did, the heads are the issue.
If your leak down test shows ok then why even go thru the work of putting the motor in the car to make a few passes if the new motor is not even the equal of the old one? I guess your stuck with it for this race season, or do you still have the old heads?
#39
That’s a bummer John! Where did the new heads peak this time? Same dyno as last engine? Can u share any of the dyno sheets maybe there’s something there that will help decipher what happened
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
#40
I would also like to add to Stan's list of questions if you know how much vacuum was made at peak hp and the BSfC numbers from the dyno sheet?
Thread Tools | |
Display Modes | |
