The Stump Puller comes in at 230/236 and the Old Faithful comes in one step higher at 236/242. While both are usually on a 112° LSA, there is enough difference that operating and performance goals should be considered before making a choice. Iron heads and the SP seem to go together well and a little better for tight converters. I know that Dave Bisschop usually recommended the SP for mild builds with iron heads.
Everybody copies everybody on cams and it seems that even the local deli probably carries a reasonable copy of either cam profile -- but I would suspect that SD Performance would still be selling cams even if it will be awhile before his shop is up and running.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon in progress. |
The Following User Says Thank You to lust4speed For This Useful Post: | ||
Butler stocks this cam,
A FWIW, Butler lists those same XE hydraulic roller lobes ground with the 110 lobe separation as above, but also with a 112 & 114 lobe separation.
The Following User Says Thank You to Steve C. For This Useful Post: | ||
I had this cam , I want 112 and more lift .
Butler makes that cam on a 112 and with 1.65 rockers that gets you pretty close.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
The reasons why I want 112 minimum is because I spray 200 using a plate, the intake was going to be a SD CNC ported 71 HO intake ( that probably melted and burned down in his shop last summer , I couldnt get a hold of Dave since)
My heads are SD CNC irons he flowed at 270cfm, and my 461 is brand new built for nitrous . Jakes performance th400 and Continental JH special ( 3200 tight ) converter with anti balloonjng plate. Lust4speed , Dave told me last year he does not want to sell cams anymore. Otherwise I would have ordered from him at the time Peter |
I would trade that cam for a stump puller or the first version of the Old Faithful .
Thread Tools | |
Display Modes | |
