Safety warning welding and brake cleaner. Never mix them!
Here is a link describing the serious health dangers involved when using brake clean on or near areas to be welded. This happened to a guy just like us.
Beware and stay safe. https://www.brewracingframes.com/saf...ces%20phosgene
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
The Following 5 Users Say Thank You to VCho455 For This Useful Post: | ||
Wow - crazy story!! Thanks for posting.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '69 LeMans Vert, 350, #47 heads: work in progress |
I have never understood why most people use Brakeclean as their go to for cleaning oily parts. Its meant for brakes and brake fluid is water based so it will not work as good anyway. CRC Heavy Duty Degreaser works better than carb cleaner for oily parts.
Thanks for posting the warning, I weld a lot. |
YES!!! Burning chlorine producing phosgene! Phosgene is a poisonous gas.
Oh come on, toughen up a little!!!
Please add welding galvanized material too
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
DOT 3 brake fluid is polyethylene glycol based, not water based, if that matters to the discussion.
I warned a guy on another forum about this - he told me to fark off with that chemistry shiat.
I remember a big thread about this years ago on this forum. Im no chemist but i think this warning doesn't apply to non-chlorine brake cleaner in the green can
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
If “brake clean” doesn’t remove grease/oil, why is it commonplace to spray down new rotors with it when doing a brake job?
But yeah…high heat near chlorine? Not good bedfellows.
costs too much |
The Following User Says Thank You to rolling money pits For This Useful Post: | ||
CRC Brakleen is a stellar product for removing oil and grease. Only the red can, not that useless crap in the green. Worse, they sell a red can at Dollar General with a yellow stripe band at the top, it's worse than the green can.
I've never found an alternate brand of brake cleaner tha takes oil film off like the true CRC product. Especially good at cleaning up after repairing engine oil leaks. I appreciate the warnings in this thread, it's news to me and I'll be welding in future. |
The Following User Says Thank You to einstein For This Useful Post: | ||
Now, while it looks like brake fluid might not be purely water based, glycol. There is a huge difference what is in your brake system and your engine. If you put oil in your master cylinder you will basically destroy your brake system. Water, nope. You could flush it out, bleed everything and be OK. You wash brake parts in hot soapy water and never in a oil based solvent tank. Carb cleaner is just better at removing oil and grease than BrakeClean. The sticky dust ect. around your rotors is not oil based. When I was a kid before Brake Clean was around or popular I seen my dad use a alcohol/water mix with a siphon gun and compressed air to clean around brake drums. My father was a master heavy equipment mechanic. |
They sell non chlorinated brake cleaner. It's all I've used for decades.
The Following User Says Thank You to Formulajones For This Useful Post: | ||
Same here.
Brake kleen is definitely a recipe for disaster when welding. I usually wipe down the material I'm welding with acetone before gluing stuff together.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
Back in the day, 1,1,1 Trichloroethane was used as a degreaser in various industries, even for cleaning printed circuit boards. Great stuff when used carefully...gone now because of the chlorine content.
A lot of what we now know as hazardous materials were used freely back in the day....chlorine-based stuff, asbestos, etc. George
I only use Acetone for cleaning before I TIG. It's much safer. Plus, all my brake clean is Non Chlorinated. Ya, Chlorinated did clean a bit better, but the risks are not worth it. Phosgene gas is very similar to Mustard Gas and we all know what that does.
The Following User Says Thank You to zippy For This Useful Post: | ||
The Following User Says Thank You to Ram Air IV Jack For This Useful Post: | ||
Thread Tools | |
Display Modes | |
