Since I have the motor out. I am replacing the brake lines. I am attaching 2 pictures on my 69 fb. I wonder about the brake line routing with regards to the motor mount. I wonder if the passenger side should follow the gas line which kinda goes in between the two parts of the motor mount. Mine currently goes around it. The drivers side I think looks ok. ? Thanks
The Following User Says Thank You to tomaszek For This Useful Post: | ||
Brake line should be with the fuel line running between the motor mount brackets.
Pic of a 69 i have in storage Steve |
The Following User Says Thank You to comanchefirebird For This Useful Post: | ||
Great thanks. That’s helps. What is the thin line that is on the other side of the cross frame towards the front side that has that 90 degree bend and heads down towards the rear on that side?
After looking at my car again. Does the drivers side also go between the mounts. ?
The other line you mentioned is the fuel return line.
No I don't think the brake line goes through the other side motor mount brackets. Will get you a pic of that side tomorrow |
Yes the brake line runs within the 2 piece motor mount on the drivers side as well. Pic attached
Thread Tools | |
Display Modes | |
