#41
Nice.Love the 63s. I had a 63 GP back in late 69. It had std steering, std brakes,no air,am radio,tach, 4spd(broke it 3 times). Put in 65 421 and m40 ,4.10 gears.
The Following User Says Thank You to sdbob For This Useful Post: | ||
#42
Great job bringing this car out of retirement and impressive results!
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
The Following User Says Thank You to OCMDGTO For This Useful Post: | ||
#43
Finally getting the car ready for first test n tune of the new combo that was fired up last year ! https://youtu.be/_RQrUILtbPo
https://www.youtube.com/watch?v=_RQrUILtbPo
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
The Following User Says Thank You to PONTIAC LARRY For This Useful Post: | ||
#44
Nice!
#45
I finally got do one bracket race(without any prior testing) and two test n tune sessions so far in the last week and a half. Basically my 850 DP carb wasn't ready having weird issue at at last minute did a bold or stupid move and grabbed my regular 750 Edelbrock Performer 1407 that was on the stock 389 in the 66 Starchief . Amazingly it actually adjusted mixture it responded and idle much better than the Holley and had excellent throttle response so I was like sure why not. went to Little River for TMCCC race and first time trial it launch really well and did a 1.64 ft basically about average of what it did before and its the same converter (10 inch) but as soon as RPM got over say 4500 it just cut out starved and surged and maybe only saw 5000 rpm the rest of the way down the track like back barrels ran dry could not keep up. Just surging and rpm limited. I am using my 140 gph old RobMc mech pump with 1/2 line and sumped cell so I doubt that was the issue. I went again and tried to just shift it real low like 4500 and keep it under 5000 and it just sat between 4-5k all the way down in all three gears only mustered a 7.82 and 87+ it would not even rev over 5000.. so i won first round cause other guy broke out I spun too it was still hitting hard on the launch though... so bad move on carb choice needs to be seriously reworked if it ever goes on again. fast forward a week I put on my buddys 950HP VS and proved fuel pump was fine this past weekend, it launched a tad softer 1.65 60 ft but dropped 5 tenths to 7.3's at 93 ! clean shifts at 6000 ... seems the single plane no surprise is a tad soft on hit with my tight converter so next up is swapping on the Performer RPM and see how low she can ,,, best it ever ran with old setup was 7.42 with hood removed (heavy) and a quicker 60 ft of 1.61 best with dual plane dual plane (Qjet and iron intake) which was .08 improvement BTW back then taking hood off.. I ran the last two weekends with 80 pounds of plate ballast in trunk to be a more than fair test of power gain not weight savings on the KRE heads vs the iron 16s .... so 7.50 was best with hood before now 7.35 and once I go to the RPM I think it will get down to 7.0-7.1 range maybe well see soon enough. But hey it runs in pump 93 now no more mix with 110 !
it used to go about 89 mph (90 with hood off) so I think its up at least 50 hp https://youtu.be/8MKBKf7apJA?si=eZU0Aoaz1JjFR5P2
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg Last edited by PONTIAC LARRY; 04-23-2024 at 12:37 PM. |
#46
Got to make it out to TNT last night , pretty poor air (DA3500-3000) warm out and humid. Pulled the old heavy hood off to go all out like I did with old combo years ago and also pulled the 80 pounds of ballast I had in trunk (when it ran some 7.35's with hood on ) and together thats about 160 pounds off... bad air and all new best twice last night. First run high water temp like 190 degrees went 7.26@94.1 @ 1.61 all three bests then waiting a while and got to line at a more normal 160 degrees and went better a 7.20@94.7 and a 1.60 60 ft.... new all three bests again ! So thats was satisfying easy win to show simply weight reduction improvement and my race weight like that was only #3600 ! Still going to port match an RPM intake since my converter is so tight and gonna reach towards 7.0's soon enough on pump gas ! no fiberglass no lexan no aluminum wheels no electrical add on's with a stock clutch fan and a old RobMC Mech pump 15x6 steel 215/75R15 15x8 steel wheels 275/60R15 DOT SS MT radials
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg Last edited by PONTIAC LARRY; Today at 09:09 AM. |
Thread Tools | |
Display Modes | |
