Is a 69-72 Grand Prix the same length as a 68-72 GTO ?
End to end of shaft
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Yes. At least for 1970.
The Following User Says Thank You to johnta1 For This Useful Post: | ||
So, is 55.34 center to center of the u-joint
I believe so.
Nice chart! Have F bodies on it? My 78 TA is about 48.5" Just remember also the front yoke can change that dimension. A stock trans yoke and a TH 400 measured different than the MW yoke did.
Good info John, thanks.
Now how far should the yoke be sticking out of the tranny ?
Bottom out the yoke and pull it back by 1” then measure with the car’s full weight on the suspension.
The Following User Says Thank You to b-man For This Useful Post: | ||
![]() Quote:
70 Bird chart:
John,
Is this chart straight out of the dealer's parts department book?? If so, do you know the year of the book? |
It's out of the 1970 service manual.
The 1978 didn't have the lengths. It did have the pinion angles and stuff. (also the 1972 didn't have it I think) I haven't looked at the parts book, yet. ![]()
All good info. Now I'm looking to have a new driveshaft made. Any recommendations ?
Thread Tools | |
Display Modes | |
