Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
hiding a 871 under the hood ...65 gto
i coukd have swore i seen a youtube vid of a guy with an 871 under his gto hood...cant find it...anyone tried to get one to fit under a 65 with 4inch cowl..?
http://performerrpm.myphotoalbum.com/view_album.php? |
“Ain’t no way”
Aretha Franklin
" Darksiders Rule "
The Following 2 Users Say Thank You to misterp266 For This Useful Post: | ||
Maybe a 653.Tom
i set it all up this evening, even without the carb adapters my 4" hood just aint enough
What about electronic injection with custom low-rise throttle bodies?
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926} |
Maybe some side draft carbs, like a Latham setup?
There's this X 400 showcar built to fit under the hood of a 63 GP. It would be a challenge to use 4 sidedraft carbs on a custom built intake to fit the top of a GMC blower. The throttle linkage would be a challenge for sure, but it fits under the stock hood. I believe that blower is a 671, but the snout could be shorter to fit an 871. Notice 7, V belts to drive the blower instead of a cogged belt.
If you wanted a blower under the hood, and were willing to use a Magnuson, or Whipple style blower, and went with electronic FI, it shrinks the package down considerably. This is a 2004-06 late model LS GTO with a Magnuson blower that fits easily under a stock hood. it's not an 871, but it's in a package that is much easier to fit under a stock hood. I didn't find any 65 GTOs with a 871 blower under even a 4 inch bubbled hood when I searched the net. That big chunk of aluminum is going to be difficult to disguise under most any hood after the late 50s cars. I've seen 55-57 chevys with a blower under the hood, but the hood is quite a bit higher than a GTO hood. |
Put a flat hood on your car and cut a big hole in it.
Show your 8-71 to the world, that’s the right way.
The Following User Says Thank You to b-man For This Useful Post: | ||
Wait for someone to make a pontiac screwtype blower system!Tom
is there a way to safely drive in the rain if you do that?
My hobby cars are all used in fair weather, none get driven in the rain whether or not there’s a blower sticking out of the hood.
That’s what my late model modern cars are for, I’d rather one of those get in an accident on a slick road than one of my old cars I have invested a lot of time and money. There are guys who drive old hot rods in every kind of weather with the engine completely exposed so it’s not like you can’t drive in the rain. So as long as you don’t mind the cleaning afterwards have at it. There are dozens of ways to add boost that will package nicely under the hood but a GMC 8-71 roots blower really isn’t one of them. They’re traditionally exposed through a hole in the hood, pretty much meant for displaying as it should be.
One of the reasons to run a roots blower is the awesome look! Don’t hide it! i82much; is there a way to safely drive in the rain if you do that? Take the cheater slicks off and stay out of the throttle!
" Darksiders Rule "
I went with EFI and the BDS intake and fit my 8-71 under the hood. A 4 inch cowl would hide the bug catcher also.
'Retha knows a lot about cars.
At least, compared to most gospel/soul artists. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
A newer TVS 2300/2650 blower would probably come close to fitting if someone had the time/money/energy to either get a manifold cast or sheet metal one made. Would make a crap load more power and have cooler air temps too. A few of us were going to approach Harrop Engineering in Australia as they are now making manifolds for new blowers to go on conventional V8's like SBC/BBC atm. I heard a Pontiac manifold has come up in discussions with their R&D dept, but not sure if it was green lit.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
Pontiac twin screw blower
https://forums.maxperformanceinc.com...92#post6474692
1964 Catalina 2+2 4sp, 421 Tri-power 1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM, Holley EFI, DIS ignition. 1969 GTO 467, Edelbrock 325 CFM, Terminator EFI 1969 Firebird Convertible |
Dont need a hood https://www.youtube.com/shorts/prREX...?feature=share
Thread Tools | |
Display Modes | |
