I don’t believe Doug’s makes a set from what I can see. This is a 66 Catalina with the column shift automatic. I guess my options would be to run long branch manifolds or else switch to a floor shift?
i'll let you know soon if they fit or not
Thanks. I didn’t have a lot of optimism, but tried a set for a 74 Catalina just because I had them laying around and there was way to much contact with the steering box to make them fit.
I'm about to try a set of Doug's headers in my 66 Bonneville. I test fit them before I pulled the engine and everything seemed to be okay, but now I can't remember if I had the shift linkage in or not. Engine should be back in next weekend so I'll know for sure then.
I'm in the process of figuring out what to do for my exhaust system - Tried Ram Air and they were no help. Thinking I'll start with an A-body and extend as needed to make it work. |
Something from Lokar might do the trick? Dunno.
![]() Quote:
Welded up a new exhaust kit from summit and in a rush I didn’t check the steering clearance all the way side to side, so on a sharp left turn I have contact. Wanting to redo it but I’m waiting until I get my header situation figured out before I jump back into tackling it. |
This might actually be exactly what a guy needs. Thanks!
The Following User Says Thank You to kpbrown31 For This Useful Post: | ||
![]() Quote:
![]() Quote:
I plan on putting the engine in this weekend and I'll know what I'm dealing with. Bought a Pypes dual exhaust setup for an A-body as a starting point, but I'm not sure if that gained me much since the tailpipes are different. |
![]() Quote:
Got the engine in and headers installed today. I can confirm Doug's Headers D521 do fit a 66 Bonneville with column shift. Worst part of the install was getting the dipstick bent to clear. This is due to Edelbrock heads though more than the Headers. With stock heads I probably would have been fine.
Luckily I had the engine out to get the dipstick tube aligned. I installed the headers after putting the engine in the car. They sit close to the steering gear, but I did not have to modify or clearance anything. I tested everything before pulling the engine and it looked like transmission cooler lines would need to be re routed. I have not checked those yet. I bought a GTO exhaust as a starting point, but I'm not sure it's going to help much. I did mock up some bends to get past the transmission cross member and think I can make it work, but it will be tight. I'm debating if I should just take the car to an exhaust shop, but it's hard to pass up an opportunity to practice Tig welding a stainless exhaust. |
The Following User Says Thank You to Alizar For This Useful Post: | ||
Thread Tools | |
Display Modes | |
