What size AN line should be used for a remote oil filter setup. 80psi pump, wet sump, thanks
1984 TA, 400 PONTIAC, th-400, 4.10 12 bolt 10.49@ 127mph 1.40 60' R/U Pontiacs in the Park 2006(SAT) R/U Pontiacs in the Park 2007(SUN) |
I use 10 on multiple apps and keep the remote and filter as low as possible.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
The Following User Says Thank You to J.C.you For This Useful Post: | ||
# 10 on mine.
The Following User Says Thank You to Scott Stoneburg For This Useful Post: | ||
agree on at LEAST -10
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
The Following User Says Thank You to Lee For This Useful Post: | ||
Same here, lines off my AMSOIL housing are -10 AN, fittings on my oil thermostat are -10 AN, and fittings on my oil cooler are -10 AN.
1969 Pontiac Firebird |
Looks like 10 it is, thanks
AN12 on mine, less pressure drop if you have long lines
Are you running the lines off a adapter block , or have you done the more work but better way of drilling and taping the block for 1\2" pipe?
If your drilling the block you can go into the return hole with a grinding Burr and put a nice funnel shape taper in there after the threads end. A 6 long Burr will also allow you to get in deep enough to round over the inside bend of that passage where it turns up to the front of the block.
-12 for me but with oil pump and filter up front we had long line lengths
Also enlarged passages in the block etc and oil pressure measured at the front main out through the face of the block (smaller line in pic) Accumulator to enlarged feed hole by dizzy and you can see -10 drains to pan from the back of both heads
Working on going faster (and now staying dry at the same time !!) |
No. 10
GTO George |
Bottom line is, there is only sense is having it as large as the smallest AN fitting any of your hardware should have based on its ID. Otherwise, you are overbuilding it just to have a bottleneck.
![]() Quote:
My HP6 filter housing and oil pump all acept _12 fitting so block adapter was made to suit with main gallery enlarged to suit.
Just piggybacking off this thread as I’m having a hell of a time getting the dual -12 AN hose fittings to fit. They interfere with each other when trying to tighten the lines at the remote housing on the block.
I’m using:
Any suggestions? I know a few board members here have run -12 lines. How did you make it work?
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
James, Wondering if you have enough room to install an adapter on one of the holes to offset each fitting. Something like this. https://www.amazon.ca/Gsinodrs-Fitti...22697296&psc=1
Only other way to spread them apart some is to make your own adapter and have the threaded hole tapped on an angle like 10 to 15 degrees. Very easy to make out of aluminum. I though you were running an IA2 that is already threaded for fittings? But I do understand how close the holes are to each other.
68 Firebird. IA2 block, 505 cu in, E-head, Solid roller 3650 weight. Reid TH400 4:11 gear. 29" slick. Best so far 10.12@133 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. Last edited by chuckies76ta; 04-01-2023 at 07:35 AM. |
any pics of your set up installed? I am going to run clear view with the built in filter and with a moroso accumulator this go thru
QUOTE=R 70 Judge;6417980]Just piggybacking off this thread as I’m having a hell of a time getting the dual -12 AN hose fittings to fit. They interfere with each other when trying to tighten the lines at the remote housing on the block. I’m using:
Any suggestions? I know a few board members here have run -12 lines. How did you make it work?[/QUOTE]
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
I was thinking another way to do it is have a really good Aluminum welder, weld the fittings on for you. I had my Son weld these to a manifold cross-over. There is a thicker Aluminum oil adapter someone sells. https://www.summitracing.com/parts/c...9/make/pontiac
![]() Quote:
FWIW, Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
If you manufacture your own block adapter you do not have to come straight out just like a tapped engine block, the lower fitting can come out of the block adapter at different angles to avoid fitting to fitting problems
I did a 90° turn in the adapter then a 45° elbow at exit, and no this turn did not adversly restrict flow, alot of flow area in the turn
If your not at the table you're on the menu A man who falls for everything stands for nothing. Last edited by Formulas; 04-01-2023 at 09:16 AM. |
![]() Quote:
![]() Quote:
Thread Tools | |
Display Modes | |
