#41
Wow! Those campers are freaking heavy! |
#42
Some friends that do repowers have come up on what they call the "right truck", which is a cummins powered F350. Cummins for the engine, ford for the front suspension.
Those GM 3500HD "cab and chassis" combos have that spacer between the bumper and grille because thats the difference in frame height between a standard frame and an HD. I had a HD with an extended cab, was a 6.5 truck. Sold it to a guy who was gonna repower it with a cummins (that would be damn near indestructible), and it sits to this day exactly where the wrecker delivered it to him. What a shame. An ext cab HD is a bit of a unicorn.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
#43
What a monstrosity!
if a RV company product designer wanted to layout the heaviest most massive Brick of an inbed camper, overload the truck's chassis, have the absolute worst coef of drag & absolutely kill MPG, he succeeded.
#44
I did a little more research. I don't know the Dodge trucks platform. I drive the GMC brand and are more familiar with them. So I came up with the Dodge payload max for Crew cab 4x4 at 6700,5850 or 5590 depending on engine. Crew cab at 6630, 5670 and 5400. Only other Dodge platform in Crew cab 4x2 drive is 7050 pounds.
In my opinion too much weight of camper for truck. One large dip in the road would test this unit. https://www.ramtruck.ca/documents/ra...rochure-en.pdf
#45
When we hauled 5500 lbs with our 97 dodge dually it was pretty much bottomed out on all 4 corners!
In addition to the 97 Dodge dually we also have a 97 F350 dually with a 7.3 Powerstroke. There is basically no difference in load capacity between our Ford and Dodge that I can tell. Both have 5 speeds and 300K miles. The Cummins is turned up and has at least 150 HP on the 7.3. All of us here wish the Ford was a Dodge, the cab and interior much nicer and roomier on the Dodge, and the Powerstroke 7.3 versus the cummins is not in the same league. Right now the 7.3 barely runs and needs $1200 worth of injectors. I don’t think any of the 350 trucks other than these current trucks probably 5 years old or newer would handle those 5K+ Lb campers, and I am pretty skeptical that is a a good idea even on those new trucks that have enough payload rating. We also have a 88 F450 diesel, I think it would hold up those big campers, but it is a 450. It’s suspension and frame is built like a tank. Lol…it also rides like one. It rides so rough empty you get bruises from the lap belt when driving across across rough roads. I get a knot on my head from wearing a ball cap from my head hitting the roof. We have replaced the pop metal bracing under the dash several times because it rides so rough it can’t hold the steering column up, fatigue cracks all over the cab. Ford tough. Lol Last edited by Jay S; 12-20-2022 at 12:29 PM. |
#46
Brands
Before all the regen and def the dream truck was a Cummins Engine "Ram" , Ford Cab and Chassis with a GM interior. I own a 2006 Dodge 2500 Cummins powered megacab since new. Thought about selling it a few times. Its never let me down.
#47
Bent
In the mid to late 90's I used to often replace chassis in the 3500 dually GM for just this reason. This is before they added those reinforcing plates to the chassis.
#48
Problem is, trucks have turned into luxury family sedans with tiny beds. If they’d put the money into making real trucks again instead of all the “frills”, maybe these things wouldn’t happen.
" Darksiders Rule "
#49
First year of hydro formed fully boxed (not C channel) 50 KSI steel IIRC. I would not want a newer RAM Cummins because these have no emission system other than CR injection. No regen, DEF, DOC, Cooled EGR, CAT, or DPF. 2003 only year built that way Both trucks have been great so far mine just passed 165k
1984 RX7 Jim Hand style 455 /200 4R Project car 67 White/Gold GTO 4 speed sold, 1968 GTO 4 speed sold, 1969 GTO auto sold, 68 Firebird 400 4 speed (455) sold, 65 GTO Night Watch Blue 4 speed sold, 64 GTO Nocturne Blue 4 speed sold, 71 GTO Gold auto sold. 1975 Formula 400 auto sold. Hopefully to be restored, H-"O" Racing 73 Trans Am SD 4 speed, Sons 70 Formula 400 auto, and wife's 1974 AMX 360 auto, 1975 Jeep Honcho 4x4, 1965 Buick Special post Last edited by 455dan; 12-29-2022 at 02:42 PM. |
#50
Yeah, try finding an 8’ bed. They’re out there but getting rare.
71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs. ‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. |
#51
Closest GMC 1/2 ton 8' bed is 643 miles away in SoCal (not TX or Denver???). $41k for a 2WD 5.3 work truck But no way it would hold the fat 3 ton camper... |
The Following User Says Thank You to Scarebird For This Useful Post: | ||
#52
I have averaged nearly 30 (29.7 mpg on the interstate) on a 350 mile round trip with my 2003 4wd 2500, 4 dr short box, usually gets 24 to 25. From what I have heard with my friends running new Diesels the DEF system is an improvement over past emissions equipment, and fuel economy is almost up caught up to our older trucks, I have not heard of anything quite as efficient as the 03 truck though. Last edited by Jay S; 12-29-2022 at 07:29 PM. |
The Following User Says Thank You to Jay S For This Useful Post: | ||
#53
Slice and tear fabric off the button. Pry cap off. Bend little tangs. Garbage can. Your skull will thank you for it. And if you didn't slice/stab yourself you'll be a happy... camper. [pun intended] |
#54
Well y’all don’t think the reason why the Chrysler muscle cars are so pricey is because they were great? They’re worth so much because they are rare (because they were built like garbage). Scarcity drives the market. A bit off topic but to
Illustrate they haven’t improved much in the rust department….
462 Yc Block, zero deck Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR Comp Hyd-roller cam,roller lifters,springs ect. 236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6 Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut Powerjection3,T2 manifold, Try-y’s Flowcooler water pump. 71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire. 17x9 YO Honeycombs with Nitto 555's |
#55
Had a 2001 Dodge
2 wheel drive dualy, cummins whit all kinds of performacnes stuff done to it! 2003 Dodge 2 wheel drive dualy cummins 2010 Dodge 3500 4 wheel drive single rear wheel cummins 2016 RAm 2500 4 wheel drive cummins Still driving the Ram 2018 2500 4 wheel drive Cummins All with 8 foot bed! no real problems with any of them! And have towed why more weight than i should have with all of them! Have a new Ram 2023 2500 4 wheel driveCummins on order as I text! Its a GREAT engine in a fair truck!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!! JM2C's! |
The Following User Says Thank You to gtokid1968 For This Useful Post: | ||
#56
The emission equipment on all my cars/trucks seems to mysteriously fall off. I blame it on all the potholes around here.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
#57
72 Luxury Lemans nicely optioned |
#58
A 6.4 hemi reg cab has more payload than a 6.7 cummins dually? That stretches it for me a bit. Especially when it looks like the truck in question is at least a 2500(or whatever ram calls them).
One would have to have better knowledge of the payload and factory specs of the exact truck though to know for sure, But if everything was well within standards warranty should def. kick in. |
#59
I’m gonna side with not covered under warranty. I did not realize that it was not an 8’ bed. Only an idiot would buy a short bed truck to put a camper in. It puts the axle too far forward. It sounds as if the dealer told him it would work. Anything for a sale I guess.
" Darksiders Rule "
#60
MOST crew cab vehicles, if not all, have the shorter bed, DOH!
Not sure if I have ever seen a Ford Crew Cab vehicle ever offered with a 8 foot bed. Post up some pictures and I will learn something. IF one is truly made. Most manufacturers follow the same pattern of cab to bed configurations. Tom V.
Thread Tools | |
Display Modes | |
