#41
I had to use a little sealer on the driver's side and one nut I can't get all the way tight.
#42
Right now I have a set of RARE 2.45" manifolds on order. The ones I have now are 2.313". After everything I've read here, and my own results, It's kinda hard to justify the money for the 2.45" manifolds. As said, I doubt I'll see much difference.
#43
Were you able to fit ram air manifolds on your IAII? Last time I tried they interfered with freeze plugs. Ground freeze plugs down but still too close for comfort. Can’t remember which version of the manifolds we used.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
#44
There was some interference with the casting locating bosses on the sides of the block but not the freeze plugs. He had to grind the bosses down a little.
#45
Not all 9/16" sockets are the same. Couldn't get to one bolt with the 1/2 inch drive socket. Easily get to all 6 bolts with the well worn & visibly slimmer 3/8 drive socket I was given. RARE 2.45" with their hardware & downpipe.
#46
I generally use a 12 point socket to get onto mine as those sockets are a thinner wall. For sure the 6 points won't go on a couple of the nuts. For that to work those pipes have to come down absolutely straight off the manifolds. If they are tilted the slightest bit it makes one or 2 of the nuts impossible.
I will sometimes heat the pipe and then tap a 6 point socket up there just to clearance the pipe a smidge, making things a bit easier. Last edited by Formulajones; 09-17-2022 at 11:58 AM. |
#47
I used socket head bolts & a ball end Allen wrench on my wife’s car. It has those big down pipes from RARE. Don’t know if they still offer them.
I used them cause they seemed to hang down less. https://www.ramairrestoration.com/po...y-headers.html Murf |
#48
With the curve of the head pipe you can;t get a socket on it, or a box end with the 2.5 head pipe and flange.
#49
Did anyone mention Doug's headers in this thread? Work great. Seal great. Pretty much my go to. I'd not install dynaflow or Summit or even Hookers..
#50
that engine masters was pretty awesome. had to laugh about the back pressure comment.
#51
headers
Does anyone make headers for 61 big cars anymore?
#52
Dennis |
The Following User Says Thank You to SD455DJ For This Useful Post: | ||
#53
The mid to late ‘60s D-port log manifold outlets I’ve measured with a caliper were 1.850” on the driver’s side and 2.050” on the passenger side with or without the flapper valve. I’ve opened up the drivers side outlets to match the passenger side, which ends up almost the exact same I.D. as a 2-1/4” head pipe.
The log manifolds aren’t all that bad really: https://forums.maxperformanceinc.com...d.php?t=630943
The Following User Says Thank You to b-man For This Useful Post: | ||
Thread Tools | |
Display Modes | |
