Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
#101
![]() Quote:
What brand? |
#102
I ordered a set of these today for my TA. Price went up a little to $849.95 but I still feel they are a great deal.
Getting excited! Now I need to pick turbos and wastegates ![]()
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#103
let us know how it fits...
My Half AN Injun..... |
The Following User Says Thank You to charlie66 For This Useful Post: | ||
#104
Anyone try these on a 64-67 abody? Very enticing...
#105
Very nice!
The Following User Says Thank You to R 70 Judge For This Useful Post: | ||
#106
Flow wise to me they don’t look any better then factory log style types, in fact looking at them again the read most tube is more restricted.
I do stuff for reasons. |
#107
1) They have a larger flow area vs factory type manifolds.
2) The exhaust PULSES are like marbles moving down a tube therefore the flow with a turbo thru those runners will just be restricted as soon as it enters the turbine portion of the Turbos anyway. 3) I have done a lot of actual dyno testing over the 40 years in my job and have to say I disagree with you on your post. Cannot disagree that the flow area might be different vs individual runners but we are talking feeding turbos, not NA header Tech. Tom V.
#108
They do make the logs in a higher flowing 3” version. They had a set on the shelf they offered to me when I ordered. I chose to stick with the 2 1/2” logs because I’ve seen them fit on a 2nd gen and I didn’t want to chance a hassle with clearance issues.
#109
3' would be over kill. If you ask me you made the right choice. I had the 2.5" log on mine and changed it to a 2 1/4' with no change in power .. I changed to the smaller size because i have a A body style car and there is hardly any room to fit anything bigger in there . I was actually crushing the log into the frame after awhile . lol
#110
Thanks Charlie66 for the info, for others. You are the guy who runs 40 psi of boost occasionally, Right?
And 30 psi quite often on your Pontiac 4 cylinder street racer? With EFI. Tom V.
#111
![]() Quote:
At those higher psi levels o-rings are a must . But i just wanted to let everyone know that 2.5" logs are more then enough ..
#112
I’d like to add power steering to my 70 TA. Has anyone run these turbo manifolds with the CVF Racing serpentine power steering/alternator combo?
Eyeballing it in pictures it seems like it may fit but I’d really like to know for sure before ordering everything. https://www.cvfracing.com/black-pont...ic-water-pump/
#113
That looks like a nice kit. By the looks of it though you will probably have to reroute the drivers V-band to make it work .. Maybe come down and around the pump if there is room?
#114
![]() Quote:
Power steering would be great but I have a feeling it may not be possible with these log manifolds without going to a mini/remote reservoir type PS deal.
#115
You can do this to the header and go under
#116
Looks like you would need a 90 degree bend down and the exhaust pipe may be against the back of the ps pump. Could try the link below, or have CVF make it happen.
https://www.speedwaymotors.com/Compl...gs,379729.html
Systems under stress fail catastrophically |
The Following User Says Thank You to Mo For This Useful Post: | ||
#117
![]() Quote:
Does anyone have a power steering box and pitman arm they want to sell?
#118
R 70 Judge were you ever able to put these turbo manifolds to use?
I was curious to see if anyone has some feedback on how these fit in a stock chassis and if there is interference with accessories etc. |
#119
![]() Quote:
I have a few pictures of the remote pump setup. As you can see there’s ample room for routing piping with how it’s set up. It may be a while before I do the turbo conversion. I’d like to add a Tremec Magnum 6 speed first and that’s a pricey upgrade. My TA was originally a M21 4 speed so I’d like to get a stick back in it.
#120
![]() Quote:
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
The Following 2 Users Say Thank You to ErikW For This Useful Post: | ||
Thread Tools | |
Display Modes | |
