Anyone looking for BBC, Mark Jones turns out tons of stellar builds.
https://www.youtube.com/watch?v=rIIoazbO0d0 BBC 467 10.6 compression Isky 238/248 - 578/608 - 109/105 billet hyd roller AFR 305 heads, performer RPM intake 950 Pro systems carb. 648.9 HP @ 6400 RPM 619 TQ @ 4500 RPM |
I have both, I love both platforms. Pound for pound, dollar for dollar the LS is hard to beat. I have built a few 5.3s and 6.0s that I threw decent cams in, coupled with some headers and a good intake they absolutely move out. Super cheap when compared to a comparable Pontiac build.
Right now I'm in the planning/parts shopping stages of a 455 build. The cost is astronomical compared to the LSs.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
The Following User Says Thank You to 72projectbird For This Useful Post: | ||
Factory hydraulic roller lifters that work... LS for the win!
Seriously, it's hard to overlook the performance capabilities, and the features built in from the factory. Many already mentioned. I think the answer, as usual in comparisons, is "it depends". A friend I work with has a 99 or 00 Camaro. Still has the original cathedral port LS1 heads, intake etc. As a retirement gift to himself he had a 402 built and used the aforementioned original (but ported) heads, intake etc. Made (N/A) 620hp on the dyno, is driven to the track and runs 10.20's @128+. Just imagine building a 400ci Pontiac that makes 620HP, and what it be like to drive, maintain, etc. Brand loyalty is cool, and I get it. But GM, as they well should have with 35 years more experience and all the technological advances that occurred in that time frame built a better mousetrap, no pun intended.
A BBC makes the least amount of horsepower per pound than any other performance engine. They are great for truck pulling.
Lots of folks are bitching about the price of a Thanksgiving dinner this year. I guess they are the ones concerned about a Pontiac costing a few more dollars that an LS engine. I can't relate to buying an old Pontiac and wanting to stuff an LS engine in it. I also can't relate to buying a fourth Gen F-body and wanting to stick a 455 Pontiac in for use as a hot rod street car. I see a lot of money spent on fuel injection (I'm a Holley distributor) and seldom see any advantage over a well set up Q-jet, other than a bunch more money spent on the EFI and you can have a remote starter which helps warm your Muscle Car up before you drive it to work during the winter months. Kinda odd hearing folks vote for the cost saving of building an LS engine and not being bothered by the added expense of fuel injection over a carburetor. |
The Following 3 Users Say Thank You to PAUL K For This Useful Post: | ||
When you happen to line up with an LS car at the track who usually crosses the finish line first, you or the LS powered car?
Good point.... Or can you not hear the lifters ticking over the factory installed piston slap.
But .. once you get out into the rural areas.. who knows. Last edited by pastry_chef; 11-28-2021 at 04:46 PM. |
*watches video* XD
Great crates are pretty cheap.
thompsonmotorsports.net Warranty as well. There may be even better options.. this was just a 4 minute search.. many seem to like thee guys. Forged Piston & Rod Aluminum LS3 Longblock w/ FRANKENSTEIN M311 Heads 800HP Forged aluminum ls3 block Forged pistons and rods STAGE 2Blueprinted New GM aluminum LS3 blockKing m.. $10,568.99 --- Note: Those heads flow 360 @ .600 and 383 @ .700 - |
I used the stock GM harness from the trucks I get my LSs from. I convert them to standalone setups with about $30 worth of relays and a fuse box. Two credits for HP Tuners later and I have an LS up and running. The fuel system is a simple Walbro frame mount and a Corvette regulator.
Mr Bill Klausing had a 63 wagon 4300 lbs with a basic 462 engine and a decent 400 trans/converter that would run 12.06 20 times a day at the track (if you kept putting gas in the thing.) 1963 rear axle, frame sectioned for a bit wider slick. He ran a Tri-Power intake with 3 Holley 2-BBLS, excellent Bracket Car and ran exceptional 60 times for what it was. Just saying, with tuning a Pontiac engine and chassis can be deceptive. Tom V.
E
There's always someone that's faster.
i like old cars because they are old cars, so i have old car things on my old car, like a pontiac engine, a carburetor, a distributor, 15 inch wheels, and fuzzy dice. if someone wants to convert their old car to a hybrid 4 cylinder, put 22’s on it, and listen to Adele cruising down the road while they make a Tik Tok video of it, I don’t mind. I’ll just be cranking up the Van Halen and glad it’s not my car ...
The Following 4 Users Say Thank You to i82much For This Useful Post: | ||
My car also has way more potential in its current state and should run 10.4s/10.5's next year and still get 16mpg
The Following 2 Users Say Thank You to ta man For This Useful Post: | ||
N/A? Street cars I will run them heads up at TMP is they are up for race?
#38
I’m just so sick of the anti-LS crowd. It’s 2021, guys. We need to get over the knuckle-dragging, antiquated ideas of the past and move on. I don’t care if it’s Caitlyn Jenner or a Ram Air IV Trans Am, if someone wants to do major surgery on their prized possession, remove the most important part and replace it with something that is never gonna look right, and expect everyone else to applaud their bravery - we need to do it.
You anti-LS guys sound like a bunch of bigoted jerks! |
#39
Idk, when you add up the cost of a good carb, and a good mechanical pump to feed it, the price difference between them and F.I. isn't that bad. The benefits of a setup like a Holley Sniper far outweigh the additional money spent vs a carb imo.
#40
Your opinion is becoming more popular. A lot of folks don't know how to tune a carburetor.
The Following User Says Thank You to PAUL K For This Useful Post: | ||
Closed Thread |
Thread Tools | |
Display Modes | |
