Old 08-18-2021, 10:21 AM
Tim Corcoran's Avatar
Default Who can set up distributor
Who can you recommend for setting up a distributor proper springs weights curve etc.
Tim Corcoran
Old 08-18-2021, 10:23 AM
pfilean's Avatar
pfilean pfilean is offline
Suntuned - do a search here for him
Old 08-18-2021, 10:42 AM
1968GTO421's Avatar
SUntuned-- http://forums.maxperformanceinc.com/...r.php?u=143447
GTOAA--https://www.gtoaa.org/
Old 08-18-2021, 11:09 AM
73LeMans's Avatar
73LeMans 73LeMans is offline
Shaker455 on this board can get it done too.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
Old 08-18-2021, 11:58 AM
77 TRASHCAN's Avatar
And Cliff
Shut it off
Shut it off
Old 08-18-2021, 05:41 PM
Thanks for the referrals. Sun Tuned is the last guy in the world I would ever let touch any part of my car. The guy might know something about distributors but knows nothing about customer service.
Tim Corcoran
Old 08-18-2021, 07:09 PM
No worries on that pal.
I wouldn’t fix one for you if there was 1500.00 in it for me to start with.
Gladly send that pile of junk somewhere else.
You need help with postage?
Old 08-18-2021, 07:13 PM
694.1 694.1 is offline
Bah ha ha ha!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 08-18-2021, 07:29 PM
wovenweb's Avatar
wovenweb wovenweb is offline
I know Ken is used by a lot of the Buick guys:
https://www.everyday-performance.com/distributors.htm
1971 Pontiac Trans Am Cameo White
1968 Firebird 400 convertible, Verdoro Green w/black top
1970 Buick Skylark Custom convertible(driver) Fire Red
Old 08-18-2021, 08:10 PM
firechicken's Avatar
firechicken firechicken is offline
Just buy a Progressive Ignition distributor and set it up yourself with a smartphone.
Old 08-19-2021, 01:02 AM
Chris65LeMans's Avatar
Thanks for posting that! When I wa shopping for an HEI several years ago, this is something I knew could exist - but I could never find any evidence of it.
Old 08-19-2021, 01:27 AM
ta man ta man is offline
Any reviews on these?
Old 08-19-2021, 01:58 AM
Charlie Brengun's Avatar
Charlie Brengun Charlie Brengun is offline
How long is that continually changing bluetooth protocol on your ever changing smartphone going to work with that distributor which is less likely to receive protocol updates and changes in the same frequency as your smart phone? Nice idea but I'd shy away from them personally..
1968 - Pontiac GTO
The Following User Says Thank You to Charlie Brengun For This Useful Post:
Old 08-19-2021, 08:30 AM
Seems tough to find many reviews but I liked the idea of this enough to buy one and chance it.
Mine has been in use for a couple months now and does everything it's supposed to as advertised.
Longevity is the unfortunate unknown here but if you want infinite control of your timing without getting your hands dirty, this is for you.
Old 08-19-2021, 08:59 AM
MUSLCAH MUSLCAH is offline
Cliff did mine
Old 08-19-2021, 01:25 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
Cliff just got through doing ours as well, I know he has a backlog right now, but most do at this point, and he ended up getting ours done way faster than he even estimated. This makes the second distributor he has done for us,, one HEI and one Points. We have also purchased a couple Qjet rebuild kits along with his recipe/Jets/Needles in the past, always great customer service, he can set you up with Qjet recalibration kit for just about any engine combination out there.
1978 Trans Am
Pump Gas 461 Stroker
Old 08-19-2021, 01:34 PM
nashcar nashcar is offline
Camaro High Performance in Maryland.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
