Old 12-27-2020, 12:58 PM
allenga allenga is offline
Default Borgeson Steering Box Brass Fittings
Morning Guys, I am installing the Borgeson steering box today. You have to use brass inserts for the hose connections. Is there a trick to getting these inserted right so they don't leak. I don't have a lot of specialty tools. Thank you!
ID:	556949   Click image for larger version
Old 12-27-2020, 03:13 PM
NeighborsComplaint's Avatar
There is a specific tool for this:
You could do the same with a piece of aluminum round bar-stock and turn down the pin on the end (lathe or chuck it in a drill and use a file) to fit into the seat. This will keep the the tool centered and prevent the seat from cocking at an angle when driving it in..
You want to drive the seats in straight without damaging the machined sealing surface. Try them first, sometimes they fit tightly, other times you can press them in by hand. Depending on how tightly they fit, you might be able to to tap them in using just a wood dowel as the driver.
Triple Black 1971 GTO
Old 12-27-2020, 03:18 PM
Thank you Sir. I better just get the tool.
Old 12-27-2020, 03:19 PM
Do you know the name of the tool so I can buy one..
Old 12-27-2020, 03:40 PM
RH68 RH68 is offline
First, test fit the brass fittings. I have the same box and they just dropped right in. They were a loose fit in the holes. I made the tool but ended up not needing it.
Old 12-27-2020, 03:46 PM
Thanks will do
Old 12-27-2020, 04:39 PM
Thanks will do
Ok, I am almost home. The box is installed. Now the pitman arm is not flexible enough to get over the top and onto the steering box shaft. I just replaced all the steering components and she is pretty tight. Is there a trick to get the pitman arm on the steering box without having to take everything apart. Thank you
ID:	556967   Click image for larger version
Old 12-27-2020, 05:02 PM
Formula8's Avatar
Formula8 Formula8 is offline
I needed those adapters when I was running a third gen steering box and they dropped in. Relative to the pitman arm issue, I have always separated the pitman from the drag link first then pulled the pitman off prior to removing the box. I then install the box, then the pitman, then reattach the drag link.
You may have to separate drivers side tie rod as well but I don't remember as I have a puller that makes quick work of all of the tapered joint stuff.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
The Following User Says Thank You to Formula8 For This Useful Post:
Old 12-27-2020, 07:55 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
You either have to remove the pitman from the steering link or undue everything you did putting the gear on and pivot it up to get it in the pitman
The Following User Says Thank You to ponchjoe For This Useful Post:
Old 12-28-2020, 08:10 PM
Ok, back in business. I had to take the idler and the other end of pitman arm off.
I have the brass fittings in. The just fell in the holes. Not sure why Borgeson says they have to be tapped in.
Wondering, can I just torque down the hoses as normal with the brass fittings.
Old 12-28-2020, 08:47 PM
Yes, just tighten the hoses as normal. The brass adapters just get squeezed between the hoses and box.
