Old 04-23-2020, 09:08 AM
62cat's Avatar
62cat 62cat is offline
Default Update 4/23/2020
The full trunk floor came. Installation wasn't bad the fit was real good. Replaced left side inner and outer wheelhouse also. The rear body panel also showed up. Fit and quality is real good. Waiting on left 1/4 panel to show up. Had to get a 67 as 66 is not available yet or ever who knows. After that's installed this goat is solid again. Its amazing how many spot welds are not penetrated from factory on these cars.
ID:	538187   Click image for larger version
ID:	538188   Click image for larger version
ID:	538189   Click image for larger version
Old 04-23-2020, 09:16 AM
62cat's Avatar
Default Update 4/23/2020 Part 2
Rebuilt the rusted end of right 1/4 panel. Going to lead this area. Finished sail panel area. Making sure i have nice lines.
ID:	538191   Click image for larger version
ID:	538192   Click image for larger version
ID:	538193   Click image for larger version
ID:	538194   Click image for larger version
Old 04-23-2020, 09:19 AM
RedDirtRoad RedDirtRoad is offline
Real nice work going on.
Its nice to see another Jersey guy getting into rebuilding a GTO.
How did you like replacing the inner wheel house? I bought 2 new inners but cut what I needed and didnt want to open up a whole can of worms getting into the upper inner structure I see you tackled that no problem
Keep up the great work
Old 04-23-2020, 09:22 AM
Trunk gaps and especially the corners look really good and level with the quarters
Nice fitment
Old 04-23-2020, 09:25 AM
62cat's Avatar
Default Update 4/23/2020 Part 3
A few pics of it back on the ground. Starting to look like a car again. 95% sure I am painting it the original Barrier Blue it was born with. Kicking around and pretty sure I am going to put a red interior in it over the original black. I think it will certainly pop. My neighbor was throwing out those corvette style 15x9 rally wheels so i threw them on lots of room in the 66 fender well. Still have to get at least a better passenger door or both.
ID:	538196   Click image for larger version
Old 04-23-2020, 09:28 AM
Keith Seymore's Avatar
Agree - looks like you have a good plan, and are making good progress.
15x8
K
'63 LeMans Convertible
'63 Grand Prix
Old 04-23-2020, 09:54 AM
62cat's Avatar
Default Wheeels
15x8
K
I thought the same thing when my neighbor said 15x9. I measured they are 9 wide. They look aftermarket though. 20-30 years ago i parted nicer cars. With the parts available kind of makes it easy to put them back together today. Thanks for the encouragement Keith.
Old 04-23-2020, 10:03 AM
62cat's Avatar
Nice fitment
Wheel houses fit real nice. Wanted to save the inner but car was in a wreck on left side and it was a mess. A lot of drilling to get them out and even though they are different brands Goodmark outer AMD inner they fit really well. Amazing how much better the aftermarket sheet metal has gotten. I like nice even gaps. 22 years doing heavy collision really helps. I used to enjoy the heavy wrecks when i worked in the collision industry and i guess i still do. Thanks for encouragement.
Old 04-23-2020, 10:51 AM
ZeGermanHam's Avatar
Looking really nice! Your pace is impressive.
1998 BMW 328is (track rat)
Old 04-23-2020, 02:43 PM
geeteeohguy's Avatar
Excellent workmanship and progress. Although not standard, I agree that a red interior with the Barrier Blue will be a knockout. Especially if you install red fender liners or paint the wheel houses red. Red pinstripe on the car, as well as redline tires.....super sharp, IMO.
Jeff
Old 04-24-2020, 07:40 AM
gtospieg gtospieg is offline
What company made your trunk floor? Did it have the correct contours at the rear under the tail panel?(the one I got from Ames sticks out at the outer corners and will need to be trimmed to fit the tail panel properly.) Thanks...your project looks great.
The Following User Says Thank You to gtospieg For This Useful Post:
Old 04-27-2020, 07:59 AM
62cat's Avatar
Default Floor
Got mine through Ames also. Fits perfectly. How long ago did you get yours?
Old 04-27-2020, 05:06 PM
I got mine from Ames in November 2018. It appears as though it will fit everywhere except at the tailpanel. I test fit it and it is too long in the rear corners, by a bunch. Do they expect me to cut it to fit. Has anyone else had a similar issue?
Old 04-27-2020, 07:35 PM
I believe that's because the pan is made for an A-body, but not necessarily a Pontiac.
Old 05-11-2020, 08:50 AM
62cat's Avatar
Default Trunk
The new version is made for Pontiac yours is probably the earlier version which has to be modified to fit.
Old 05-11-2020, 05:49 PM
Thanks 62cat...where did you get this info? When I questioned Ames they were no help.
Old 05-11-2020, 08:21 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Don't forget the red brake drums!
  #38
Old 05-12-2020, 12:56 PM
62cat's Avatar
Default Ames description.
K149WH
Description 1966-67 ONE-PIECE TRUNK FLOOR (RE)
Net Comments EXISTING REAR PANEL IS NOW PONTIAC SPECIFIC
From Ames site in the description. Hope this helps.
  #39
Old 05-12-2020, 12:57 PM
62cat's Avatar
Default Red
Going to have to be calipers. more than likely going 4 wheel discs.
  #40
Old 05-12-2020, 06:05 PM
Thanks 62cat...will call again and see if I can exchange.
