Hi all,
I am in need of a measurement- I need the distance from either: A) The top of the assembled air cleaner lid to the mounting flange of the carburetor/intake manifold junction --OR-- B) The top of the assembled air cleaner lid to the center of one of the intake manifold to cylinder head mounting bolts-- Please indicate which bolt. The reason for this is to compare a 4150-style throttle body vs. a 4150 elbow adapter and a 102mm throttle body. Thanks!
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
Also, if you happen to know how much clearance you have above the air cleaner to the hood, that’d be great too!
Bump
Not much... i have a stock 76 (and a 69..believe the same height )intake, 76 carb and stock air cleaner assembly, but not in car or on engine. What can I measure for you?
I had an RPM intake on it and there was not enough room for an air filter that cleared hood well, and didn't mess with the carb funtion with it on. |
What I'm trying to determine is if:
A) I go with a 90* elbow-to-4150 adapter and a barrel-style throttle body -OR- B) A 4150 throttle body and a traditional air cleaner. This is on a Hurricane/Tomahawk EFI intake-- I believe it's a copy of a Holley Street Dominator- that I'm hoping is close to stock height for carb/TB mounting. I'm trying to fit this under the hood of a 74 Formula, so space is at a major premium. So, if you could place a straight edge on the top of the air cleaner, then measure from the top of A/C to the carb/manifold mounting flange; and also from the top of the A/C to the center of one of the intake manifold mounting bolt holes, then let me know which bolt hole you measured-- that would be a tremendous help! ![]()
There you go ....7 and 15 little lines.
-Both Intake’s are the same height ~70 and 76 egr , carbflange to a bolt hole - ~3 1/4” for q jet -1/4” gasket - 2 1/8” air filter housing, air horn to top of lid peak, wing nut/ stud is recessed below top LMK if you need anything else, I took a bunch of measurements and pics |
That's perfect!
Thank you!!
Thread Tools | |
Display Modes | |
