#81
I'm sure you think anyone not milking cows is delusional. So smarty pants you tell me how much does a state of the art ex coughlin prostock weigh complete with titanium hardware (nuts and bolts everywhere) carbon fiber body, carbon fiber brakes etc. You highlighting what a moron you are. I've seen the car. Its triple throw down bad. and light. get the weight. cause it matters.
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#82
He is using the weather corrected numbers. If you use the weather adjusted ET and try it, it would probably be closer. (that one you used is for STP) Stan's calculations are also much more elaborate, so would be more accurate. Mine is for a ball-park figure. (and for quick use)
#83
my god you're a a real gem
#84
I think Stan's numbers look pretty damn GOOD to me!
GTO George |
#85
KRE's MR-1 THE BEST Aftermarket Pontiac Block Bar NONE!
Hey, I still want to know why you believe this. I've asked several times, if I missed the answer I apologize in advance. SD |
#86
I was kinda curious about that myself!
If its one thing I know, its..... Uhhh I forgot . What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!! |
#87
Now,that's just over the line.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#88
How much ballast can a pro stocker legally add?
Mike McCarty You can drop the line, but you'll never kill the spirit! Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far |
#89
If I read it right, anything faster than 8.49 is 250 lbs.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
#90
That's probably ET racing.
Here's the Pro Stock from rulebook:
#91
Back to topic. As much as I like to try and antagonize Jack (all in fun) my prediction is: A LOT of horsepower and very fast! 1113 hp.
#92
So all of these calculator are just guesses. So please do explain how from et, mph, and weight you can get a HP number that is anything other than a WAG? Stan
#93
and by the way a wag is all that is possible with missing info. get the weight and we can move on to a swag. If we have weight, et, and hp we can remove one and reasonably calculate its value. We were trying to figure out how much the kre boys are making with a warp 6 535. WE CANNOT FIGURE THAT WITH ONLY ONE KNOWN DATA POINT! Please i'm trying to be nice here but dang it you're doing this on purpose. No where did jack say he would make 1300. You did. Don't think for a minute that what you are really doing is not obvious. Some ill planned form of race head "Social Justice" Lets set the bar "for" jack so high it unreasonable then call him a failure for not getting there, EVEN IF HE BUILDS A STOUT COMBO THAT IS IMPRESSIVE. You guys and your retarded nonsense is laughable. I'm sure you see it as retribution for him being mean to another head. The difference is they made the claims not him. And there are still no takers on that front that can come even close to the same performance as even the ehead let alone tigers, and kre high ports. cheers
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. Last edited by mike leech; 03-29-2014 at 01:04 PM. |
#94
I read that and it looks like it tells you how much the max is in certain spots on the chassis. It really doesn't give a max there. It refers you to the general rules where it says max is 250 if under 8.50. I don't know....it's a little confusing.
#95
Hard to say what KRE's car weighs. I know my chassis car weighs 1500. Although it isn't finished, it's a rolling chassis with a heavy Dana 60 rearend and is mild steel not chromoly. I weighed it with a powerglide case, 428 block with iron heads, headers. Basically it's missing wiring, a rotating assembly and about 85lbs worth of transmission internals. The iron heads make up for some of that compared to aluminum heads. I think finished it will come in around 2100 lbs maybe less since I have to put a new chassis under it and it will be chromoly.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion Last edited by Probird; 03-29-2014 at 02:15 PM. |
#96
Clearly a state of the art pro stock all chrome moly cage with a carbon fiber body and carbon fiber interior with titanium hardware would be significantly lighter. Not to mention a small driver.
#97
The only person locked into 2300 lbs is you. I have posted HP numbers based on 2000 lb. (your estimate of its eight), 2100 lbs, and 2200 lbs. I along with Aaron believe that Lil Jack's engine should be able to make 1300 N/A HP. When reminded that Nitrous engines are not all-out engines like N/A engines I did post a revised N/A HP number. In a all-out 400 ci engine with a smaller bore (ie smaller intake valve) spacing Visner has made around 1180 HP. I know 120 HP more from 141 ci is asking allot. When all else fails, you go back to the same old cylinder head BS. I do not know if it is lack of reading comprehension, or bad memory on your part, or just wanting to be argumentative. One more time. I have no cylinder preference Stan What cylinder head is this?
#98
Stan Stan Stan. I said 2000 ish. Comparing jacks to An Existing and continually refined pro stock effort only further highlights your bias and inexperience. Have you or Arron(no disrespect to him) ever built a 1300,1100, or 1000 hp NA anything? While you're discussing how easy it is?
And ps. How many more times are you going to post that picture of an engine you had little to do with? Could you please just count how many more times you want to and just make one final post with that many pictures in it?
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. Last edited by mike leech; 03-29-2014 at 03:05 PM. |
#99
I gotta get to Norwalk this year!
#100
I do not understand Leecheese. How much different is "2000 ish" than 2000. Maybe I am the one not has the Reading Comprehensive problem. But I am sure I saw Lil Jack talking about how he had the "A Team" building his engine not Stan Weiss. The only one using the word easy is you. Again lack of comprehension on your part. It is not about who built the engine, but cylinder preferences. I will post that picture as many times as it takes for you to comprehend. Which means I will be posting that picture a lot. Stan
Thread Tools | |
Display Modes | |
