I've just about got my 66 GTO together but I have no taillights at all. The car was apart for about 2 yearswhile being restored. I installed a new tail harness and I have no tails except for licence plate lamp. I hooked a meter up to the harness at the connector. Brown wire is hot when head lamp switch is on yellow and green both test good with left or right signal activated. So the problem is the tail harness. Is there a ground I might be missing or something to look for? Any help would be greatly appreciated.
The grounds for your tail lights are the tail light housings. Make sure your housings socket openings are clean, and that the tangs on the sockets, are making good contact to housings. Some add extra ground wires to the sockets so as to double the ground, as the tangs get weak over time .
Scott If you always do what you always did ![]() You always get what you always got ![]() ![]() |
Make sure the connectors snap tight and of course check for a bad ground. Electrical problems are a major pain. Good luck!
The trunk has been painted as well as the taillight housings. Perhaps the paint is causing a bad ground. I'll check it out after work and let you know. Thanks.
I ended up running seperate ground wires to my housings to make sure mine work all the time. Make sure your getting 12v thru the wires first. If you are then it's the grounding.
Never poke a bear with a stick! |
![]() Quote:
Scott
I found the problem. Paint on the housing studs causing bad ground. Thanks for all your help.
Thread Tools | |
Display Modes | |
