![]() Quote:
have you ever read the HO or SD threads in the 70-73 firebird section?they were talking about how the HO455 out powered the SD on the dyno.one of the guru's that really knows this stuff talked about how the smaller cam in the HO was better for the compressions those 2 motors were running.the 2801 is a close match to the HO cam with more lift where the 2802 is close to the cam in the SD with more lift.by the way,HO's came with 3.42-3.73 stick or 3.08-3.42 auto,and the SD came with 3.42 stick and 3.08-3.42 auto.either one could blow the tires off on the street,the 455's have that much torque. just ran both thru the desktop dyno with 8.2 compression;2801 cam made 482lbs torque at 2500,the 2802 was 444 at 2500.2801 made 357 hp at 4500,where the 2802 made 373 at 5000.in round numbers the 2801 had about 30+ lb more torque across the board at a lower rpm than the 2802,where the 2802 had 15 more hp at a higher rpm.with the 2.73 gears he will be using the lower rpm's more than the higher.thats why they talk about making the whole combo work together.
FREEDOM ISN'T FREE BUT WORTH FIGHTING FOR |
![]() Quote:
FWIW, I also ran this car with 3.55 gears and surprisingly the 60 foot, ET and MPH all stayed the same! The revs on the highway were a little more annoying though. ![]()
1966 GTO 1969 Lemans Convertible- F.A.S.T. legal family cruiser. 12.59 on G70-14 Polyglas tires. 1.78 60' 1969 Bonneville Safari- cross country family cruiser. . 1979 Trans Am 400, 4-speed, 4 wheel disc. View from the drivers seat racing down Atco Raceway- http://www.youtube.com/watch?v=GhYDMdOEC7A Ride along in the other lane-http://www.youtube.com/watch?v=mIzgpLtF_uw |
Warbird.. No i havnt read that post.. Ive run the 2801 in a 350 just seems bizzare that a 2802 is to much for a 455.. The 2801 wasnt much in my 350.. Oh well
Our 2+2 with the 2802 cam was also in an HPP shootout (September 2007). Here's the link: http://www.mickbatson.com/images/HPP/HPP_Article.html
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon. |
![]() Quote:
my 2802 had a nice lope to the idle,more than likely the 2801 will be dead smooth,so that may be what makes up his mind. by the way,what compression,gears and such were you running in the 350?i think that is close to the cam the factory ran in the 350 HO's.
I've been trying to stay away from 455z4ever posts because he seems to prefer I do such,but I just cant let some info pass without discussion.
Further I am certain they are not looking at the complete specs & valve events on those two cams,and by repeating that common misunderstanding they are leading anybody who bothers to listen to them astray. With 10° less total overlap and an intake closing event that is 14° earlier than the 068 cam,the 2801 cam is nowhere near the 068 cam in terms of "size". Even the 067 cam bests the 2801 on those same aspects,but only by a very slim margin,the 067 has only 1° more total overlap,and the intake closes about 6° later than the 2801. So truth be told the 2801 is much more closely comparable to the 067 cam than it is to the 068 cam,I would call the 2801 cam a good standard 4bbl style replacement cam in lieu of the 067,but I would hesitate to call it a performance cam myself. You cant just look at the advertised and .050" durations and decide you "know" any given cam,it just does'nt work that way,a cam designer can use many tricks to make those numbers almost meaningless,whether they intend to do so or not. Same deal with LSA's relationship in all this. And lift,well dont even get me started... And do note the same sort of disparity exists when comparing the 2802 cam to the factory SD cam. (BTW the SD uses the same specs as the 744 RA/MT cam uses,except the SD cam uses the smaller distributor gear) The 2802 (59°) is down 17° of total overlap to the SD/744 cam (76°). And the 2802 intake closes 13.5° earlier than the SD/744 cam closes it's intake valve. The 2802 does'nt even best the 068 in those two respects (total O/L & IC/ABDC),but that 2802 cam is in fact a much closer "comparison" to the 068 cam than the 2801 cam is. So you should understand why I must debate the validity of comparisons of those "factory" cams to those summit "clone" cams,the common specs on all those cams are very misleading for the less studious consumers/users. In the factory cam terms,each jump up of roughly 10° (+/-) or so of total overlap represents the next "step-up" in terms of performance levels. Factory cam total overlap: 067/4bbl = 54° 068/H-O = 63° 744/S-D = 76° 041/RAIV = 87° The 2810 has 53° total overlap. The 2802 has 59° total overlap. And by looking at the valve timing events and overlap numbers instead of the "popular" advertised specs that is all much easier to see. Now dont get me wrong,I'm not saying overlap is everything here,but ignoring it is certainly not a wise idea either,the factory cam designers certainly did'nt ignore it,fact is they used it to their advantage,the way the factory pontiac heads were designed these engines are very overlap responsive. And valve timing events show a lot as well,and a fella must be sure to look not only at the .050" valve events,but the "advertised" valve events as well. Quote:
The differences between the 068/H-O cam and the 744/SD cam are indeed valid,the guru was likely aware of this,and one can easily see why the slightly milder H-O cam would outperform the "bigger" SD cam,especially in a lower compression ratio engine,of which neither cam was designed or optimized for. Both cams used wide LSA's for broad powerbands,so neither cam likely gave up a bunch in terms of overall RPM range,so this is just another example of a "torquey" powerband upstaging a more "peaky" powerband. Simply put the added 13° of overlap and a few degrees more duration @ .050" with the 744 based SD cam was just not enough to overcome the DCR boost the earlier intake closing the 068/H-O cam added to those H-O engines,with a bit more static compression ratio and a higher RPM operating range,that situation would have surely changed. Now some thoughts on the topic at hand. I would expect the 2802 to have a slight edge over the 068 cam in a lower compression engine,mostly because the 2802 closes the intake earlier and does'nt give up all that much in the overlap department compared to the 068 cam,sure the 2801 cam will "feel" better at lower RPM's compared to those two "bigger" cams,but it almost certainly will not match those two "bigger" cams in peak output,and likely will result in a slower ET than the 2802 or 068 cams would have,especially when the drivelines are optimized for each given cam. I would use the 2802 without any serious concerns in a lower compression,moderately geared 455 based combo,were it a 400,I would likely take a little more time with that decision. The 744 style cams with the added overlap and later IC events would make even more power than those two cams (2802/068),but almost certainly the 744 based engine combo would need/benefit from a slight bit more compression ratio,more gear and a mild stall convertor for best results. If ya'll wanna see the valve events for any/all these cams,feel free to lemme know,I'll take some time and type them out for you guys to peruse. HTH. |
SC - at what lift points are you comparing your overlap figures?
If you are using the advertised duration numbers, are you sure that Pontiac and Summit rate their advertised durations at the same lift? If they are not the same, how does that affect the comparison? Isn't the fact that manufacturers never standardized on a lift point for advertised duration numbers the reason we use the .050" lift point as a standard among all cams? Yes, I know that only looking at .050" numbers has it's problems as well, especially since Pontiacs are very responsive to valve acceleration rates off the seat below .050" lift. And, while I agree with you that overlap and intake closing events are very important in how the cam will behave, you can't simply discount duration, especially not when we're talking differences of 10 degrees or more at .050". The reason I blabber so is that seeing how the 2802 actually performs in engines and comparing it to the 068, I would say that the 2802 is indeed more similar to the 744 than the 068. The 068 has a pretty dead smooth idle with excellent torque right off idle and doesn't pull hard past about 4800-5000 RPM depending on the size of the engine whereas the 2802 has a bit of attitude to the idle, is softer on the bottom end and will pull to 5000+. In short, if we have to compare the summit cams to factory cams then I would agree that the 2801 is similar to the 068 in performance and the 2802 is similar to the 744, regardless of what the numbers on paper may say. ![]() ![]() ![]() ![]()
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
Throw another variable in the mix, these valve lifts haven't been brought up in reference to duration and how it affects cam charateristics.
valve lifts: pontiac cams(excluding the RA4) = .406" lift summit 2801 = 0.442 int./0.465 exh. lift summit 2802 = 0.465 int./0.488 exh. lift
Home of WFO Hyperformance Shaker induction. Last edited by Larry Navarro; 02-12-2008 at 08:51 AM. |
hi SC.not worried about my toes,they get stepped on all the time
![]() when it comes to my engines i have a couple guys i call and use their ideas.it's funny,but so far they are coming up with bigger cams than i thought would work.i'm using more compression,flow,and gears in my cars thou. back to the question he asked,which cam do you think would work better in a 8.2 compression 455-2.73 gears-auto car?the 2802 or the 2801?
I would "at least" put a numerically higher rear gear in. IE 3:23 or 3:42 and I would get a higher stall converter as soon as I could- I ran a 10" nitrous converter once, but it really didn't stall that much- I think most converters are liberally rated on the high side.
Just my .02. David |
My '67 Lemans has the 2802 in a 462, street ported SD Performance 6X heads shaved to 9.5 compression, Hughes GM2500 converter, 3.23, locker. Idles nice with just a hint of lope, pulls nice to 5400 rpm, runs 12.8's.
[insert witty signature here] |
![]() Quote:
Hmmm.. the proverbial 'can of worms" as always
![]() P.S. thanks Warbird for the "dyno time" ![]() |
Hey Warbird... Can you advance that 2802 cam 4 degrees in your dyno sim and post those results?
hp-369@4500-368@5000......torque-452@2500-456@3000-452@5000. (+4 degrees)
hp-386@4500-389@5000......torque-468...-470@5000.these numbers are if you bump the compression up to 9.0. your numbers may not be exact to this but it should show the difference that changes make.you lose a little hp but gain torque when you advance the cam.this was run on a 455-stock 6X heads-dual plane intake-800cfm carb-small tube headers with open exhaust-2802 cam advanced 4 degrees-8.2 compression-then 9.0 compression. it would not be cheap,but you could always run an overdrive trans to keep the 2.73 gears but have the better first gear.
I agrree with SC on the timing difference, at first glance the summit cams seem the same as factory but not really.
Real world experience: 2802 in a 428 9-1 in a big fat 63 with 2.69 gears. th400/stock convertor No lack of low end according to the shredded Michelins. Later swapped to GM2500 convertor and 3.64 gears. That really brought it togather. I would have no hesitaion about using a 2802 in a street 455. Likewise a factory spec 068 (Melling?) I have another 455 with a factory 041 and would not want that cam in any street car. Not even if propped up with leaky lifters. (It would have been fun when I was young and didnt know any better) LOL |
![]() Quote:
#38
I know this might be a dumb question but what brand of cam are guys talking about?
#39
![]() Quote:
no,not dumb.summit.summit sells 3 cams with their brand on them,2800,2801,2802.i've ran a couple that worked pretty good.not sure who grinds them.
#40
![]() Quote:
![]() I really dont even know why I bothered to get involved in this topic??? ![]() I could give a rats a** about these summit or factory cams,,,to many better choices out there to loose any time arguing these cams merits. ![]() Use whatever ya'll choose,makes no difference to me... ![]() ![]() |
Thread Tools | |
Display Modes | |
