Old 02-04-2022, 09:41 PM
Gach's Avatar
Gach Gach is offline
Default What will it make ?
This is going to be pump gas motor,
Old 02-04-2022, 09:43 PM
Gach's Avatar
Heads are BES Victor heads ( E-Heads ) they flow 480 cfm.
IA11 block 4.250 stroke Crower billet crank. 505 ci.
BME aluminum rods.
Compression will be 11.5
Kauffman…Polar Wind intake
Cam 264/276 @ .050 with 770 lift on 112 lobe
Old 02-04-2022, 10:17 PM
Stan Weiss's Avatar
Lou,
What do the heads flow @ .750" lift?
sTAN
Pontiac Pump Gas List
Old 02-04-2022, 10:22 PM
Gach's Avatar
I’m waiting for that info from BES.
Old 02-04-2022, 10:27 PM
Dragncar Dragncar is offline
Interesting BES used a Polar Wind ? Is it highly modified ?. PP heads ?
Old 02-04-2022, 10:28 PM
Old 02-04-2022, 10:29 PM
25stevem's Avatar
25stevem 25stevem is offline
Your posting in the street section so is that how the car this motor is going in will be used 90% of the time?
Can your chosen intake manifold support and ideally exceed the level of air flow that the heads are capable of?
Are you saying that BES , a company capable of getting flow numbers like that out of those heads cant tell you how much power this motor combo will make, or you don’t believe what you have been told by them?
If so then does it really matter that the motor will make 800 or more hp?
Will you really have the car set up to apply that much power on the street?
I do stuff for reasons.
Old 02-04-2022, 10:48 PM
Stan Weiss's Avatar
The what will it make question is posted on PY many times. Sometimes the engine is not done yet other times the person has dyno sheet in hand.
Stan
PS 950 HP @ 7500+ RPM
Old 02-04-2022, 10:58 PM
Scott Stoneburg's Avatar
I'll guess 900 HP and 750 lb/ft torque. That's assuming that the intake has been ported to match the heads performance. How soon till it's together? What carb will you be using?
Old 02-04-2022, 11:27 PM
77 TRASHCAN's Avatar
It oughta make 900 HP, just shift’n into Drive
Shut it off
Shut it off
Old 02-04-2022, 11:56 PM
Gach's Avatar
Yes Street cruiser, but definitely will be raced.
The price includes the Polar Wind port match to the heads, no other port work needed that’s what he said.
Stan… hit nail on the head that’s exactly what BES quoted
The car will definitely handle the power. It’s a 4 link suspension.
The Victor even though it’s fully ported won’t work, 2 things I’m guessing not enough plenum area, and fact the ports on the BES Victor heads are much taller
Scott….4 to 5 months to get the heads because they are busy. I have written quote from them.
Maybe we can make Norwalk
Old 02-05-2022, 12:01 AM
Gach's Avatar
The carb, Pro System I’ve had really good luck with Patrick. By the way he’s a Pontiac guy. I Don’t think most of us knew that.
Old 02-05-2022, 12:24 AM
Gach's Avatar
Thing is, I was blown away when he said they’ flow 480 cfm, I’m like that’s BBC flow numbers, I expect him to say 420-440 cfm. They do how ever have a 440 port. But recommended we go with the 480 port. That’s kind of why I posted this, kind of to let guys know, who may be thinking on going this root.
Wide ports are out of the question and I asked about they High Ports..basically the Victor is their exclusive head they developed. I’m thinking High Port just need to much work.
Old 02-05-2022, 01:29 AM
Is BES working with Butler and all those Pro Ports that basically got given to them ?
Been waiting for something to come of it.
Cam looks very familiar. 1.75 rocker would get .770 lift.
Old 02-05-2022, 01:38 AM
R 70 Judge's Avatar
That is one heck of a build!
Are you using the Sims roller cam plate? Which lifters? Did you already have the cam or was it ground for this build?
I'll guess an honest 890 hp
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Old 02-05-2022, 07:14 AM
25stevem's Avatar
Lou, if you do not have at least a 1150 dominator ( if you’re not going FI ) to feed this combo , then now’ s the time!
Something like a AED 1450 Dom maybe with high gain boosters comes to mind.
If your stuck with a intake that’s lacking in Plenum volume due to hood clearance concerns then a slightly too big carb or throttle body will help to pressurize the plenum better in terms of top end HP if that’s your main consideration.
Old 02-05-2022, 07:36 AM
chuckies76ta's Avatar
I'm just a novice here , but not knowing what the heads flow at .770 lift is just that. Is Cam not on the small side for heads that will flow that high? It should at least make close to 1000 HP. That Polar intake is huge.
I'm going to go with something around 880 hp 725 torque.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick.
Best so far 9.95@134 mph. 1.43 60 ft.
Old 02-05-2022, 09:05 AM
Gary H's Avatar
Gary H Gary H is offline
Sounds like the heads are capable of over 1000 HP, but the moderate cam and compression ratio will probably keep it slightly under 900 horsepower. I'll say 875 HP. Looks like a great build!
Old 02-05-2022, 09:13 AM
the moderate compression has less HP lost from compression losses.
Im allowed to guess; 580 HP at 5250 rpm, and 900 hp at 7600 rpm
Old 02-05-2022, 12:53 PM
Gach's Avatar
Carb is a Pro System 1230 cfm. The cam I have is 770 with 1.7 rocker shaft, I can go with 1.8 = 830 with that he said 875 hp or 1.9 would be 880 lift. Still leave the 264/276 duration. Keep it more street able. Right now have the Cloys timing gear set, but it’s the good one. The bottom line is I’ll have 100 more cfm head. Then what I have now. He did say the Polar wind going to want rpm up top. 72-7500 rpm. He like cam specs but said minimum of 800 lift. Quote from Lou Jr, it makes what it makes as long as it run 8’s. LOL
