#81
My opinion:
Original P4B design was a Squarebore-only, with subsequent poor sales, & reputation developed to overlook it. Then Post 64 Picture #2 came out; a half-finished Spreadbore design (does not seal the Q-JET's Primary circuit) Perhaps aimed at the 800Holley Spreadbores, with Squarebore ability. Then Post 64 Picture#1 came out, a finished Spreadbore design, with "Oops, not for Squarebore...'cause we casted a whole bunch of thooose, and they be sitting around. I could be wrong, and would enjoy hearing "the rest of the story" ------------------------------------------------------------ |
#82
Well actually, there were some intermediate ones, although I don't know how you see a qjet anything in pic #2 ??? That is a squarebore only intake.
There was a P4B that had the meat of the qjet flange at all portions but was only machined for a square bore. I don't know if it was large or small runner. |
#83
Found it on Craigslist in Minneapolis
http://minneapolis.craigslist.org/pts/1065233873.html LARGE runners and lacking the choke pad -weird. |
#84
Here is a pic of the one I bought..
Charles P4B-QJ version. I think there are 4 versions of the P4B..
68 Firebird. IA2 block, 505 cu in, E-head, Solid roller 3650 weight. Reid TH400 4:11 gear. 29" slick. Best so far 10.12@133 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. Last edited by chuckies76ta; 07-21-2011 at 06:23 AM. |
#85
![]() Quote:
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
#86
Few pics of the P4B-QJ intake I bought.... This looks to be an excellent intake. The flow should match the RPM..
Charles
#87
![]() Quote:
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters ![]() “Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill |
#88
Nice Charles!!.. what size are the ports?.. I did end up getting the one above !!
#89
This is a Felpro1233 gasket comparison. The P4B-QJ ports all measure approx 1.12x 2.03.. The torker 2 measures approx 1.03 x 2.04..
Charles They look as good as the Torker 2..
#90
Also uses the early style Q-jet bracket..
Charles
#91
![]() Quote:
#92
Yea I just bought it
#93
![]() Quote:
Thanks Charles
#94
i thought about doing that too , but there`s alot to cut out for the secondaries and im thinking it will need a spacer afterwards to give the airflow room to turn into the intake, and since there`s not much room now between the air cleaner and underside of the hood on my firebird , the spacer wont allow me to keep my factory ram air hood ,,
#95
![]() Quote:
#96
![]() Quote:
Charles
#97
Well Got most of the grinding done tonight so the q-jet will work on the top... just have to do some minor touch ups.. then its on to opening up the ports some.....
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's Last edited by grandville455; 04-06-2009 at 08:48 PM. |
#98
That one looks pretty much the same as the QJ version. Just will except a 4150..
looks good. Charles
#99
That look`s really good !! Have you had the chance to install and test it yet ?
#100
Thanks!.. No i haven't and with racing season starting may have to leave the testing up to cliff with his
