Old 02-14-2009, 10:06 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Default Edelbrock P4B intake
I have aquired one for testing. It looks pretty wide on the rear runner by the distributor.
Does anyone know if they will clear an HEI?......Cliff
Old 02-14-2009, 11:12 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
IIRC, I read somewhere that the stock HEI won't work with the PB4 intake...
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
fbodyfan's Avatar
fbodyfan fbodyfan is offline
Cliff , i have one on my 75 and i dont have any clearance problems with the HEI , mine has the square bore carb mount and i havent any idea as to what year it is and there`s no pn`s on it either .
Old 02-14-2009, 11:52 AM
400 Lemans's Avatar
Ran one also several years ago with hei. Worked well.
Old 02-14-2009, 01:56 PM
Cliff R's Avatar
Thanks, the one I have is exactly like the one in the pic. It was given to me 3-4 years ago, just getting around to checking it out. It has the square flange and both bolt patterns. They also made a version that was for the q-jet only, anyone try one of those with an HEI intake?.....Cliff
Old 02-14-2009, 04:48 PM
AGTO8U's Avatar
AGTO8U AGTO8U is offline
The HEI housing is very close to the runner on a P4B, but clears. Problem I had was one of the lugs on the distributor cap did not clear, so ended up grinding on the cap a little bit for clearance. Used only 3 of the 4 lugs.
Old 02-14-2009, 04:58 PM
Cliff R's Avatar
I dug out the intake and it looks like it will clear, however, it is the square flange model and will NOT take a q-jet carburetor at the flange without an adapter, bummer!
I just bought the correct one on E-Bay, item # 190277330134. We'll be testing it this summer with our stock Shaker assembly and see how it compares with the iron and RPM intakes?.....Cliff
Old 02-15-2009, 10:49 AM
Donovan Donovan is offline
I shipped my QJ P4B to Rocky recently, so he can flow test it up against stock intakes. If I'd known you were going to test intakes I would have asked him to send it to you after he was done
Should be interesting. I never tried mine with HEI though. On my 68 setup the throttle post in the back didn't line up well and the thermostat housing bolts are turned slightly to clear the runner. This made alternator mounting an issue.
Later years probably have no issue on this stuff. FWIW
I've always wondered about this intake since the runners appear to be voluminous, and the plenum is average to small.
Old 02-15-2009, 01:05 PM
grandville455's Avatar
When I seen one of these on ebay I emailed Jim H.. On it and he said to stay with the stock intake was way better.....So will be interesting to see this and how it works out...
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 02-15-2009, 01:47 PM
400 Lemans's Avatar
Google in edelbrock p4b. On the very first link there are some good pictures for comparison.Theres definately a difference in the runner sizes and shapes between a couple of the models.
Old 02-15-2009, 08:54 PM
Hooter's Avatar
Hooter Hooter is offline
I just sold one on ebay. Only got $10 for it. Not a lot of demand....
67 Bonneville ragtop
Old 02-16-2009, 01:01 AM
Cliff R's Avatar
The one we purchased is a q-jet only model, first one I've seen. We have a square flange model, and the plenum area is noticably smaller than the q-jet version, not sure about the runners themselves?
We'll get it gasket matched, remove the water crossover, and clean up the runners if/as needed. Testing to come as soon as the tracks open up here......Cliff
Old 02-16-2009, 10:07 AM
fbodyfan's Avatar
I'm definitely interested in how it turns out after all the testing is done,,, Thanks Cliff !!!!
Old 02-16-2009, 11:39 PM
chuckies76ta's Avatar
Cliff: Did you check the runners on the QJ version to the Square flange model yet?
Charles
Old 02-17-2009, 12:44 AM
Cliff R's Avatar
Nope, it hasn't arrived as of yet, should be here this week....Cliff
Old 02-17-2009, 08:52 AM
Thanks. Keep us posted if possible..
Charles
Old 02-17-2009, 09:27 AM
Cliff R's Avatar
After doing some research, it turns out that there were several versions of the P4B intake produced.
The one I purchased is the last pic, we also have one like the 1st pic in the shop.
It's interesting to note that the P4B was developed into the modern Performer intake. At some point Edelbrock decided to narrow up the runners and make them smaller.
The did the same thing with the Small Block Chevy Performer intake, as really old samples look almost exactly like the Pontiac unit in pic #3.
Ours new one is the Q-jet only model, but appears to have enough material to set it up for square flange carburetors, which we will do before testing it......Cliff
ID:	158340   Click image for larger version
ID:	158341   Click image for larger version
ID:	158342   Click image for larger version
Old 02-17-2009, 09:31 AM
Was there not an open plenum version.. Maybe someone cut the divider out..
Charles
Old 02-17-2009, 10:05 AM
Cliff R's Avatar
That units has had the divider removed. I've tested a few dual plane intake with extensive divider mods, completey removed, etc. They give up as much as 40 ft lbs torque on the dyno, and at most we've seen 2 hp improvment for peak power, usually they are off clear across the loaded rpm range.
It's best to leave the divider in them, at least from what I've seen.
Quite a few RPM intakes have been sent here from folks who modified them, or aquired them after the divider was cut out. We use aluminum flat bar, notch both ends of the flange area, and drive it a custom divider. Pretty easy modification.....Cliff
Old 02-17-2009, 05:41 PM
amcmike's Avatar
amcmike amcmike is offline
It will be interesting to see how they compare with and without the notch.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
