Old 11-26-2008, 07:08 PM
FSJplumcrazy's Avatar
FSJplumcrazy FSJplumcrazy is offline
Question Change a blower motor
Ok folks, I did something stupid and now I need help!
How in the world did the folks who changed them at a shop in the old days get to it?
I've looked at dropping the inner fender and there doesn't look to be enough room and I pulled the box inner and outer to see if I could fit the motor through the opening to no avail
So how can I install a blower motor without taking off the fender?
Wayne S
Nothing is impossible, impractical maybe, but never impossible.
1966 Le Mans Convertible STATUS: *In Progress*
389 (sixty over)/200-4R/10 Bolt (3.08 for now)
My other ride is a 71 Jeep J4000 Pick-up Truck with factory Buick 350/Th400
Old 11-26-2008, 07:24 PM
4bl389 4bl389 is offline
A/C or non A/C the inner fender drops out easily for access if needed
Old 11-26-2008, 07:50 PM
Non A/C...and I'm looking hard at those inners. Almost looks as if it could drop down, but it catches the bottom of the fender and I'm not ready to hurt the paint yet.
Motor is in as well as the front sheet metal
Wayne S
Old 11-26-2008, 10:16 PM
Ducks Goat's Avatar
Ducks Goat Ducks Goat is offline
I've changed one on my '65 GTO by separating the squirrel cage from the motor and then sliding the motor along the top of the inner fender. Not sure if there would be any difference in room on a '66 or '67.
1999 WS6 Formula, 1 of 175
1967 GTO Linden Green 4 spd, A/C, survivor
1967 Lemans convt
1967 Firebird 400 bench seat, deluxe interior, auto
1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne.
1961 Catalina 2 door htp
1960 Ventura 4 door htp wife's car
1960 B'ville 2 door htp
1960 Catalina Wagon wife's car too
Old 12-02-2008, 01:16 PM
67blackcherry's Avatar
67blackcherry 67blackcherry is offline
Location: The conservative enclave in a land of liberals; South Orange County, CA
I think you've got to drop that inner fender...can you at least move it out of the way?
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house...
Old 12-02-2008, 01:56 PM
Cammer-6 Cammer-6 is offline
guy brings me a 67 non A/C car thats just back from body shop as a rolling shell with front end assembled.
He then hands me the heater box to install.
I said "OK you show me how to put this in with the fender on."
He gave me a dumb look and in 30 minutes the fender was off unharmed(got to love that masking and duct tape).
Old 12-02-2008, 02:02 PM
That looks to be the route, but I'm going to try removing the squirrel cage first and then seeing if the motor will slide across the top of the inner fenders.
Now I'm sure this will be the last big project...at least this month
Wayne S
Old 12-14-2008, 11:37 AM
als67goat als67goat is offline
Sorry I'm late on this one but the inner well will come out fairly easily if you pull down and twist the rear. I just put factory a/c evap box in my 67 this way. Didn't have to remove fender. You have to get the car jacked up pretty high for it to come out the bottom. Be sure to only put the bolts back in loosely and tighten AFTER you lower the car onto the ground. Helps to have a second set of hands to re install but I got mine out by myself.
Old 12-29-2008, 02:32 PM
Thanks Al...not late because I'm really slow
Wayne S
