#41
And water pumps. Have couple each. And stock bell housing.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
#42
It seems high to me but I have it in print here for a 400 car at 3855 for curb weight.
A second class drive is better than a first class walk. |
#43
Had my full dress 9er weighed a couple of weeks ago. 3740#. 1/4 tk gas, 4sp, SF conn, 4pt bar, traction bars, 150# in the seat.
Robert |
#44
Found my list and wieghed some other stuff laying around last night with a cheap bathroom scale.
Fully loaded #16 hd: 72 Ported 66 cc 2.19/1.66 E-heads/Manley vlvs/triple springs and rkr studs(no rkr's): 30 Uncut stk intake w/switches: 43 Uncut Victor: 18.5 Torker I and II; didnt feel like dig'n out. std 850 Holley: 13 stk 800 Q-jet: 11 Stk water pump: 7 Aluminum w/p: same reason as above. 19" stk clutch fan: 6.5 19" flex fan(steel ctr w/7 stainless steel blades): received phone call, but think: 4.5 Stk 70-455 air cleaner: 16 14x3" chrome drop base a/clnr: another phone call Stk exh manifolds: 24 70 RAIII exh mans: Still need to dig out. 1-3/4"-3"(3 bolt collector) Hedmen d-port's: 28 1-7/8-3.5" (coated slip fit collectors) Dougs still in shpg box: 38 Stock GM unpainted fenders: 30 ea. Steel deck lid: 27 Hood: didnt find note yet. Glasstek bolt on hood: think i was told 22 shpg wieght? last month. Cowl, fdrs, doors, deck lid: need to find out. 14X7 ralleys w/225-60 radial(full tread): 44 14X7 " w/245-60 radial(1/8" tread left ): 47 15x5 Weld Stars w/165r15 Coopers(full tread): 27 15x8(or 8.5-9. ?)w/27x11.50-15lt Hoosier QPT(1/8" left ): 27 Frame connectors: 16 Stk tank vs cell: have to find note Front cowl panel LH/RH "horns" under fenders, and whl/houses: still have find that note 90-91 TA plastic wheel liners: less then a lb. ea. Same with stock frt seats vs APC cloth seats(in car), and stk seat belts vs 5 pt belts(way heavier).
#45
Also have th350, th400, 200-4r, 700r4, 4-spd, 9", 10", and stk trq cvrtr's, 1st gen 10 bolt, 2nd gen 10 bolt, and 1st gen 12 bolt rear ends wieghts somewhere.
#46
Whole front disc brake setup
-spindle -caliper -dust shield -bracket -cap -bearings -hub -Rotor 45 pounds per side 1969 Single piston style brakes |
#47
Bring'n this back up cause the inner bracing(center only) fell out of the hood last night
6 lbs. The cowl "horns" look like they'r gon'a fall off this winter also. I'll post when they do.
#48
This was pretty accurate for my year:
1967 AMA Spec's http://firstgenfirebird.org/firebird/1967/ama/24.pdf 1968 AMA Spec's http://firstgenfirebird.org/firebird...ma_page12.html 1969 AMA Spec's http://firstgenfirebird.org/firebird...ma_page12.html |
#49
In case anyones been wondering, my 68 has 115 lb's removed so far.
Probly more then that cause i forget to wiegh some of the small stuff before cleaning up. And theres more to reamove, but i'm really holding myself back.
#50
Just weighed my aluminum radiator with dual electric fans
34lbs keep in mind it had more volume than a 4 row so it will weigh more when filled. No weight savings there from a clutch fan and brass radiator. |
#51
Bare front bumper - 16lbs
The top bumper support - 11lbs |
#52
Both my frt bars wiegh 17. But i'm use'n and old cheap bathroom scale.
Right now the bar sppt(trimmed 4lbs) w/frm brkts is 21. Still decide'n if i should trim the frame brkts themselves.
#53
Have not weighed birds but weighed some A-bodies on my forklift scale at work (certified to 2lbs accuracy). The weights below are for original cars, no driver and no gas.
Some are surprising: 69 GTO vert: 4spd AC and heavy optioned (windows, 8 track etc) 3,890 69 LeMans vert: 3502bbl, T400 AC, also fully optioned with windows etc 3,885 69 GTO HT: 4spd AC and again fully optioned 3,855 Porky cars! Wonder what a stock Bird 400 weighs? My experience is that a muncie installed is almost 50 pounds lighter than a T400 and a 3spd floorshift (DB13) is about half way between the two (iron case)
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 Bonnie Cvt & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
