#61
1974 Trans Am. 4010 lbs with me and 1/2 a tank of gas.
- Original 400 ci. Stock crank, rods, pistons... Was rebuilt in 1988 to stock spec.s. - Completely stock 4x heads with the exception of some Crane RV cam from 1988. Not ported. - Edelbrock Performer intake with out of the box Holley 650DP. Original intake and carb were long gone when I got it. - Hedman 3 tube headers with Flowmaster 2.5" exhaust, H-pipe with original style Flowmaster crossflow muffler. - K&N air filter in the Shaker scoop. Opened flap. - Stock GM HEI with Mallory coil, cap, module and Accel wires. Originally came with unitized Ignition, but was long gone when I got it. - Original TH400 trans with Shift kit. Rebuilt in 1990. Stock converter. - original 10 bolt rear end with 3.42:1 gears. - 225/70-15 BFGs on stock Honeycombs. - Koni Red shocks, stock rear leaf springs with no traction aids. Front stock replacement springs, stock sway bars with poly bushings. - This is as basic a combination as can be. It has been dead reliable for the past 17 years I've owned it. Drive 75 miles to the track, race, and drive home. Best E.T. to date: 14.19 @ 97.42, with crappy 2.1 60' times leaving at idle. Car has more in it, but I can't tune a carb to save my life
Panos Little Miss G Racing |
#62
1971 Pontiac LeMans Sport, 3880 lbs w/o driver
1971 455 block Stock crank Eagle rods TRW pistons W/Butler lightened pins Speed-Pro moly rings BOP rear main seal 6X-4 heads ported to 255 cfm by Pete McCarthy Stock 1.5 rockers and push rods (for now) Edelbrock Perf. RPM manifold w/porting to match the tall roof on the the heads and removed water crossover Brad Urban Stage II Q-Jet #79 jets / 43K rods DU secondary rods / H hangar Cam specs: Intake/Exhaust @ .006 285/290 @ .050 235/240 Lobe Lift .338/.331 Gross Lift @ 1.5:1 .507/.496 Lobe Separation 106 Deg Installed Intake Centerline 102 Deg. Doug's headers PY/Pypes 3" exhaust and tailpipes w/x-pipe and Goerlich XLerator 18" mufflers GM HEI MSD 6-AL MSD Timing control Taylor wires Autolite plugs TH400 Continental 10" "Jim Hand Special" converter Pontiac 10-bolt 3:36 rear gear Moser axles Original "machined" cone-style posi 28x10.5 slicks Sumped stock gas tank 140 GPH pump -10 from tank to pump and filter -8 line to regulator, etc Stock front suspension Rubber bushings "El-cheapo" front shocks 1-3/8 swaybar from F-body Stock rear suspension Owner-boxed lower control arms, w/tubed holes for swaybar Poly bushings Brakes Factory disc brakes T/A rear discs in rear 10" dual-diaphragm booster from 78-87 A/G body Aluminum master cylinder from pre-'91 Caprice Line lock on front brakes Brake pressure gauge in car Best E.T.: 12.35 @ 109.36 mph (1/4 mile, Speedworld, 2600 foot relative) 7.69 @ 89.75 (1/8 mile, Irwindale, 1500 foot relative) Drove to Pontiac Heaven, won on Saturday, R/U on Sunday, drove home, average 14.5 mpg.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same. -RONALD REAGAN 462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg Last edited by PMDRACER; 08-19-2007 at 03:33 PM. |
#63
1970 GTO PS/PB A/C
71' 455 +.030 zero decked Nodular crank .010 M .020 R Scat forged H-beam rods with pressed pins TRW forged pistons Sealed power 80lb oil pump with a stock baffled pan Comp XE274H with an Edelbrock timing chain Stock Edelbrock heads (87cc) Harland Sharp 1.5 rockers Performer RPM Gasket matched with a 1 inch open spacer on top Holley 850DP fed by a Carter 120gph mechanical Doug's Headers with dual 3 inch exhaust Hays Flywheel with a 11 Inch ram power grip and Power Master Mini Starter TKO600 (.64) Shortened stock drive shaft Ford 9 inch with 3.60's and a Detroit TruTrack 275/60/15 Radial T/A's on 15x8 Cragers Engine was assembled by me when I was 18 In the pictures it had the crappy Edelbrock 750 and a performer intake
70 GTO 462 E-Heads TKO-600 9-Inch/3.60's |
#64
467ci 635hp
467cid Specs, my sig lists the track times and on the dyno we made 635hp@6400 and 575ft/lbs@4900. This dyno has proven to be conservative by about 50hp when track times & race weight are calculated. I drove this all over the place on the street and made well over 350 passes at the track before I pulled the motor to check everything over.
1994 Formula 535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200 Pontiac Powered 4th Gen Project Progress |
#65
416ci 518hp
416cid Specs, my track times in my 69GP with a 3750 race weight has gone a best of 6.90's@100mph & 10.80’s @ 123mph, on the dyno we made 518hp@6300 and 496ft/lbs@4300. This dyno have proved to be conservative by about 50hp when track times & race weight are calculated. I drove this so many untold miles on the street and made well over 200 passes at the track before I pulled the motor to drop in the 467 motor
#66
70 GTO 4200lbs race weight.
72 455 +.030 - 4.21" stock crank -.010/.010 balanced cast pistons resized cast rods with ARP bolts Ported 5C heads/stock valves UltraDyne 280/288 hyd / stock type lifters stock rockers RPM/Demon 850DP Summit headers/ 4' length of 3" pipe with cheap Summit mufflers/no tail pipes 2004R/stock lock up converter 2.93 gears in Olds rear BeCool aluminum radiator Stock H2O pump 185 thermostat best ET 13.51@105 best MPG with Qjet 25MPG, 16 city, 22HWY is normal Recently swapped in a 12 bolt with Eaton Posi, and 3.42 gears. Have not raced it since. |
#67
72 Formula 3900lbs/ # matching
455 HO 4bolt main +.030 Stock 4.21" crank Stock reconditioned rods 7F6 heads/untouched/stock valves CC 292 hyd cam 1.5 roller rockers TorkerII intake/800 E carb (since changed to Performer/Qjet, runs MUCH better but no ET) Hooker supercomp headers/Full 3" system TH400/3000 stall 3.70 gear Power everything, AC = heavy Bought from a good friend who had it set up this way. He got a best of 13.0 with it, dont remember the MPH. Last edited by Thumpin455_GTO; 09-19-2007 at 11:45 AM. |
#68
79 Formula 3750lbs race weight
(previous combination) 73 455 + .030 4.21" crank -.010/.010 balanced stock rods, resized, ARP bolts TRW Forged pistons JBP ported 670 heads/Fererra valves/stock size 11.3:1 compression as measured UltraDyne 288/296 flat hyd Comp 995 springs/CC locks-retainers Crane 1.65 aluminum roller rockers TKII/850 Holley DP Hooker headers 1 7/8/4' length of 3" pipe/cheap Summit mufflers TH400/L88 style stock converter/stalled around 2200 4.10 geared 12 bolt. Ran faster with 3.42, but the 4.10 was left over from the previous 400 McCreary DOT dirt track tires/later BFG Drag Radials 296/65/15 Stock WS6 suspension, front sway bar removed Best ET 11.71@115 Typical ET 12.1@114 / 7.70@ 88 1/8th Last edited by Thumpin455_GTO; 09-19-2007 at 12:02 PM. |
#69
79 Formula - 3100lbs empty
(Current combination) 73 400 block + .030 Eagle 4.25 crank / balanced Eagle 6.800 rods Ross pistons JBP 330cfm E heads 85cc/ tall solid roller springs CC 270/272 solid roller JBP 1.6 rockers Victor/1050 Dominator (4" cowl hood is too low) Hooker SuperComp headers/2' of 3.5" pipe/3.5" Dynomax bullet mufflers Th400/manual VB/3600 stall (Needs a 4000 Continental or similar stall) 4.10 12 bolt adjustable drag shocks up front 50/50 rear shocks Moroso trick springs in front NO ET as yet. Only a few shakedown runs around 7.40 in the 1/8th. (3rd gear only) Will be a while before it sees the track again. Needs all safety equipment and a good stall. Plus the closest track is 6 hours away. |
#70
Engine Modifications:
'69 400 2 bolt block bored .030 Deck height set to -.001 #62 Iron heads - home port to 275cfm @ .500 lift - heads milled to 10.4 compression with .040 gasket Stock 10/10 crank Eagle H-beam rods with ARP fasteners Forged Probe SRS Pistons Bullet Solid cam 260 / 258 duration @.050 - .554 / .586 lift int / exh Crower Solid lifters with EDM hole Crower 1.6:1 roller rockers 9-way Timing chain from P.P.R. (nice piece) Edelbrock Performer RPM Intake, top 1” milled out of plenum divider and light porting Heads and intake port matched to RA IV gasket 825 CFM Mighty Demon Mallory Hyfire IV Mallory Mechanical magnetic distributor Transmission: ’69 Muncie has been upgraded with Super Case, Iron Mid plate, M22 wide ratio gears McLeod SFI Aluminum Flywheel 11” clutch Rearend: Dana 60 with 4.10 gears and 35 spline Strange axles and Aerospace disc brakes Suspension Multi-leaf rear springs QA-1 Race coil over shocks/springs up front set on 90/10 CE adjustable drag shocks in back set on 50/50 1 1/8” sway bar up front Cal-trac’s New best ET is 12.06 @ 113 with 1.75 60' time. Still dialing in combo - shooting for 11's. Need to get 60' times down. MPH is consistently in the 110-114mph range. ET varies from 12.0* to 12.3 depending on launch / 60'. Edit: 10/13/07 - new best is 12.01 @ 113 on motor 11.31 @ 122 on 100hp shot Nitrous system is an NOS top shot (sits on top of carb) - 150 shot coming soon... 10/26/07 track trip yielded a new all motor pass of 11.82 @ 114mph with 1.74 60' - still don't have a solid pass with the 150 shot. Last edited by JoePapa; 10-28-2007 at 01:16 PM. |
#71
77 Trans Am 3745 lbs with driver
455 .060 over, bottom filled, 4 bolt mains 87cc E-heads ported by Butler, 315cfm. factory crank, eagle rods 6.8, SRP flat top pistons 254/262 solid roller, .590 lift (street roller) Victor, Holley 4150 (850) Hooker headers, 3" exhaust with X pipe and tail pipes. Turbo 350, TCI 3500 converter, 3.42 gears with a posi in the stock 10 bolt, MW axles Cal trac's, mono rear springs, QA1's Weld pro stars, 3.5's and 10's with 13.5x28 QTP's. Full interior, Alpine Stereo with Subs, 10 pt cage, per NHRA rules. 10.90's @ 125 on motor 9.90's @ 135 on a plate kit. Street driven all the time. |
#72
Two tales
I used to have -
73 TA, Bucaneer Red, no AC 4 Speed - M-22 - Hurst 4.10 rear gears, Saf-T-Trak of course 455 original block '67 GTO heads (I think they were 92 or 94s?) reworked with bronze guides and knurled stems and 3 angle valve job by Kline Automotive in Richmond VA Copper head gaskets, O-ringed heads - 11.25/1 coompression Crane Fireball Cam (294/304 advertised, about .45 lift), springs, lifters, etc. GM 1.65/1 rockers GM HD pushrods Edelbrock intake Holley 850 DP Hooker Headers Rebuilt recurved distributor Carter fuel pump reworked water pump (2 vane) Undersized drive pulley Scoop opened up for cold air Traction bars I could adjust at the track Air Lifts Turned about 12.25 to 12.30 at 128MPH at Richmond, VA I still have- 1966 Goat, Barrier Blue, no AC, no PS, Quick Ratio Steering 3 dueces, Posi, 4 Speed M-20 Bobcat Kit M&H Cheater Slicks Turned a best of 13.12 at 107 at Richmond, VA
"What could have happened, did." Last edited by Virginian; 10-11-2007 at 07:45 PM. |
#73
EFI 455 Street and Strip
1967 Pontiac Tempest 2 Dr. HT ...originally an OHC-6 1barrel w/ 3 on the tree.
This car was designed and built to be a REAL street and strip car. As such, it is by definition, a compromise. It is not another of the all too numerous “race cars with a license plate” that pretend to be called a “street car” while screaming down the highway at 4000 RPM, sucking fuel like a Titan rocket! Seriously, what kind of gas mileage do you get and how practical and reliable is it on a long road trip? Oh, well! ...to each his own! My goal is a stealthy, reliable, pump gas friendly and relatively economical road cruiser that is also capable of kicking some ass in the quarter mile! Engine Details, Etc.: 1970 XF code, 4-bolt main, 455 +.050 (467 cu. in.) Stock Nodular crank turned 0.010 Cleavite bearings Ross Custom flat top pistons Hastings file fit rings Eagle forged H-beam 6.625” rods Zero decked 9.5:1 comp. ratio Melling 60 psi oil pump Balanced rotating assembly SFI balancer Fel-pro gaskets #96 heads, ~96 cc, hardened seats, gasket matched, blocked crossovers and mild porting Ferrea SS 2.11 / 1.77 valves 1.6 ratio aluminum roller rockers Comp XE 274 cam 230/236@.050 523/529 lift w/1.6 rockers 110LSA Comp Cams timing chain set, hyd. Lifters, valve springs and push rods Edelbrock Performer RPM intake manifold Holley 900 CFM TBI with 4 x 85 lb. per hour injectors Megasquirt II v 3.0 ECU -controlling all fuel and ignition. 3/8” in / out fuel lines Twin parallel MSD EFI inline fuel pumps Innovate Wideband O2 HEI w/locked down mech. advance and no module 34 degrees advance in by ~3K rpm MSD6AL box MSD coil MSD 8mm plug wires Doug's Headers 3" pipes w/ 3" X pipe and 3” cut-outs Dynomax Super Turbos Dual Flex-a-Lite electric cooling fans Trans Details: ’88 700R4 -w/Hytek max build Transgo 700 shift kit TCI BOP adapter 2500 stall converter, w/full lock-up B&M trans cooler B&M Megashifter Rear end: 10-bolt BOP 8.2 Nodular GS type 3.55 Richmond gears Auburn Pro posi TA Performance Rear End Girdle Moser custom alloy axles SSM lift bars Split, independent-fill air shocks 275-50-15 BFG Drag Radials (track) 245-60-15 BFG Radial T/A (street) Misc. PST polygraphite front suspension kit MBM power front disc brake kit OMZ Racing seats Hurst Line-Lok Highway Performance: Getting close to 20 MPG @ 70 mph cruise at 5% throttle! -Runs nicely on the 91 octane oxygenated crap gas found here in Phoenix. ¼ Mile Performance: Only 1 trip to the track so far; ET 13.05 @ 107 mph with a momentary starting line bog and resulting lousy 60 ft. times. Pulls very hard thru top end! More tuning needed w/TBI at launch. -Looking for mid to upper 12’s?! …Stay tuned! Weight: ~3700 lbs. w/ driver
The 1967 Rustbelt Refugee. Work in progress. Donations accepted. - 467 Cubic Inch EFI Pontiac, Megasquirt II v.3.O ECU, 700R4, 3.55 gears - Best 1/4-mile ET: 12.79 @ 107.36 MPH - Best Fuel Economy: 18.47 MPG ...That's no GTO, that's a Tempest! |
#74
Daily driver, 76 TA
455 .040 over, early Pontiac forged rods, KB pistons, zero decked
800 Qjet, MSD dist. both done by the late Bob Maxie KRE 310 dports , WFO drop base, RPM port matched, UD 239/247 hyd (. 507/.520) MSD 6AL ignition, 6000 rpm chip, (effective @ 5,500) Borg Warner 4 speed, 2.88 first gear Hooker headers, Dr Gas 3" X 2.5" crossover, Flowmaster transverse muffler Stock 3.23 rear, driven year round as long as the streets are dry Temp never over 180 degrees, stock water pump Sorry no pics, this car is from an all analog, vacuum tube powered home! Never on the track, Always enjoyable! Garcia Hill Fort Washington, Md |
#75
1971 Pontiac Formula 400
Engine Stock Displacement: 400 (actual 400.18) Block modifications: trimming of flange castings by lifter cross over for better oiling Freeze plugs: brass Displacement after bore: 406 (.030-inch over) Bore: 4.12 Stroke: 3.75 Main Size: 3.00 Main Caps: stock 2 bolt Rotating assembly: Stock Crank: Stock 3.75 Rods: Stock (Length) Bearings: Federal Mogul Cam FEM-1220M, Main FEM4040M, Rod FEM-8-7050CH Pistons: unknown .030-inch over aluminum stock type flat top Rings: Moly model SLP-E-299K030 from Summit/Sealed Power brand Timing Chain and Gear: Comp Cam model 2112 stock chain gear type Oil pump: Melling MEL-10541, shaft MEL-IS-54A Camshaft: Summit model SUM-2801 214 / 224 duration at .05” lift with 1.5 rockers, advertised 272 / 282, 112 lobe separation Lifters: Comp Cam model 852-16 Push Rods: Comp Cam CCA-7851-16, length 9.136”, 5/16” diameter Rocker Arms: Harland Sharp 1.50 full roller rocker model CSP-S6001 Clylinder heads: Stock 1971 96cc heads Cylinder head modifications: trimming of casting flanges for better oiling, light porting of exhaust, light porting of intake openings and push rod bulge Rocker arm studs: 7/16” (big block Chevy type) ARP Model ARP-135-7101, poly-lock 7/16” by ARP model ARP-300-8245 Valves: Ferrea stainless steel valves 4.98” length; 1.77 exhaust model F5062, intake 2.11 model F5065 Valve springs: dual springs, Crower model 68404 Valve retainers: Comp Cam 10 degree model CCA-740-16 Compression ratio: 8.2-1 Fuel / intake Carburetor: Stock 1971 Rochester 704163 750 CFM Intake: stock 1971 455 HO aluminum intake with cast iron exhaust crossover (blocked) Octane: pump gas 91 octane Air cleaner: Stock ram air cleaner Exhaust Mufflers: Dynomax, dual mufflers Tail pipes: 2.5” diameter Exhaust Manifolds: Stock ram air III D ports Cooling Radiator: OEM style from NPD; Aluminum. 160 degree thermostat Drivetrain Axle: 3.75 Tries: BF Goodrich 235/60 R15, Rally 15 x 7 rims Traction bars: Lakewood Transmission: 4 speed, Muncie M21 close ratio Clutch: Ram clutch, 10 1 /2” diameter |
#76
My daily street driver.....
1977 TA 400 9.5:1 CR 351hp 414LbFt, #13 Heads + 1.52 Roller rockers, 1968 Pontiac 400 intake, Holley 4165 650 DP #7054 Howards Hyd .447/.467 IN:288 EX:298 214/224@.050, MSD6A + MSD timing control + H2o/Meth 1-5/8" headers, Magnaflow 200CPI Cats + 2.5" Pypes X, Dynomax STs, TH-700R4 2200 stall, 3.42 Eaton 10-bolt, PS/PB/PW/PL/AC/Cruise 13.84@100.14mph 2.18 60' on P255-60-R15 radials, pump gas, mpg : 21.5 hwy 15.2 city |
#77
1979 T/A WS-6 4 speed w /rear 3.42 gears w/ original posi 245/60 BF Goodrich tires
engine: 455 .030 over w/trw pistons stock rods reconditioned to H-O's specs with good bolts, magnifluxed and shot peened '71-no. 96 heads 3 angle valve job Cam Dynamics (crane) no. 10514 Cam 234/234 .494 lift w/1.5 stock rockers and Rhodes lifters and stock push rods Competition Product no. 98341 valve springs Edlebrock Performer or Holley Street Dominator manifold (depending on how I feel ) Holley 850 dbl pumper w/original jets BOP rear seal Warrior crank scraper Centerforce 10.5 clutch '68 GTO ram air III exhaust manifolds with 2.5 pipes w/Flowmaster mufflers Griffen aluminum radiator w/ 7 blade clutch fan and homeade shroud. Accel ingnion with HP module and coil set at 34* and a Crane vacuum advance Suspension is a complete Rancho kit w/ stock Gabriel shocks I am planning on installing 1 5/8 4 tube headers w/cossover and 1.65 rockers The above combination produced 474 LB/FT of torque at 4000 RPM and 417HP at 5000 RPM on My Performance Trends Engine Analyzer. The torque curve was very flat only varying 71 lb/FT from 3000 to 4000 RPM. I used N0.62 heads for the flow example with 9.5:1 compression. Take it for what it's worth. |
#78
EL GATO GRANDE
My car is a 1964 Catalina Executive 4 door sedan.
stock: it had am radio, Air Conditioning, Seat belts in front, Power steering, 389 O5L engine, 2.56 to 1, with a Roto Trans. Weight around 4100#. Racer: No seats, bucket for driver only, No A/C, No Power Steering, cross bracing for rear seat removed, heater removed and all extra sheet metal up front, flat panels made from aluminum road sign material. wet weight: 3650# Race weight: 3945# Engine: Stock WX 455 out of a 76 Trans Am Stock Crank Stock Rods Stock Cast pistons with 9 CC champher Stock large inlet oil pump, changed from small inlet on this engine Stock oil pan w/baffle no windage tray Cam: Ultra Dyne...can't find my card at the moment Cam Chain: Cloyes Double Roller Lifters: Pep Boys replacements, good for 5500 RPM Pushrods: stock for heads used Valves: stock, Ram air 4 springs & retainers. no shims Heads: casting 98 2.11 intake 1.60 exhaust, 3 angle, no porting, .030 off surface C.R.: 8.6 to 1 87 octane fuel Rockers: JBP Aluminum rollers at 1.60 Lift at the valve: 5.12 intake 4.98 exhaust Headers: Unknown Make 4 tube headers into 3" collector Exhaust: 3" pipe into 4 chamber flow masters, dumped at the rear end Distributer: Stock Point type, Accel 32oz points, cap, rotor, Beldon 8mm wires, accel coil, resistored Advance: 14* locked at idle, 34* total at 2800, No Vacuum Spark Plugs: Autolite Manifold: Edelbrock Torker II Gaskets: Felpro Carb: Holley 750 cfm Vacuum secondary set as lite as it can, no choke, 2.5 PV Jetting: its been so long since I had it apart, I don't remember Air Cleaner: 8" round, 6" tall K & N sticks partally into scoop Water pump: stock, electrically driven Alt: internal regulated, belt Damper: Stock, used to have timing tape Transmission: T-400 short tail Rebuilt? Yes, by owner with mods from T-400 book, shift kit, seals modified Converter: GM-6 HD Stock replacement for 427 Corvette Ect. Stall: Roughly 2200-2400 Driveline: 4" Lincoln shaft with the ends made to GM 64" long W/loop 8" behind yoke Shifter: full ratchet up and back Rear end: Stock 64 Pontiac Gears: 3.42 to 1 with "spyer locks" no spool, no Saf-T-Track front tires: 215/75/15" Rear: 9 X 28 X 15 Mickey Thompsons Fuel Pump: Holley Blue with regulator Fuel tank: 9 1/2 gallon cell in trunk Battery: in trunk 1 or 2 Fuel line: stock no return Power Adder: 150 Plate shot of NO2 at owner descretion. not linked to throttle 10# bottle in trunk, best pressure to run this car.....940-1000 PSI 115V heater Brakes: single circuit, Manual Drum/drum Axles: Stock Steering: Manual box transplanted extra engine filter: Frantz oil Cleaner with Modified roll of CHARMIN TP engine filter: Purolator Blue stock type Oil used: Castrol Syntec 20-50 Oil changed at: I don't change the oil, just the filters, OIL IS 7 YEARS OLD Gauges added: Hour Meter, Oil, Volt, Temp and 8000 Autometer Tach with Sh/lite Hours on meter since car in this configuration: 152 Street driven? yes, it is licensed and can be driven legally on street Fastest speed driven: well over 120 + launch RPM: Just off idle to 1400 in low, manually shifting, shift light set at 5200 rpm 1/4 mile results: LACR 13.69 on engine, @ 98 12.58 NO2 @ 106.9 POMONA: 13.25 on engine @ 102. 6 12.05 NO2 @ 114.7 Sears Point: 13.20 on engine @ 1--.- 11.93 NO2 @ 111.7 The 11.93 was a surprize and I got in trouble because the car wasn't set up for that. It launched so hard it knocked the wind out of me, and yes I have a copy of the time slip for both Pomona and Sears Point (infineon raceway park)
RDRR Custom Fabrications ....A fictitious company doing fictitious work.... Last edited by RAJNWDY; 12-17-2007 at 03:59 AM. |
#79
I have another post on page 3 but the motor has since been rebuilt – this is the new combination. Car is a ’69 Firebird, full body car. ~ 3600 lbs curb weight.
Engine Modifications: 69 400 2 bolt block bored .030 Deck height set to -.001 #62 Iron heads - home port to 275cfm @ .500 lift - heads milled to 10.4 compression with .040 gasket Stock 10/10 crank Eagle H-beam rods with ARP fasteners Forged Probe SRS Pistons Bullet Solid cam 260 / 258 duration @.050 - .554 / .586 lift int / exh Crower Solid lifters with EDM hole Crower 1.6:1 roller rockers 9-way Timing chain from P.P.R. (nice piece) Edelbrock Performer RPM Intake, top 1” milled out of plenum divider and light porting Heads and intake port matched to RA IV gasket 825 CFM Mighty Demon Mallory Hyfire IV Mallory Mechanical magnetic distributor Transmission: ’69 Muncie has been upgraded with Super Case, Iron Mid plate, M22 wide ratio gears McLeod SFI Aluminum Flywheel 11” clutch Rearend: Dana 60 with 4.10 gears and 35 spline Strange axles and Aerospace disc brakes Nitrous Top Shot set to 150hp Best all motor pass is 11.82 at 115 or 116 mph. Can run 12.0 at 114 pretty consistently. Best nitrous pass is 11.20 at 125mph. Also pulled similar times on 100 shot. Still tuning … |
#80
1968 Ram Air III GTO convertible
'69 engine L74 YZ 400/366 HP 410 ft lbs torque performance longblock:
400 block bored, honed, decked and align honed Speedpro® performance camshaft: 214/224 @ .050 or cam of choice .465 lift 112 lobe center New Durabond® cam bearings Reground 3.75” stroke steel crankshaft Resized rods with ARP® rod bolts New King® performance bearings Speedpro® domed forged pistons with Molly® rings 9.3 to 1 compression ratio New Melling® timing set New Melling® high volume oil pump New performance gasket set Pontiac Heads #48 includes: 2.11/1.77 new performance valves Bronze guides 3 angle seats 110 lb. Matching springs New push rods and stamped rockers TH 400 3 sp automatic His/Hers shift Flowmasters |
