ISO harmonic balancer for 1963 389
ISO harmonic balancer for 1963 389 w/AC (not sure what years are compatible for '63). Mine has broken, not sure condition of crank until I tear it down. dont need the pulleys, only balancer that mounts to the crank.
Need crank bolt as well
Phil '63 Grand Prix / 389 Tri-power |
I think I have one,not sure about the bolt.Tom
PM sent.
That is the hub,I have it with the balancer bolted to it but no pulleys.Tom
I only need the hub, all other parts (expect bolt) are okay. not sure of condition of crank until I tear it down
Update on my balancer failure. I purchased a replacement hub and crankshaft bolt. The bolt wont tighten to specs. So it looks like I have to pull the motor and get a replacement crankshaft. Anyone know if the crank bolt hole can be machined to accept a larger bolt? any other ideas. Will be pulling the motor out once I get the accessory drives out and trans disconnect. Wont be cruising for a while ;-(
Get a shorter bolt!Tom
Sounds pretty un fun. I would think a thread insert would work.
Or there are some cranks on this side of the pond, I will ask around.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
