Old 04-30-2024, 05:22 AM
spectramitch's Avatar
spectramitch spectramitch is offline
Default Milling Intake
My intake sits a little high with .062 gaskets making it so the thin area on the bottom of the port doesn't pinch down on the gasket. The intake is a ported Victor.
How do you determine exactly how much to mill off each intake flange?
ID:	632923   Click image for larger version
Name:	View recent photos.jpg
Old 04-30-2024, 06:12 AM
What's it look like without the gasket on?
I've used a thin paper gasket before.
Old 04-30-2024, 06:52 AM
With no gasket it sits pretty good. Intake is slightly lower than the head ports.
Old 05-02-2024, 12:09 PM
I set up the intake and cut .045 off a side. It lined up much nicer. The bottom was crushing the gasket a little harder than the top. So I set it back up today and took a couple thousandths more off the bottom than the top, .005 total more.
ID:	633059   Click image for larger version
ID:	633061   Click image for larger version
ID:	633062   Click image for larger version
Old 04-30-2024, 07:04 AM
This pic is from the first time I took it apart after buying it. Looks like it has always sat like this. See how the bottom is barely pinching the gasket.
Old 04-30-2024, 07:38 AM
Without the .062 gaskets making it fit decent then I would mill .050/.055". (.062 would put it at where it is with no gasket)
Might need little more but hard to put material back on.
Old 04-30-2024, 08:27 AM
chuckies76ta's Avatar
Can you post a better pic of the bottom of the intake runners. It doesn't look like there is much sealing area. I would test fit the intake without the valley pan in your way for starters to see where it lines up.
Also, The holes for mounting on the intake need to be ob-longed so the intake once mounted can kinda find it position on the heads. It's hard to tell what's going on with the washers in place on the bolts. When mounting the intake, take a rubber head hammer and tap on the carb base area to seat the intake. You can test fit with and without the gaskets see where the intake lines up.
Old 04-30-2024, 03:43 PM
Its about little less than 1/8” wide at the bottom of runner opening. I looked through port with my bore scope and all the ports match good with no gasket. I think I need to wack off about .050 a side
Old 04-30-2024, 03:47 PM
Have the heads been milled?
If so, maybe they didn't mill the intake side?
Old 04-30-2024, 04:11 PM
Formulas Formulas is offline
In this case wouldn't it require an angle mill ? Just adding or removing gasket thickness moves the intake up or down.
stated problem is less clamp load on port bottom as in incorrect angle or mechanical interference with valley cover
If your not at the table you're on the menu
If you remove material off the runners, the intake will sit a bit lower. You still should be ok as there's space from the valley pan.
Well, you know the gasket are .060 thick. You could try installing the intake with only one gasket see where your at. I guess if you take too much off they make thicker gaskets. Tin Indian I think has them. Those are really good pics you posted.
My intake I cut at the bottom like yours to accommodate the valley pan. If you take .030 a side off that's like one whole gasket. I wouldn't do .050 a side. That's seems like alot. Another thing I did was use the feeler gauge between the heads and intake as I would snug the bolts up a bit to see if there was contact. Tedious process but tells you what's happening.
Old 04-30-2024, 04:15 PM
Another thing I was thinking, leave you gaskets hit the valley pan when you install them. You might have to cut a bit off to line up the posts, But I find it help hold the gaskets in place.
Old 04-30-2024, 05:03 PM
Heres 2 pics with and without gaskets. I do need the intake to “fall” down more.
Old 04-30-2024, 05:41 PM
With his gaskets off, and it fits good, that would be equivalent to what it needs to be milled off each side of intake. (best would be the intake side of heads but they are still attached I believe)
As to the tray hitting, he could chamfer the intake bottom some if need be to keep it from sitting all the way down. (or even trim the tray some in the ares of the intake ports, which is what I did on mine)
Old 04-30-2024, 07:52 PM
Can anyone measure how thick the intake flange is on a un cut edelbrock victor dominator? I am just wondering for peace of mind to see if this one was never cut.
Old 04-30-2024, 08:57 PM
I have 2 victor intakes here that are new and the flange is roughly .500 thick or 1/2".
Old 05-01-2024, 05:33 AM
Thanks Chuckie this one measures that also. Looks like either the intake was port matched to the heads with no gasket taken account for or somewhere down the line it was mated to a different block.
Old 05-01-2024, 05:42 AM
It's odd here that there's a gap difference between the top and bottom side with a gasket in place, this leads me to question weather the heads have been not just Milled, but angle Milled?
Old 05-01-2024, 05:49 AM
Your welcome. I was thinking you might want to separate the water cross-over from the intake. It helps to align the intake with the ports alot better. I realize you know that. Just thrown ideas your way.
The other thing I noticed in your pics was that the top part of the flange has alot more material than the bottom suggesting that maybe who ever ported it moved the openings downward. So cutting a-bit off each side will lower the intake to the port opening. And then the angle that has been mentioned comes into play.
Old 05-01-2024, 11:37 AM
Scott Stoneburg's Avatar
I wouldn't separate the water cross over until after the milling process, the machine shop may charge extra for setting up the 2 pieces. (Ask me how I know..lol)
