Old 04-28-2024, 09:14 AM
punkin punkin is offline
Default Vacuum Pump Mandrel Drive
Good day all,
I've done a little web searching and haven't yet found what I'm looking for. Perhaps someone here has already dealt with this.
I have a vacuum pump and crank mandrel for the belt drive. The pulley on the crank slides on (semi-press fit) using a woodruff key and set screw. It works well enough but makes is a real pain to try to roll the motor over by hand as there are no provisions for a nut or socket on the end.
I'm curious if anyone has found a mandrel which incorporates a nut or hex head on the end so that you can turn the motor over with hand tools rather than taking it all apart to get at the crank bolt.
I know it's possible to bump the motor over with the starter but I'm hoping for something a bit more precises. Thanks in advance.
1968 Firebird
IAIIa 522
340 E-heads
Northwind with XFlow TBI
4L80E
3.50:1 Rear
Old 04-28-2024, 10:56 AM
Mean Green's Avatar
Mean Green Mean Green is offline
The Star Machine mandrel has what you're looking for.
www.lancablingsolutions.com
The Following 2 Users Say Thank You to Mean Green For This Useful Post:
Old 04-28-2024, 07:16 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
Yup, Jones racing products will sell you one too. Its in their catalog under Drive Hubs
Jones Racing Drive hubs
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
The Following 2 Users Say Thank You to 73LeMans For This Useful Post:
Old 04-29-2024, 05:37 AM
Thanks to you both.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 04-29-2024, 07:46 AM
John Langer's Avatar
John Langer John Langer is online now
I use a Moroso
Old 04-29-2024, 09:30 AM
Feeling foolish, my search terms perhaps kept me from finding these. I had no idea this was a "thing". I appreciate the replies. My pump came with the mandrel, wishing I had known a bit more when I purchased it and I could have asked more questions.
Thanks!
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 04-29-2024, 05:48 PM
slowbird's Avatar
slowbird slowbird is offline
Originally Posted by John Langer View Post
I use a Moroso
Moroso make one that works with a Pontiac balancer? Or you you using a Chevy one?
The Following User Says Thank You to slowbird For This Useful Post:
Old 04-29-2024, 06:30 PM
Chevy bolts up to an ati balancer.
The Following User Says Thank You to John Langer For This Useful Post:
Old 04-29-2024, 04:51 PM
Commonly called a front drive kit. This allows you to mount multiple pulleys to the front of the motor at the same time and space them as necessary for an oil pump, vacuum pump, alternator, etc.
Old 04-30-2024, 05:44 PM
Thanks again everyone, I have a 4 bolt Pontiac balancer.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 05-01-2024, 07:42 AM
Don 79 TA Don 79 TA is offline
about 10 years ago when i was looking for one the only one at that time was from TIP, but at that time didn't have it for the pulleys i was using. i think they do now or perhaps could make one???
i have the butler one, while it works, i do miss that ability to put a wrench on the bolt to rotate the engine.
i use the march serpentine setup with the pioneer sfi balancer, and the butler mandrel. it's got some weight to it too
Old 05-01-2024, 06:55 PM
That's exactly my situation. I didn't want to mention where I got my unit, there's absolutely nothing wrong with its. Works exactly as advertised and the price is right but not convenient when doing things like setting valve lash or getting to TDC. I'm chalking it up to my cost of learning. It's entirely serviceable, just looking for alternatives.
Thank you all...I'm going to carve out some time tomorrow to make a few calls and gets something on the way.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
