Pontiac timing cover tab
Hello all!! I am new to this forum and need some assistance. I have read plenty of articles regarding Pontiac timing cover casting markings for timing covers produced on certain years of Pontiac V8's Well I am one who replaced a timing cover on a 1973, Pontiac 350 engine without the casted timing markings. I have read older posts that "Pontiac Dude" fabricated some bolt on tabs, and were often sold to people via this site, or on eBay. I have reached out to him via message service but have noticed, he has been inactive since 2017. Any help on getting a proper tab marking would be greatly appreciated, I am wanting to avoid removing the entire cover and assembly, only to replace with one that has these markings. I have also looked all over the internet in search of a person who makes them using a 3D printer, amd have been unsuccessful. Please HELP!!
You installed a 76 to 79 timing cover from a low performance motor that had a abbreviated balancer.
Even if you had one of these bolt on steel timing tabs if your are running a normal balancer I don’t know that it would bolt on and not hit the balancer .
The Following User Says Thank You to steve25 For This Useful Post: | ||
Here is one of the timing tabs that works with a large balancer with a later model timing cover. I bought one off of eBay when I built this engine probably 8 years ago. It must have been one from Pontiac Dude.
Pontiac Dude goes by Bill Bailey on some of the Facebook Pontiac pages. Find him there and see if he has a timing tab.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
The Following User Says Thank You to Singleton For This Useful Post: | ||
If you ascertain TDC by removing number 1 plug and making sure its at TDC, wherever the mark on the pulley is (providing that you know it hasn't slipped on the rubber), Then thats where you make a mark on the timing cover for 0 deg. Put a thin line with tipex or similar.
Didnt the timing covers without marks use a bolt on plastic timing tab from the factory? Should be able to find a used factory one that will bolt on to your cover that doesnt have marks. I have a couple Id consider selling if needed.
The Following 2 Users Say Thank You to 78w72 For This Useful Post: | ||
A guy on Facebook (Terry Schroeder) has 3d printed one and is considering making more.
https://www.facebook.com/groups/4445...6902265811827/
I have one of Keifer's metal timing tabs. Works great and fits stock or aftermarket balancers. Too bad they may not be available anymore.
The Following User Says Thank You to Scott Stoneburg For This Useful Post: | ||
Franks Pontiac parts had two on there site until about 3 weeks ago, too bad!
Doesn’t Perform make a bolt on timing tab?
]"You installed a 76 to 79 timing cover from a low performance motor that had a abbreviated balancer."
nope my 78 TA 180 HP motor with a full balancer had the plastic one-it also had a hole for some sensor placement also
As far as I recall during those late cars with 2.73 rear gears or less got the small low per balancer, so this would call for two different bolt on timing tabs no?
Mine had 2.56 gears-and could only pull 4000 when stock in high gear! 130+ mph on Texas World Speedway straight-and a few empty South Texas roads Normal balancer plastic tab.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune 13.43@103.4 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs Last edited by Skip Fix; 04-05-2024 at 10:10 AM. |
