Nunzi cam
Just saw one on fb anyone know specs nunzi 2041 ???? 068 but higher lift thanks Geoff
I don't know what the part number is for this Nunzi cam. Looking at the date on the file, I got the lobe information in Aug of 2015 and don't remember from who.
Stan
The Following User Says Thank You to Cliff R For This Useful Post: | ||
Nunzi 2041 in a 455?
Cliff R, I just acquired a 1974 455 that I eventually want to drop into my 74 Ventura. I haven't rebuilt the 455 yet. The car is primarily a cruiser. I will use the 1974 #46 heads from the 350 with screw in studs (will send them off to get 2.11 intakes) and I have a Nunzi 2041 laying around I was planning to use in this motor. The Ventura has a 3.08 posi rear and a 1977 Q-jet from a Trans Am. Will the 455 be undercammed with the Nunzi 2041? What do you think of this combination?
Tim Corcoran |
Why would you think it would be under cammed when the 73-74 SD455 came with a smaller Cam then that?
