I am building a 73 2 bolt main street duty 455 motor. Block will be bored .30 over. Heads will be 7F6 and factory HO aluminum intake from 72 455. I believe the general factory cam is a 068? The car will be a 4 speed muncie m20 with 12 bolt posi with 3.55 gears and stock G60x15 tires. The car is a 72 GTO WW5 car. Car will be mainly for car shows and a few drag races. I would like a lumpy idle but able to sit at a stop light. Any suggestions for a cam and lifters?
Are you staying with the factory Hi Po exh manifolds, or will you run headers?
With 3.55 rear gears and a cam that will make peak power at a higher rpm you should ditch the factory connecting rods during the rebuild process and also and while your at it get the compression up to 9.2 if not 9.5 depending on the fuel you have access to.
I do stuff for reasons. |
I will use reproduction factory round port manifolds for the heads and factory exhaust
The Following User Says Thank You to Drewsgto For This Useful Post: | ||
Neat engine.
A couple years ago I did a 72 455HO with the same 7F6 heads, HO aluminum intake, but the heads were ported and compression bumped to 9.98:1. Paul C did a nice custom hydraulic roller for it 239/243 @ .050 on a 112 LSA that made good power with the RA manifolds in place. 507/571 and peaked at 5600rpm. It idled nice and ran the AC and power brakes. I'd probably tame that down a bit for what you're doing. I imagine your compression will be lower as well since those heads have pretty big chambers. Being a 4 speed will be nice, no converter to worry about. The really common 230/236 Comp cam chosen for many builds like this would work well enough from what I've seen and make decent power. Cliff has used that cam quite a bit as well as several others, and is something that Butler sells a lot of. In fact Cliff and others have dyno numbers they have shared on builds almost exactly like that. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
Sorry I meant the comp cam xe 274h not 278.
Xe cams don't get any love around here. You're better off with 2802 based on everything I've read.
78 T/A 4SPEED, Original paint, match #’s, stock original bottom end, milled 6x-4s, HE268H cam,17058263 Q-jet/ 72 jets, CH secondary rods, RA Manifolds, poly body bushings, Moroso SFCs,mine since ‘99. 77 t/a sold 85 Monte Carlo SS sold 83 Mustang GT sold |
Thanks for the comments. My engine builder is recommending the summit 2802 or comp xe278 cams for the motor. He said the 2802 will be milder and the xe 278 will have more lope at idle but will still produce vacuum. My 7F6 heads were still factory so they need new valves and springs. Thoughts?
![]() Quote:
Dennis |
The Following User Says Thank You to SD455DJ For This Useful Post: | ||
Sounds similar to the 464 I’m building. Are you looking for a roller cam or a flat tappet?
I went roller with my build and originally had a 230/236 picked out, but the crew here urged me to go bigger so I’ve got a 236/242 .521/.540 114 going in now. I chose a 114 because I have A/C, power brakes and an auto. You could probably go tighter with a manual to get more lump.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
Just planning a flat Tappet cam
Here is a more 'stock' 455HO engine rebuild that we ran a Summit 2802 cam in it (224/234/114 duration @ .466"/.488" lift). It is .030" over with forged Eagle H-beam rods and TRW/Sealed Power forged (heavy) pistons. The heads, intake and RA manifolds are all untouched factory pieces. The short block was from an older build (2000 miles) and we just added the 455HO heads, intake and exhaust manifolds (2.0625"/2.125" outlets!). The first pull made 410 hp @ 4800 rpm and 515 lb-ft @ 3600 rpm. After richening the Q-jet as far as we could go with the jets and metering rods we brought, it eventually made 431 hp @ 5000 rpm and 535 lb-ft @ 3500 rpm.
Dennis |
The Following 4 Users Say Thank You to SD455DJ For This Useful Post: | ||
Thanks for the engine build dyno info. How did the engine idle, was it streetable? The 2802 is a cam that I have seen recommended for the 455 motor since it seems to provide more horsepower and torque then the milder summit cam,I think 2801 version. All comments welcome. Thanks.
![]() Quote:
Dennis Last edited by SD455DJ; 09-13-2022 at 05:09 PM. |
Nice numbers!
It’s good that test started at 2500 to show just how low massive torque is already being made. The Tq never drops below 460 from 2500 all the way up to 4600. Did that total timing of 38 turn out to be the best?
![]() Quote:
Dennis |
This is the car ('71 GT-37) the 455HO now resides which is waiting for new canyon copper paint and eyebrow stripes (R/W). It's taking the place of the original 455HO engine that is all apart and in storage.
Dennis Last edited by SD455DJ; 09-13-2022 at 05:11 PM. |
Wow,,,41 total. Out of the mild to race engines ive had built from Eheads to ported iron ive never had a engine like even close to 41 degrees. Maybe 35 at the most.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
The Following User Says Thank You to scott70 For This Useful Post: | ||
These old chamber heads seem to like timing on some engines. My buddy would occasionally take his 69 COPO 427 camaro to the race track for fun back in the 80's and early 90's, and that thing always ran best with 42 degrees of timing in it.
I used to run the Nomad here back in that time frame with it's 327, with hump heads, and I always kept the timing at 41 on that thing where it ran best, and daily drove it that way. My 454 Chevelle, even with more modern AFR heads with heart shaped chambers makes best power at 38 degrees, which I didn't expect at all. Then take dad's 571 Pontiac for instance, with it's old style Edelbrock bathtub style chamber heads that everyone says likes more timing, didn't like anything more than 34 degrees when that was on the dyno. Go figure. That's why I prefer to dyno and test these things, they seem to be all over the place for what they like on timing. No set number. |
To add what FJ posted, when we dyno'd 455HO's back in the days before we understood what tight quench did and the actual static compression was lower 8's (8.0 to 8.3 range) the best power was in the 42 - 44 degree range all in by 2500 rpm. But that was probably with 93 octane 100% gasoline (no ethanol). The RAIV's liked 36-38 degrees all in by 3000 rpm with a minimum of 100 octane blends of real gas.
Dennis |
The Following 2 Users Say Thank You to SD455DJ For This Useful Post: | ||
I have the XE268 in my 461. Its very similar to the XE274 on paper. My engine idles smooth and quiet. Pulls hard and is all done at 4800. Def too small for a 455/461. If I were doing another HFT prob. just use the 2802.
