73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 06-15-2021, 03:38 PM
Flashflood Flashflood is offline
Send a message via AIM to Flashflood Send a message via MSN to Flashflood Send a message via Yahoo to Flashflood
Default Do I have to remove crossmember
Do I have to remove the crossmember to remove the transmission and engine together on a 350 olds? I removed almost all the exhaust, and the engine is free. But it seems the transmission the thing thats getting stuck. Any help would be appreciated.
Sent from my SM-S506DL using Tapatalk
Old 06-15-2021, 08:07 PM
cdrookie cdrookie is offline
yes
Old 06-17-2021, 02:37 AM
Brian Baker's Avatar
Not necessarily. If you unbolt the transmission from the crossmember mount at the top, leaving the mount attached to the crossmember, the tailshaft should slide right off. Having a friend under the car to help guide wouldn't hurt either.
The Following User Says Thank You to Brian Baker For This Useful Post:
Old 06-20-2021, 09:26 AM
Unfortunately I think cd cookie is right cause it ain't going anywhere and that stud where it was bolted to the crossmember isn't moving
Old 06-22-2021, 08:57 AM
I think you would have to remove the 2 upper bolts from the trans mount were it bolts to the transmission, then it "should" slide off. But I have always removed the trans mount myself.
Old 06-22-2021, 07:26 PM
Location cause the even the crossmember isn't going anywhere?
