Old faithful at butler
...does butler have the same old faithful cam like dave at SD performance seems the duration is different 236/ 245.....from SD and at butler 236/242 with different lope seaparations from 110 to 114....since a little spec difference could maybe make a big difference ....but maybe not....any thoughts....
If you are speaking of this cam it uses Comp XE lobes, numbers 3315 & 3316:
https://butlerperformance.com/i-2503...tegory:1272239 His similar grind with 242 degrees exhaust duration uses XE lobe 3317 https://butlerperformance.com/i-2503...tegory:1272239 The original Old Faithfull cam uses Comp High Lift Magnum lobes 3122B and 3120B, note the "B" suffix code can but not always alter the seat duration and or lobe lift than what's stated in the catalog. The newer version of the Old Faithful cam is slightly different, I believe it uses a combination of XE and Magnum High Lift lobes. I suspect they are lobes 3196B and 3123B .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 03-14-2021 at 03:35 PM. |
The 3315 only has 230 @ 0.050" I believe he is talking about something like this. https://butlerperformance.com/i-2445...tegory:1234797 Syan
Thanks Stan, brain fade I had the Stump Puller in mind.
The second Butler cam I linked with 236/242 - 112 LSA is closer. Again both XE lobes. Lobe 3316 288 236 157 .3470 Lobe 3317 294 242 164 .3600 112LSA The Old Faithfull over the years has had various variants. From a early cam card: Comp High Lift Magnum lobes Lobe 3122B 289 236 160 .3800 Lobe 3120B 306 236 245 .3830 112 LSA .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 03-14-2021 at 07:32 PM. |
Or if desired a hydraulic roller cam with a bit more 0.200 duration, more exhaust duration and additional valve lift.
Comp Lobe 3196 288 236 162 .3900 Comp lobe 3123 300 246 169 .4000 And as we know any of the lobes mentioned can be custom ground with whatever lobe separation desired, be it 110, 112 or 114 https://www.compcams.com/lobe-catalog .
yes the 236/ 242 WITH 112 BUT WILL TRY WITH 114 WITH MY 461.....
i also build another engine its a 428 ...like to use the same cam but maybe the lobe separation should stay between 110 an 112 in the 428 |
[mention]ponchorob [/mention] I just purchased the 236/242 on a 112 LSA from Butler for my 428/455 I’m putting together. Hopefully I can give some first hand feedback on it this spring/summer. The lobes are 3316/3317, though the cam card shows slightly altered advertised of 287 293 vs. comps lobe catalog of 288 294. It is effectively a XR288HR ground on a 112lsa. The .200 intake and exhaust duration is 5 degrees smaller on the Butler grind than Dave’s OF 2.0 cam if I’m not mistaken, with a fair amount less lobe lift.
For 3317 I have 293.5 @ .006 .050 is 241.8 |
I think I have the 1st version of "old faithful". back in 2008, Using it with Dave's 290cfm CNC ported Kaufman's.
Didn't know it's had other variations through the years.
Home of WFO Hyperformance Shaker induction. |
I'm positive Dave has always sold the same Old Faithful cam and the new OF 2.0.
I still like the high lift magnum lobes the best.Tom
Googled up.... "Once the four timing parameters are established, the cam should be designed for maximum lift."
https://www.tildentechnologies.com/C...rformance.html "If you want to build a street motor with the most power without a sacrifice of idle and low speed qualities, then lift is the most important factor to maximize, not duration. The best suited cams are those that seek to maximize lift while only adding a minimal amount of duration." David Vizard .
This is a cam I have on the shelf very close to yours,
I wonder if there are Bullet lobes that resemble the OF lobes but offer more lobe lift?
Here is a Bullet hydraulic roller lobe that is the same as the Old Faithful but with more lift....
HR288/390 288 236 160 .3900 Us it on the intake side. Then pick a exhaust lobe that suits the exhaust-to-intake ratio on the specific cylinder heads in use and/or the cars exhaust system in use, be it 4,6,8 additional degrees duration, or none.. Then it could be ground with any lobe separation desired. Now the question would be.... do they have on hand blank billet cam cores. https://www.bulletcams.com/Masters/HRlobes.htm Ask for Tim Goolsby .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 04-24-2021 at 09:42 AM. |
The Following User Says Thank You to Steve C. For This Useful Post: | ||
When you go with more lift some numbers have to change. Comp Cams show the 3316 to be 157 @ .200". But they also have the 3196 which is shown as 288 236 162 .390 Stan PS This is a graph of my simulation of each lobe and what the difference in lobe lift would look like. Mike / Pastry Chef maybe can post a better graph
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 04-24-2021 at 06:38 PM. |
Stan, the lobe I mentioned in post #23 was in response to this, "I wonder if there are Bullet lobes that resemble the OF lobes but offer more lobe lift?"
The original Old Faithful cam sold by Dave Bisschop uses Comp lobe 3122B on the intake. That 3122 lobe: 289 236 160 .3800" lobe lift The Bullet lobe is the same but with .3900" lobe lift. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 04-24-2021 at 07:24 PM. |
If one wanted something similar to 236 degrees intake duration but more valve lift for modern cylinder head ports....
Comp QXI hydraulic roller lobes: Lobe number 13450 287 235 156 .3930" Lobe number 13451 289 237 158 .3970" .
Sorry compared the 3196 to the wrong lobe. But didn't SD have a version of the cam with the 3196 lobe also? Stan
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 04-24-2021 at 07:41 PM. |
Lift (in) Intake Exhaust E/I 0.10 76.20 68.80 0.90 0.20 150.80 124.60 0.83 0.30 209.90 169.70 0.81 0.40 265.20 208.10 0.78 0.50 309.90 231.20 0.75 0.60 330.70 242.20 0.73 0.70 334.70 248.40 0.74 I was intending on running the OF with 3122B/3120B lobes with 1.65 rockers, but I'm thinking I don't need that much extra exhaust duration given the E/I ratios. My max lift Is 0.640".
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. Last edited by AG; 04-25-2021 at 12:49 PM. Reason: change attachment |
Thread Tools | |
Display Modes | |
