T400 trans linkage
Swapped a trans and converter in my 69 GTO and am having a hard time getting linkage right. Problem is with the rod from the steering column that controls the neutral safety switch to the coupler. Shifter works great but it slips off the coupler when it goes into park, leaving the rod dangling. Everything worked great before the swap.
Thanks for any help, Chris
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR288 w 165s, RA manifolds, 11.60@114, 1.58/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
Scott, definitely not that clip. Didn't touch anything on the steering column, just disconnected the bottom stuff to get the trans out
the other 11
I have the cotter pins on. Problem is the coupler (#4 in the detail). Dude at work says I need to tighten something up on it so it doesn't slide.
I assume u have the bolt and the wave washer in there ?? to lock it ??
ALL all >? all the parts were on your car and working b4 the swap ?? th400 to th400 ?? Last edited by Scott Thelander; 09-30-2019 at 11:36 AM. |
That's where I went wrong, didn't tighten it up so it wouldn't slide on the rod. Had trouble getting it synced up so the key comes out of the ignition without having to twist the column. Need to try it again when I get time, thanks Scott.
