UMI is making stock height springs
http://www.pro-touring.com/threads/1...1972-GM-A-Body
We all know the Moog replacement stuff is crap nowadays. Just letting everyone here know UMI is making stock height springs for 64-72 A body cars.
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
Eaton had springs at one time. Glad to know about UMI.
Eaton still does, to stock and custom spec.
gotta have more info, I just installed MOOG springs on the rear of my 69 GTO, all seems fine to me, what am I missing for $ 300.00 a set?
color me gone Last edited by 1969GTO; 06-16-2015 at 08:20 AM. Reason: I first entered the wrong price. |
This is great news, I'm possibly looking to return to stock height!
'72 Lemans 400/468 Stroker - XX 400 block; Forged internals with flat top pistons w/ valve reliefs; Aluminum KRE D-Ports ported by CVMS (10.2 comp); XR288HR Comp Cam; MSD distributor; Port Matched Performer RPM; Quick Fuel Carb; Doug Long Tube Headers, 2.5 exhaust with H-pipe and Flowmasters; TH-400 w/11" 2800 stall; 9" Rear w/Eaton TruTrac Diff and 3.50 gears. |
I also just put a new set of moog spring in the rear of my 67 GTO and don't have any issues. Both sides sit at exactly the same height. What am I missing?
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
Why is Moog junk? I put Moog 8002 springs in my car two years ago and it sat right where I wanted it to and it is holding up just fine.
Yes,I would like to see where the MOOG springs are junk too...??
1967 GTO Sport Coupe 49,xxx orig.miles Champagne/Parchment 30 Original Owner Ordered PHS Documented Factory Options Second Owner |
Moog must be hit or miss. The spring I ordered for my bird were so bad it wouldn't come down of the bumpers.
Did you do the calculations right and order the correct springs?
