Quarter panel extension seals
Hi
Does anyone know where to get the quarter panel extension seals for -66 Bonneville or what can be used instead if not available?
-66 Bonneville Convertible |
I don't believe these are being produced. Mine are good, but I know people have asked about them on some of the cars that I parted out. I thought of using a very small vacuum line cut open or trying to find some edge trim small enough to work like these from mcmaster
http://www.mcmaster.com/#trim-molding/=qepaf6
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
Picture of the seal! That would be helpful.
Black door edge guard {?}
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Call P/Y I think the 65 GTO is the same material. It may just be a matter of cutting them longer
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
seal
I don't know if I got it right but on mine there was a piece remaining of a gasket which I believe should be the correct seal. Please correct me if I'm wrong.
I thought the 1/4 Ext. stuff was flat.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress |
I've looked for them too with no luck. I can't recall, but I think the headlight bezel seals are very similar. It was suggested to me to use the headlight seal and modify it to fit the rear extension. We'll see...it's too cold to find the parts in the shed to make a comparison.
65 Catalina 2D Post |
Jim
Need both F/R seals... can someone point me to the listing for same? Thanks!
The front bezels seals have been available for a long time from PY or Ames. I have one old rear ext. seal to help modify fronts when they're finally put back on the car...if that day ever comes. HA!
