Old 10-25-2012, 09:26 PM
69FIREBIRD76MM's Avatar
Default 69 firebird was 455, 4 speed, (budget) now LS-Lm7 5.3 gm swap
So I indecided to stuff a 2000 up, 5.3-lm7 or ls series engine in my 69 firebird, sold the 455 and the 4 speed muncie. This is the list of parts that i need to buy
TH400 JW ULTRABELL 92451LS
ENERGY SUSP. SBC M-MOUNTS
CORVETTE LS6 OR ZRI CAMSHAFT
98-2000 CAMARO CORVETTE INTAKE
FUEL RAILS
50-60 LB INJECTORS
PAC VALVE SPRINGS
98-00 CAMARO WATER PUMP
P/S PUMP AND RESERVOIR
HEADERS---DOUG'S
1350--DRIVESHAFT
80MM T/B
99 CORVETTE FUEL FILTER
STAND ALONE ENGINE HARNESS
REPROGRAM ECU
UNDECIDED IF TURBO IT OR NOT??? SINCE THIS MOTORS MAKE DESCENT H-P AND ARE CHEAP TO BUY...--TIME AND $$$
ID:	301488   Click image for larger version
ID:	301489   Click image for larger version
ID:	301490   Click image for larger version
ID:	301491   Click image for larger version
Old 11-27-2012, 12:05 AM
Default car updates
So i decided not to buy the jw ultrabell, instead i had my local trans built me a th400, i also bought the converter, 3200 stall, GM spacer, bolts for the spacer and cadillac cts-v oil pan, dipstick and tube, here are some pics
GM spacer #12563532
GM (6) bolts #19257940
ID:	304167   Click image for larger version
ID:	304168   Click image for larger version
Old 12-20-2012, 10:21 PM
pastry_chef's Avatar
GM spacer #12563532
Thanks, I was not aware of that spacer.
For those swappers who don't yet have a converter I found out CircleD makes a custom t350/400 converter with CNC billet front cover that bolts direct to OE LS flex-plate.
https://www.circledspecialties.com/p...converter.aspx
Old 12-20-2012, 10:59 PM
I Learned about the spacer from ls1tech and you tube, I already had the 9.5" converter thats why i went that route...
Old 12-01-2012, 10:50 AM
kainedogg's Avatar
kainedogg kainedogg is offline
Looking good brother. Check out the Ls1tech classifieds often for deals. Here is my twin-turbo LQ4 setup.
I have a 5.3 in my '68 LeMans and am going single turbo because the C5 FEAD blocks my older twin-turbo manifolds. I went with an '04 LS6 cam (5308), LS9 timing chain, LS6 intake and LS2 springs. If you go with the ZR1 cam you will need more parts since the CPS is located on the front of the newer Gen 4 motors. Your Gen 3 ls, like mine has the CPS in the back. Not worth the hassle in my opinion.
Old 12-01-2012, 07:06 PM
Default ls 5.3 into older pontiacs
LOOKING GOOD BRO. What exhaust manifolds are you using for your twin set up? - actually ls1tech its being very helpfull, plenty of info, also yellow bullet..
Old 12-20-2012, 12:05 AM
Default updates 69 firebird 5.3 gen III
here are few more pics, got my ebay headers install, th400 trans and 3000 stall behind it. motor mounts were a pita...lol, the oil pan i used its from a cadillac cst-v, it berely clears the drag link...motor mounts sit my motor way back...
ID:	306755   Click image for larger version
ID:	306756   Click image for larger version
ID:	306757   Click image for larger version
ID:	306758   Click image for larger version
Old 12-21-2012, 12:09 AM
kainedogg's Avatar
Sorry for the late response bro. My manifolds are Mustang T3 manifolds mated to LS flanges.
Old 12-21-2012, 01:46 AM
Default manifolds tourbo??
how were you able to do that, the tubes matched the mustang 302,351w. head exhaust layout? thats interesting, can you elaborate on that please? i know they sell plenty of 302 turbo exhaust headers on ebay too.
Old 12-21-2012, 04:05 PM
kainedogg's Avatar
This is where I got the idea.
http://ls1tech.com/forums/conversion...o-headers.html
Old 05-03-2013, 02:06 AM
Default 69 firebird ls motor
here are some more pictures of my car, i am almost done,cant wait to drive it...
ID:	321981   Click image for larger version
ID:	321982   Click image for larger version
ID:	321983   Click image for larger version
Old 05-03-2013, 03:45 AM
kainedogg's Avatar
You do good work brother.
Old 09-23-2018, 11:45 AM
Default ls swap
I blew that 5.3 motor racing on the street, now it has stock 6.0, corvette heads with BTR springs, retainers and .620" lift cam, FiTech efi stand alone harness Intanks efi system. This is the last time I mess with ls motor, this one blows I have a 455 I can put back in car.
ID:	493452   Click image for larger version
Old 06-27-2013, 03:15 PM
Tim john Tim john is offline
I am considering a LS installation into a 69 Firebird as well. Do I need a different oil pan other than the factory 2004 GTO LS 1 pan, will it not fit well ? Thank You.
Tim john---
Old 06-27-2013, 03:48 PM
Default ls1-5.3 swap 67-69 firebird
Tim john---
Tim, that oil pan wont work, Holley makes a nice one, ebay sells them for $399..buy the headers and the motor mount kit from "DOUG'S HEADERS", also you need the stand alone engine harnes for you engine...cooling fans from a 98-02 camaro-trans am ls1, if you are going toinstall a complete LS1--motor,stock, you need to have the ECM-reprogram and also remove the ANTI-THEFT-VEHICLE....Its tricky and kind of pricey, try to buy your engine complete, pulleys, p/s, alt. intake that will save you some good money..good luck man..post pict. about your project
Old 09-23-2018, 01:23 PM
FrankieT/A's Avatar
No more turbo? That motor will last forever...
Old 09-23-2018, 01:39 PM
FrankieT/A, yup no more turbo, this 6.0 should be around 500 to crank, plenty for me, turbos are addicting, I was always
Doing burn outs and racing on street with that turbo.
Old 06-27-2013, 03:53 PM
Engine that I am considering will be a complete take out of a modern GTO. I also would like to know about using a Tremec TKO 600 five speed, will the Tremec work with the factory GTO LS-1 flywheel and hydraulic clutch ? or do I need to go with what HURST Driveline offers in kit form.
Tim
Old 08-16-2013, 11:05 PM
Finally installed the exhaust by PYPES STAINLESS, o2 sensors, stand alone harness, air intake, bosch fuel pump, 36lbs injectors, my centerline rev wheels, 15x4 fronts with 205-70-15 and 15x10 rears with 275 drag radials, I was able to start the engine, idles fine but will need tunning cause of the cam and injectors change, next fill tranny up with fluid and maybe test drive it...here are some pictures, sorry kind of small, they were taken with my cheap ass cell phone...
ID:	333588   Click image for larger version
ID:	333589   Click image for larger version
ID:	333590   Click image for larger version
ID:	333591   Click image for larger version
Old 09-23-2018, 01:45 PM
FrankieT/A's Avatar
I have another thread going right now selling my Pontiac roller cam and lifters because of switching to LS. I have a 6.0 with LS3 heads with 5k miles on it . I'm putting my FITect on it because of functional hood scoop. Still collecting swap parts. I'll post pics when complete.
