The Inland Empire GTO Club dyno day @ HK Motorsports Dyno Shop
1972 GTO
http://www.youtube.com/watch?v=LFuBh...5&feature=plcp 1966 GTO http://www.youtube.com/watch?v=wYRLZ...eature=related 1964 Wagon http://www.youtube.com/watch?v=kGgOT...eature=related 1967 GTO http://www.youtube.com/watch?v=192_Q...eature=related 1968 Firebird http://www.youtube.com/watch?v=J-Bd08M33Yk http://www.hkmotorsportsdynoshop.com/
someone who thinks logically is a nice contrast to the real world. http://www.youtube.com/watch?v=3FfKVVZW1-Y Last edited by harry k; 02-21-2012 at 02:02 AM. |
someone who thinks logically is a nice contrast to the real world. http://www.youtube.com/watch?v=3FfKVVZW1-Y Last edited by harry k; 02-21-2012 at 02:06 AM. |
All sounded rather healthy Harry, BUT numbers with mild description of combo's would be helpful. Great sounding Pontiacs anyway.
Was that pin head Bruce Rhoads there with you? That looks like him in the picture and that sure looks like his 67. Tell him I said hey.
12.84 @ 106.89 with street radials. 12.63 @ 108.39 on drag radials. |
dyno results
71 gto-455---350+hp to the wheels
66 gto -455----315 67 gto--455----350+ 64 wagon 428. kre heads, rpm===360hp+ full exhaust, 410+ open exhaust |
Hey Chris, Yeah that was Bruce Man and his 67.
Harry, Thanks for posting the videos. Very Cool And we proudly wear our club colors here in Oklahoma too. The IE GTO Club started in 1985 has members in So Cal, Pennsylvania, Idaho, Arizona, Oklahoma.
You know it's going to be a good day when you wake up breathing! |
1968 Firebird -- 289 rwhp
Those videos came out much better than the mine did with the stationary camcorder.
Dil is being way too modest - he founded the club and was the dictator, I mean "president", of the Inland Empire GTO Club for many years. The '72 GTO is owned by Rick Haney, and is an original HO 455 with the rock-crusher 4-speed. It retains its original engine, trans, and rearend. The engine had come close to being destroyed by a speed shop down in Los Angeles - and it quickly earned the name "The Engine from Hell" as we got into it. You name it, and the shop had screwed it up from a crank cut out of index with egg shaped journals, a cam so tight in the bearings that liquified the babbit, and decks that were .004" low on each end. We obtained a new crank from Ken Brewer, a custom HFT cam from Ken Crocie and had the block square decked. The 7F6 heads were milled .048" to raise the compression up to 9.3:1, and the heads were home ported and new springs and SS valves were installed. The 66 GTO owned by Tim Rankin has a 428 with 6X heads, and also has a custom SFT cam from Ken Crocie. Tim is still chasing a few demons trying to get the horsepower up, but he is making progress. We're coming to the conclusion that while the heads were ported before he got them, the port work has actually subtracted horsepower from even stock heads. I'm sure it won't be long and the heads will be history. The 64 wagon is owned by Jim Miholick and is a very cool ride. It also has a 428 with Kaufman heads hooking up to a Richmond 6-speed trans. Jim had an oil burning problem on the trip to and from Harry's shop and Jim has now traced it to a combination of aluminum valley pan and a defective PVC valve. This is the second bad valve we have come across, and both have been AC valves from one of our large Pontiac Suppliers (not PY). The 67 GTO is owned by Bruce Rhoads, and has a 428 short block that went from Bruce, to me, and back to Bruce. JE Sportsman pistons and BME aluminum rods. Heads are port matched 96's that are gasket matched but no port work. He's running a big SFT cam that he got from Dil that seems to work very good despite the low 9:1 compression. This combination runs much better than the sum of its parts. It's always enjoyable spending the day down at Harry's shop.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon. |
numbers & new vid
[quote=SupergasDil;4558942]Hey Chris, Yeah that was Bruce Man and his 67. Harry, Thanks for posting the videos. Very Cool Dill next is your turn for your gaser to get on the dyno [quote=lust4speed;4559517]Those videos came out much better than the mine did with the stationary camcorder. here is Micks vid>>>http://www.youtube.com/watch?v=IQaaTHKtiEM The '72 GTO is owned by Rick Haney, and is an original HO 455 with the rock-crusher 4-speed. It retains its original engine, trans, and rearend. The engine had come close to being destroyed by a speed shop down in Los Angeles - and it quickly earned the name "The Engine from Hell" as we got into it. You name it, and the shop had screwed it up from a crank cut out of index with egg shaped journals, a cam so tight in the bearings that liquified the babbit, and decks that were .004" low on each end. We obtained a new crank from Ken Brewer, a custom HFT cam from Ken Crocie and had the block square decked. The 7F6 heads were milled .048" to raise the compression up to 9.3:1, and the heads were home ported and new springs and SS valves were installed. Rick arrived with blue line & left with red line run notes:HK TUNE 455 H.O. 4-speed M-22 3:55 rear end. Bored .040 over 1.65 rocker arms. cam: The 66 GTO owned by Tim Rankin has a 428 with 6X heads, and also has a custom SFT cam from Ken Crocie. Tim is still chasing a few demons trying to get the horsepower up, but he is making progress. We're coming to the conclusion that while the heads were ported before he got them, the port work has actually subtracted horsepower from even stock heads. I'm sure it won't be long and the heads will be history. 428 .030 over custom grid cam 244/253 w/1.6 rockers HK tune The 64 wagon is owned by Jim Miholick and is a very cool ride. It also has a 428 with Kaufman heads hooking up to a Richmond 6-speed trans. Jim had an oil burning problem on the trip to and from Harry's shop and Jim has now traced it to a combination of aluminum valley pan and a defective PVC valve. This is the second bad valve we have come across, and both have been AC valves from one of our large Pontiac Suppliers (not PY). 428 ci, solid roller cam (dur = 242 254 @ .050< lobe sep 110 degrees, CR 10.5 (KRE alum heads), Tremec 6-spd manual, 3.42 12-bolt posi open cut outs The 67 GTO is owned by Bruce Rhoads, and has a 428 short block that went from Bruce, to me, and back to Bruce. JE Sportsman pistons and BME aluminum rods. Heads are port matched 96's that are gasket matched but no port work. He's running a big SFT cam that he got from Dil that seems to work very good despite the low 9:1 compression. This combination runs much better than the sum of its parts. 96 HEADS RA iv VALVES CAM: 605/589..254/259@.050..112* SOLID(1.65 ROLLERS) 9.3 COMP..DEMON 850 CARB RPM MANIFOLD 3.36 R.R 11" 3600 STALL T-400 ELECTRIC FUEL PUMP(140) OPEN CUT OUTS NOTE THE PONTIAC BLUE FUEL DRAIN CUPS !!!! It's always enjoyable spending the day down at Harry's shop
someone who thinks logically is a nice contrast to the real world. http://www.youtube.com/watch?v=3FfKVVZW1-Y Last edited by harry k; 02-23-2012 at 05:05 PM. |
