Unloading some parts...
OK, I've been collecting some parts for about a year while I do my restoration on my 79 TA but I've come to find out that some parts I don't need as mine are currently repairable and were never needed in the first place. Guess you shouldn't get ahead of yourself and buy things you might not need. Thats what I get for listening to a body shop!! Well my loss is your gain...
There are too many parts here for pix but if you ask I can send you some... Brake booster - $75 freshly painted, few chips on back Master cylinder - $50 Repro red nose emblem - $30 OEM RH front grill - $100 very good condition Repro outside door handles - $20 4 Chrome headlight bezels - $50 slight pitting on bottom of all 4 3 OEM wheel center caps with Pontiac arrow - $60 4 New wheel center caps with Pontiac arrow - $50 I believe these are NOS as they have the sticker on the inside. Windshield/rear window trim - $125 each but would rather sell them as a set Rear valance - $25 mild surface rust on the inside Fiberglass spoiler, front & rear flares (5 piece) - $250 Seen online for $300-400 for set RH/LH fenders - $500 each RH fender is near mint and LH has some very minor rust. Neither has dents. These are for local pick-up only as they are too large to ship! Front spoiler - $75 Middle bracket is cracked but held onto radiator support fine and a crack in the center on the bottom which is hardly noticeable. Front flares pair- $50 LH has small crack near bottom of mounting bracket and bottom mount is cracked but didn't effect application. RH has one bolt on mounting bracket halfway snapped off but no damage to flare. Turn signal - $20 I believe is pre-79 as it has the hole on the end. Hood hinges - $50 They opened and closed fine when they were on the car. Will need to be painted. Shifter knob - I have 2 of these: one is in near mint condition w/ minimal wear and the other has a small crack in the top near the button and 2-3 little indents. Looking for $25 for the near mint condition one and $10 for the other. Shifter button - I have 2 of these: one is near mint with hardly any wear and no scratches and the other has a small, faint scratch. Both very good condition. Looking for $25 for the near mint condition one and $20 for the other. |
Correction: the shifter knobs are for an automatic car.
Interested in the booster...pm sent
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
Outer handles and emblem sold..
The shifter buttons are the red bird!
Turned up 2 more pieces for sale:
Steering wheel and hub - $50 The wheels foam has cracking either to sun or heat but still feels relatively soft and a small hole in the backside at the 12 position. The hub is attached to the steering wheel and has spots of flaking of the paint. Repro LH/RH 79-81 front grills - $150 These are new and include the screws to attach to the nose. |
Repro grills sold
Steering wheel sold
$10 shifter knob sold
Brake Booster - pix 3 and 4 show the chips that are on the backside and won't be seen once installed.
Master cylinder - I believe this is for a '80 and up Firebird/TA.
OEM RH grille - has one small scuff mark (pix 4) on the upper left hand corner near the turn signal but is hardly noticeable. Tape on the top came off when I removed but tape on the bottom is still attached and unused (see last pix)
Turn signal - mint condition. I believe this is for a pre-79 Firebired/TA.
The reconditioned mirrors have been reduced to $150
Are the front & rear window trims black or natural?
What condition?
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
It is actually the outside molding for the front/back windows.. They are silver and brand new reproductions.. Don't know if you were referring to interior or exterior molding/trim but the description was alittle bit confusing so I just wanted to clarify..
That's what I was looking for - the outside. Where in NY are you?
What color is the interior? I need a Driver's side arm rest/door pull for the deluxe Camel Tan interior in perfect condition.
Boss - pm sent
4 Pontiac symbol center caps SOLD
Front/rear window molding sold!!
