Fuel line and system suggestions
My son and I are working on his 79 TA (it's a painted shell being reassembled) and need to install fuel lines (and brake lines as well) prior to installing the rear suspension (Ridetech 4 link). We'd like to use factory lines and clips for a neat install, but wondering if we'll run into problems with the factory layout and line sizes (originally a 403 car).
The feed line (3/8) and brake line are on the LH side, and the return (1/4) and vent line (5/16) are on the RH side. My thought is we could jettison the factory return line and use the larger vent line as a return. But will 3/8 feed and 5/16 return be enough? Car will be LS powered (408), Terminator X, about 500hp or so. Also wondering whether having the feed line on the LH side and return on the RH side will create difficulties when it comes time to tying into the fuel rails? Haven't decided on a fuel system yet, so may not need a return, but it would nice to have it in case I end up there. On my Formula I went with a Rick's tank, ZLI fuel module, Vaporworx controller (and bent my own lines), but looking for something less expensive for this car if possible. Suggestions would be very welcome.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
Does the TerminatorX have the ability to do PWM control? I'm working on getting set up to test a Vaporworx controller to PWM a Walbro pump in a tank's inc tank. Might be an option. I highly recommend Carl @ Vaporworx. He tailored one of his units for this application and is just super to work with. I think at 500 crank horsepower on gasoline you'd have no issue with 3/8 feed and 5/16 return. Not sure if attempt the 1/4 return.
I have considered a Tanks Inc tank with a high flow GPA series Walbro pump. Looking closer now, the website does say that this pump can be controlled by PWM. Is this what you're using? How will your system be setup with the VaporWorx controller? I wonder if these Walbro pumps can be set up returnless style (cap off the return on the pump) where the Vaporworx controls fuel pressure and pump speed using input from a fuel pressure sensor? This is how my Formula was originally set-up (albeit used a GM fuel module so no return to cap off). Also, may be possible to set-up as a return system with fp regulator (C5 style?) to control pressure, but using input from a MAP sensor to control pump speed. This is where I ended up with my Formula (modified the fuel module to internal return style). The least expensive in-tank option seems to be a Holley muscle car/sniper Fuel Tank Module and one of their tanks. The module is internally regulated, integrated sensor, etc., but don't know how well these modules work. I don't believe they can be controlled with PWM but it seems to be an attractive option.
Mine has a tank's inc tank and a Walbro 450 pump.(for e85 compatibility) Carl devised a way to use one of his controllers triggered by my ECU(MS3 Pro Ultimate) I will be using the open loop PWM strategy of my ECU to pump through my existing return regulator. You could also use the Corvette style and have a short return line. You cannot deadhead any fuel pump. You can run a single line forward to the engine, but somewhere the pump has to be able to bypass. It could be with a Corvette style regulator and short return, or even a regular regulator and short return. It could be done internally in the tank(bleed orifice on the pump, or siphon jets etc) But no fuel pump I'm aware of can be truly deadheaded. I am unfamiliar on how/if the Holley does PWM, so I'll be no help there...
I am running an Edelbrock ProFlo4 SEFI system in a 1968 GTO 400 4 speed. Using original fuel and vapor return lines are problematic with modern fuel. The lines must be shielded from all heat especially heat from the exhaust manifolds or headers.
The Edelbrock requires significant constant fuel pressure in excess of 55 psi for the horse power you are seeking. (1) You can use 3/8 lines for main line and for the return. They must be adequately shielded from all heat sources or you will be vapor locked or flow restricted and your system will not have enough fuel under high rpm/torque demand (2) Standard fuel gauge sending units normally have the "Vapor Return" line as a smaller size line and it is INADEQUATE to allow fuel to flow back to the tank and will cause a back up and prevent fuel getting to the injectors or throttle body. You will have to increase the size of the return opening on the sending unit; (3) Holly makes a very good "In Tank Pump" that doubles as a fuel gauge sending unit and DOES NOT REQUIRE a return line. It has a built in means of keeping unneeded fuel from being sent to the fuel rails or throttle body depending on your type of EFI. After experimenting with an external pump and fuel pressure regulator system using a return line, I found the Holly internal tank fuel pump to work best and cured all fuel delivery problems. No external regulator is needed and no return line is needed. |
After doing more research, and emailing back and forth with Carl, I'm leaning towards 340lph Walbro high flow GPA in-tank pump in a Tanks Inc tank, C5 regulator, VaporWorx ReturnX PWM controller, and new factory 3/8 line to the front.
In total, should be about $1600 less than running a Rick's tank and VaporWorx controlled OEM fuel module type set-up (the system in my 70 Formula). I was concerned that a 340lph pump would overwhelm the C5 regulator, but Carl said the controller slows down the pump speed enough to prevent any overpressure scenario. He said he tested the C5 regulator with a 525lph pump and it maintained good pressure control with the controller. The smaller 255lph pump would be plenty to support the engine, and would work perfectly with the C5 regulator, but it doesn't work with PWM so couldn't run the ReturnX controller (which I like because it keeps the fuel cooler and increases pump lifespan). It wouldn't be too much more work at this point to run an additional line to the front so I could use an adjustable regulator, but I'm not sure the additional line and the clutter on the firewall is necessary. The only extra piece on the firewall on this set-up would be an external MAP sensor for the controller. For some reason, the Holley ECUs don't output MAP sensor voltage. Here's a photo of one on my Formula.
'71 Trans Am
6.0 LS I'm using a Tanks Inc. tank (2 extra gallons) with 340 Walbro with an Aeromotive regulator w/ return at the tank. Victor Jr. intake w/Edelbrock fuel rails and Accufab 1200cfm TB. I have consistent 60psi at the rail. I do have 1/2" fuel line from pump to rail, but that was from the 455 Poncho set up. I feel the 3/8" line would work just fine. If you go with the Tanks Inc. set up use their floatless fuel sender, their universal one with the adjustable float is lets just say,... not good. Walbro says right on their site NOT to use PWM with their pumps.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
There is a 340lph DCSS 39/50 turbine pump which they say is fine with PWM. The older gerotor style pumps are a no go.
At any rate, the 450lph “hellcat” GPA-9 pump I have says it is compatible with pulse width modulation. It’s brand new in the box if your son wants to save some $ and buy mine. If he plans on using E85 the extra capacity may be a good idea. The Terminator X is great. You add a couple wires from the sending unit to the Terminator X and it will give you the option for a fuel level gauge. My Terminator X will be getting wired up in the next week or two. Will your son be running the digital dash? I have the 6.86” pro dash going in mine. Fwiw I’m running a 1/2” hardline/ Fragola PTFE -10 AN lines on the feed and PTFE -8 AN for the return. Aeromotive 13134 regulator and high flow Motion Raceworks E85 block with a GM sensor. Holley VR series 460gph 10 micron filter. It may sound excessive but if your son adds a turbo later he’ll need a fuel system like mine.
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ Last edited by R 70 Judge; 03-11-2023 at 11:38 PM. |
Holley now makes a LIDR fuel level reader, and believe that is the best option. The floatless ones Tanks Inc have are not very accurate, especially below a 1/4 tank. I've tried several floatless senders with spotty results.
I run 1/2" lines for delivery & return, it ensures proper operation, period. (bypass regulator). I'm tempted to run a fuel mat on the pickup of my pump in the Tanks Inc efi tank for added insurance. .
That new laser holley fuel level sender -- can't be used with stock gauges
Some of their pumps. The turbine pumps are ok. Not sure about the the 340 or 400, but the 450 and 525/hellcat are routinely used with PWM.
Correct, as mentioned, the Tanks Inc floatless senders do not fit directly to the bottom of the tank. In a 67-69 F-Body tank, there is about half an inch from the bottom of the sender. I believe this is the case for most of their units, when fit to a Tanks Inc tank.
This gives you a margin of error of around half a gallon of fuel, plus whatever is still in your sump. Not as accurate as modern stuff, but even with vintage gauges, you're still in better shape than with a factory style sender in a tank that has no internal sump and no baffling that allows fuel to run away from the pickup. I typically fill up at an 1/8th tank and when I do so I usually fill a little more than 14 gallons, which would be accurate for an 1/8th tank with about half to a full gallon of "reserve."
So the depth of my A body EFI tank is 5 3/4", and I got the 5" floatless sender. Once it gets down to about a 1/4 + an 1/8, it's a crap shoot what's in there. It will slosh and cut out, and no matter what, gauge wont really go below about a 1/4 and a hair below. I've run out with it, and that's not good. And I've played with the calibration many times.
The float style that I got when I bought the tank was a joke, but it would go below a 1/4 reading. On the 442, has the same issue, started with the float type, then went to the floatless. The Speedhut gauge in the GTO allows to calibrate by E, 1/4, 1/2, and full. I went gallon by gallon on it at one point, and that was the best I could get it. I even bought a cheap gauge as a test, it's not the gauge. Like I mentioned, I haven't tried the reed type, but probably will use one in the 442 as a test. But pretty sure I will do the LiDAR on the GTO. I'd be curious to hear others' experiences, but doubt I'm doing anything wrong. .
I use the floatless tube from tanks inc in both EFI cars and installing another in a current build. Been using them in all installs for several years now.
My experience with them has been ok. Way better than the stick and ball setup. I have to admit though I've never been in the habit of running any car much below a 1/4 tank anyway so Ive never experienced fuel delivery issues when way down on an 1/8 tank or less. I do however test accuracy when the tank and float are first installed on every car with a stupid simple method. I get exactly 5 gallons in a can and dump that in a completely empty tank, make sure car is level and turn the key on and check the gauge. In all the 20 gallon tanks I've checked the gauge always settles in at 1/4 or very close to it give or take a smidge. I call that accurate enough and make a mental note when the gauge in that car reaches that point I have 5 gallons left and I start looking for a gas station. Last edited by Formulajones; 07-19-2023 at 07:34 AM. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
One thing on the ball float type is, the arm has to be so short, there's no granularity. Like from 1/2 to 1/4 tank, it drops all at once, and happens fast. It hovers at full for a while, then can drop to under 3/4.
On the floatless it's kind of the same from full to 3/4 or so, then it drops at a faster rate to 1/2 and 1/4. You can start driving with a full tank, occasionally glance at the gauge, and get an idea of the rate of burn. So you relax about watching it, the next time you look at it, it's at a 1/4 and panic sets in. .
