IA II cast iron block update
Just want everyone to know that Cast Iron and Aluminum Blocks are in the machining process.
If you are looking for a block with special order items, such as a big cam tunnel, the time to order would be now. We apologize for the long delay. The new, blocks with our latest improvements in casting and machining, will be ready for shipping beginning 2/15. We have moved the CNC machining to a new building, within the same company, with new machines and dedicated operators. All of the CNC manufacturing is done in a cell with palletized robots loading and unloading the blocks. We now supply the blocks with the main and cam tunnels line honed to save additional machine cost. The improvements include adding more cast Iron to the main webs. We now have to machine both sides of each web to match the caps. This removes any stress risers in this area to improve strength. The main webs are now a full 1". We have also down sized the oil feed hole to the cam bearings to 1/8 of an inch to keep more oil on the main bearings. We thank everyone for their patience and look forward to keeping the Pontiac community supplied with the best possible products.
Frank G |
Pictures of the changes.
Bob C. Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads Boss Bird Funny Car Best pass to date 08/06/2016 6.027@231.64 Allpontiac Big Chief Aluminum Engine Block http://www.AllPontiac.com |
I have to ask, when will the revised Tiger heads be available?
What changes were made?
Read Post #1 by Frank, the changes are there.
Yeh thanks, I was referring to updates on the Tiger heads.
Good news!! That's allot of air flow. I would like to see a set if possible.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Good news! Thanks for the update.
I have the new casting going in the mill on Friday.
Then it will go for sonic checking and porting. Don't be surprised if we have numbers in the 520ish CFM range. These prototypes have been near 10k rpm on someone's car already.
Nice!
When are you guys going to come out with a service replacement block good for 1000hp and a target cost of under $1,000... you would sell tons of them. Sorry, had to type that .
Thats......FUNNY! LOL! GTO George |
Put the crack pipe down and step out of the smoke John.
Why would they cost so much?
There is no reason to have a larger oil feed hole is the main reason to down size this hole.
And anytime you reduce the cross section you gain yield strength. Machining the sides of the Mains is like polishing a crankshaft to reduce the surface imperfections. It makes it stronger. We always try make a better product.
Thanks, Bob and Frank, for your efforts over all of these years!
This is a VERY exciting time to be a Pontiac enthusiast!!!!
Thank you!
1969 Pontiac Firebird |
Now that is what I call service. A couple of posts about additional machining costs and these guys are on it,fixed it, and the blocks upgraded too. Can't fault you.
These are significant upgrades and make great engine block even better! The smaller feed to the cam bearings will just help that area, even though it hasn't been an issue on the IA II block. Line honing the cam tunnel especially make it nicer for a guy not working with a well equipped machine shop. Line honing the mains eliminates a machine shop messing up that critical machining operation. For those looking for a bargain, you just got one. Most shops charge about $300.00 + to line hone a cam tunnel and main tunnel. It's like a discount on the block and the block is better all around. Great job.
