What we have so far. We have been over 500 in the test port, but Tony says some flow we dont want, so we will see what his final number is. I think we need a bigger valve but Tony is very conservative on valve size.
This is with all valve train intact. Exhaust is at 300, we are doing some testing on milling the exhaust flanges to the valve cover like the old days. The cutaways are stock castings. This is the first port done with the new head porters head. The RAV is 1/2 shorter than all the competition.
Lynn McCarty dba/McCarty Racing www.RamAirV.com lmc3470@aol.com www.ChemicalManagementIndiana.com 317-260-3486 |
STUNNING.
Where are the push rod tubes ?? and better not show that to anyone - the plug is to close to the exh. --- hehehe - Also - -I keep hearing Tony dont care about no stinking flow bench and CFM -- whats the deal.
![]() Quote:
i had Tony move the pushrods out of the port. Any more D***A** questions besides the ones you asked?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
maybe you dont understand sarcasim -- being from lesiana and all
yeah, here is some for you, i agree with Baker, someone must have dropped that 6 second car out of the sky in your driveway. you sure as he*l, didn't build it. heehee
![]() Quote:
I fundamentally disagree with moving the pushrod out of the way. Cross Sectional area on those engines are way more important than flow. We could only achieve the additional CSA by squaring off the port. CSA(min) = bore x bore x stroke x rpm x 0.0035/620 = 4.5 x 4.5 x 4.785 x 8000 x .0035/620 = 4.46 sq inches minimum. This limits this engine to low 8000 RPM with a minimum port. Our next engine is the 406 RAV engine @ 11,000 RPM. Valve train lined up straight I believe is a very good thing. A 5.750 length valve and pushrods in the 8.200 length range advantage RAV.
Lynn McCarty dba/McCarty Racing www.RamAirV.com lmc3470@aol.com www.ChemicalManagementIndiana.com 317-260-3486 Last edited by NHRASuperStock455SD; 05-23-2012 at 09:11 AM. |
![]() Quote:
![]() I think that the plug location shown looks a heck of a lot better than the PP head. Havent seen a cut away or raw casting to say with 100% certainty. The plug boss doesnt seem to be hugging the exhaust port wall as tightly and appears to be somewhat better retracted from the exhaust valve. The plug shell's job isnt just a place to put threads... it has to be able to pull heat away. The tip itself is exposed to pretty much the same temp during combustion, its the ability to pull heat(heat range) that counts. The exhaust side of the chamber itself is hotter than the intake side. It sees both combustion heat and exhaust heat. The intake side sees more or less same combustion temp at plug tip but is cooler there, due to intake charge being cooler. The closer the plug boss hugs the exhaust port the harder it becomes to cool the plug. Would this head be better if the plug was on the colder side of the chamber? Probably, if you got the room to do so and not wash the tip with fuel. The tip certainly can face the exhaust valve area. We wouldnt have heat ranges if all this stuff didnt matter. FWIW In identical spark plug types, the difference from one full heat range to the next is the ability to remove 70°C to 100°C from the combustion chamber. (Thats 158 - 212 F for those that want to know) Plenty of plug info here... http://www.ngk.com/search_char.asp?s...nufacturerID=1 When coldest plug isnt cold enough you have to reduce temperature.(lower compression or richen mixture or reduce advance or additional cooling capacity or any combination of those) That costs you horsepower. Ignoring it can cost you a motor. Last edited by BruceWilkie; 05-22-2012 at 07:46 PM. |
![]() Quote:
Tony says that they get heads in his shop all the time that actually flow big numbers, but they dont make any power. He redoes the heads.....the flow drops and the power comes back up to what he normally gets. It is like making beautiful pasty that tastes like S*&).
![]() Quote:
I hope u hit 500 CFM at what ever lift. 700 would be awesome.
Conrad 79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ![]() |
Awesome Lynn
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
I have no problem putting any car I BUILD -- up against anything you drag out of the swamp
![]() Quote:
Drag racing vs corners, both have excitement at every high speed turn.
Albeit a completely different kind. ![]() ![]() Looking at those ports sizes I swear Lynn used to build aqueducts. Damn! |
corners are only for people that dont know where there going - or where they been from --------
didn't you bust that thing up awhile back and have to get it bubble gummed back up? Maybe you would do better trying to turn left.
nevermind..bubbubbb...throttlestop...bubbubbb won't work in emano...emano racing
From the looks of your picture --you should be the last one talking about busting things up --- hell I was prob going faster doing a burn out than you do down the back strech!
see it aint just the cv1 guys that get all uptight!!!!
AND WERE OFF!!!!!!!! j.c you just dont steal my EHTTFMF and put RA5TTFMF! nice numbers!
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
